The thread discusses issues with VPN connection on a Windows system, specifically how the VPN's SonicWall setup interferes with accessing certain websites. The original poster seeks advice on bypassing this restriction. Replies suggest adjusting VPN settings related to routing and ask for details about the VPN client in use to provide more specific assistance. Overall, the discussion aims to troubleshoot VPN configuration problems affecting internet access.
mexicano
hi guys.
i coneect to my computer at work with my personal desktop but in order to conect to windows server 2008 i have to make a vpn connection first, but the problem is that ervery time i do this i cannot used some websites on my computer because of sonicwall thing in the vpn.
how can i bypass this?
I don't have a VPN on the pc I'm currently using so can't confirm the options but goto IPv4 advanced properties of the VPN connection and see if there is an option to use default gateway on remote network. if so then uncheck it. This should stop traffic bound for remote net being directed to the VPN.
patcooke
Microsoft MVP
Microsoft MVP
