SomeRandom
An image from '100% Disk Usage Issue'. Two screenshots showing a Google homepage with historical doodle and Task Manager with 100% disk usage.
Sorry I am sort of a newbie sorry if I forgot any thing, let me know if I need to add anything. Okay so I noticed when I started my computer today that the disk is at 100% more or less all the time right now. I cannot figure out why this is happening and it causes my machine to go really slow. It took 20 minutes to just try and write this post and even just boot up google chrome? Is there anything I can do?
I have not seen this happen for a long time maybe 6 months ago I did but it was a driver conflict? I am not sure this is the same though that caused my machine to crash, this has not happened yet though.
Slight update while I was typing this the disk dropped to 3% for a while but when back up after a while
BIGBEARJEDI
Try booting your PC into SAFE MODE, and look at your utilization. It it drops off substantially; say less than 50% when idle, you most likely have an app or service in your Startup that is the culprit or culprits. If this is the case, you can go into MSCONFIG.EXE and uncheck all of your Startup apps, and reboot. When the utilization jumps back up to 100%, the last app you enabled and rebooted from is the Culprit and needs to be uninstalled from your W10.
Best of luck,:encouragement:
<<<BIGBEARJEDI>>>
SomeRandom
Hey thanks for the help it seems to be working now but I have an issue I am trying run a program that did work before battle net but now it does not open. I tried reinstalling the program and it made this file in a folder called Errors.
Also It seems to be applying to me installing anything? I am not sure what is causing this issue
I got this error : external exception c0000006
Exe: C:\Users\onemoretime\Downloads\Battle.net-Setup.exe
Time: Jul 29, 2017 4:54:00.441 PM
User: onemoretime
Computer: DESKTOP-GB3NRGJ
This application has encountered a critical error:
ERROR #1 (0x13370001) Fatal Exception
Program: C:\Users\onemoretime\Downloads\Battle.net-Setup.exe
Exception: 0xC0000006 (IN_PAGE_ERROR) at 0023:6FF9BDA0
Crashed Thread: 0x00001e40
<Application:>
Bootstrapper
<:Application>
<Inspector.ProjectId:>
127
<:Inspector.ProjectId>
<Inspector.BuildNumber:>
Bootstrapper 1.13.0.2685
<:Inspector.BuildNumber>
<Inspector.Module:>
Bootstrapper
<:Inspector.Module>
<Inspector.Platform:>
All PC
<:Inspector.Platform>
<Inspector.Priority:>
None
<:Inspector.Priority>
<Inspector.Summary:>
0xC0000006 (IN_PAGE_ERROR) at 0023:6FF9BDA0 : error 1: ERROR #1 (0x13370001) Fatal Exception
<:Inspector.Summary>
<Inspector.Assertion:>
DBG-ADDR<73F1B3F9>("")
DBG-ADDR<6FF9706A>("")
DBG-ADDR<6FF96D9F>("")
DBG-ADDR<715598F9>("")
DBG-ADDR<71515942>("")
DBG-ADDR<71513AFB>("")
DBG-ADDR<71513A9E>("")
DBG-ADDR<71553B0C>("")
DBG-ADDR<7150F309>("")
DBG-ADDR<00CAF182>("")
DBG-ADDR<00CAF31F>("")
DBG-ADDR<00C81E79>("")
DBG-ADDR<00C81580>("")
DBG-ADDR<00C8169E>("")
DBG-ADDR<00C7CC15>("")
DBG-ADDR<00C6C3AD>("")
DBG-ADDR<00C6DA31>("")
DBG-ADDR<00C6D69A>("")
DBG-ADDR<00C6E954>("")
DBG-ADDR<00CBD661>("")
<:Inspector.Assertion>
<Inspector.HashBlock:>
DBG-OPTIONS<FunctionsOnly>
DBG-OPTIONS<>
<:Inspector.HashBlock>
Showing 6 threads...
