BAtkinson17
- Joined
- Aug 7, 2014
- Messages
- 12
Hi
Recently my PC hasn't been able to connect to the internet. I looked at the connection status and it said Limited Access. Before, I received an update for my netgear wireless adaptor. I installed the update and it worked fine, then after a couple hours I went out. When I returned the issue came up. Everything else works, my iPhone, tablets both laptops and the Xbox. I've tried everything I've found on the web; restarting, disabling/enabling, looking for the exclamation marks and whatnot. Even reinstalling the adapters drivers. Nothing works. I am using a sky router and Netgear Wireless Adaptor model WNA1100. Also, if you give me something to do with CMD, that doesn't work either, it just doesn't recognise the command, I.e \ipconfig. Something to do with the path, I don't know. I'll solve that later. The real issue is my connection! So if any of you can help, it would be greatly appreciated!
Thanks,
Ben
P.S I don't understand all the computer terms, so you might need to explain abit. Sorry!
Thanks,
Ben
