The forum thread focuses on how to properly uninstall and install graphics drivers, with Peterr seeking advice as a beginner. Contributors recommend using tools like Display Driver Uninstaller (DDU) and suggest that removing existing drivers before installing new ones is preferable, preferably in Safe Mode. Overall, the discussion emphasizes safe and effective methods for updating drivers, with Peterr expressing gratitude for the assistance.
Hi Peterr,
yes it is preferable to first remove the original drivers before replacing. To this end a really good application is this Display driver uninstaller found here:
https://windowsforum.com/threads/display-drivers-uninstaller.179960/
I always use this myself and includes booting into safe mode which isn't critical but is perhaps the best way of doing things.
May I ask if a person is supposed to remove drivers before downloading and installing them? Obviously I am new at this.
I was reading about driver sweepers but then I read all can be done in the device manager.
Is this a safe mode task or not?
- Joined
- Aug 28, 2007
- Messages
- 36,163
Hi Peterr,
When I click here I am directed to Revo however, I did get to the DDU link. I assume it is for Win 8.1, 10 and 64 bit. It will be handy to remember. So I would download my manufacturer driver to desktop. use the DDU either in safe or otherwise then install the new driver.
Can you also try to uninstall and install in device manager first to see if you have any luck. I am not skilled that is why I ask. Thank you very much.
- Joined
- Aug 28, 2007
- Messages
- 36,163
You can use the device manager to update drivers although whatever changes you make affect the whole system so it's not like you can test.Can you also try to uninstall and install in device manager first to see if you have any luck.
Ultimately it's best if you just stick to the method you outlined above.. 🙂