Thread 1/6 - Thread Id: 7744
DBG-ADDR<73F1B3F9>("msvcrt.dll")
DBG-ADDR<6FF9706A>("iertutil.dll")
DBG-ADDR<6FF96D9F>("iertutil.dll")
DBG-ADDR<715598F9>("WININET.dll")
DBG-ADDR<71515942>("WININET.dll")
DBG-ADDR<71513AFB>("WININET.dll")
DBG-ADDR<71513A9E>("WININET.dll")
DBG-ADDR<71553B0C>("WININET.dll")
DBG-ADDR<7150F309>("WININET.dll")
DBG-ADDR<00CAF182>("Battle.net-Setup.exe")
DBG-ADDR<00CAF31F>("Battle.net-Setup.exe")
DBG-ADDR<00C81E79>("Battle.net-Setup.exe")
DBG-ADDR<00C81580>("Battle.net-Setup.exe")
DBG-ADDR<00C8169E>("Battle.net-Setup.exe")
DBG-ADDR<00C7CC15>("Battle.net-Setup.exe")
DBG-ADDR<00C6C3AD>("Battle.net-Setup.exe")
DBG-ADDR<00C6DA31>("Battle.net-Setup.exe")
DBG-ADDR<00C6D69A>("Battle.net-Setup.exe")
DBG-ADDR<00C6E954>("Battle.net-Setup.exe")
DBG-ADDR<00CBD661>("Battle.net-Setup.exe")
Thread 2/6 - Thread Id: 11120
DBG-ADDR<00C558F8>("Battle.net-Setup.exe")
DBG-ADDR<00C5576C>("Battle.net-Setup.exe")
DBG-ADDR<00C5103D>("Battle.net-Setup.exe")
DBG-ADDR<00D25CEB>("Battle.net-Setup.exe")
Thread 3/6 - Thread Id: 11184
DBG-ADDR<76458792>("KERNELBASE.dll")
DBG-ADDR<00D1B954>("Battle.net-Setup.exe")
DBG-ADDR<00D1B8AB>("Battle.net-Setup.exe")
DBG-ADDR<00D1B866>("Battle.net-Setup.exe")
Thread 4/6 - Thread Id: 7240
Thread 5/6 - Thread Id: 4676
Thread 6/6 - Thread Id: 7616
<Inspector.DebugModules:>
DBG-MODULE<00C50000 00326000 "Battle.net-Setup.exe" "Bootstrapper.pdb" 0 {0b0697c8-a479-4033-87b0047526eb7246} 1 1490135343>
DBG-MODULE<77200000 0018e000 "ntdll.dll" "wntdll.pdb" 0 {3e6b95f1-0656-482a-735fbe90515f548e} 1 3575471198>
DBG-MODULE<74200000 000d0000 "KERNEL32.DLL" "wkernel32.pdb" 0 {a21dd779-f249-e708-3a11bbcc2511ab5f} 1 2876943953>
DBG-MODULE<76370000 001c2000 "KERNELBASE.dll" "wkernelbase.pdb" 0 {42e975f1-4d06-f0e9-ff3c933ab7fe5c4f} 1 3281344036>
DBG-MODULE<6BDE0000 00093000 "apphelp.dll" "apphelp.pdb" 0 {ffeff7ed-83bc-0735-b5c7467f796ca06b} 1 1668835649>
DBG-MODULE<74530000 00077000 "ADVAPI32.dll" "advapi32.pdb" 0 {a3d13d3a-e779-85a1-8d7a0a6291e4e264} 1 4279026613>
DBG-MODULE<73EC0000 000bd000 "msvcrt.dll" "msvcrt.pdb" 0 {62a9a857-d280-a718-2dff2f1438891eee} 1 3460004376>
DBG-MODULE<740A0000 00041000 "sechost.dll" "sechost.pdb" 0 {a5f37958-d964-2ac6-84c79c22bf3a41d9} 1 2363577946>
DBG-MODULE<745B0000 000c0000 "RPCRT4.dll" "wrpcrt4.pdb" 0 {86528b46-1514-40a9-03ad3aec1b0b391b} 1 2039565926>
DBG-MODULE<73CD0000 00020000 "SspiCli.dll" "wsspicli.pdb" 0 {656d572a-18d1-6792-3cdca133cb866a58} 1 4218812655>
DBG-MODULE<73CC0000 0000a000 "CRYPTBASE.dll" "cryptbase.pdb" 0 {cfbde80c-4204-2d09-8d68e5dbfbbb392f} 1 182211265>
DBG-MODULE<744D0000 00057000 "bcryptPrimitives.dll" "bcryptprimitives.pdb" 0 {d4551309-418f-9ec2-3abc6a018e4c14b2} 1 1783142089>
DBG-MODULE<742F0000 00067000 "WS2_32.dll" "ws2_32.pdb" 0 {4d765dcd-5e9d-26a4-ef98312d824aba70} 1 3447731020>
DBG-MODULE<741A0000 00051000 "WLDAP32.dll" "wldap32.pdb" 0 {a738cd71-6d99-cdfd-20963e3bc4584e7e} 1 621582904>
DBG-MODULE<760D0000 00118000 "ucrtbase.dll" "ucrtbase.pdb" 0 {197456bc-f2a7-d4f9-a7d6eae7664352cd} 1 2842342176>
DBG-MODULE<74360000 0013c000 "USER32.dll" "wuser32.pdb" 0 {100112f7-fb40-0e61-8355d837c7b6a031} 1 4045802820>
DBG-MODULE<742D0000 00016000 "win32u.dll" "wwin32u.pdb" 0 {b5a3224c-5384-d617-ca43845c40cfe562} 1 2740174735>
DBG-MODULE<738C0000 00008000 "VERSION.dll" "version.pdb" 0 {2c150934-78d3-1826-d154652c706e15dd} 1 3354854768>
DBG-MODULE<72090000 00006000 "MSIMG32.dll" "msimg32.pdb" 0 {ebe526d3-a6d9-d059-bcb1f0311a8e344d} 1 2507880646>
DBG-MODULE<77050000 00021000 "GDI32.dll" "wgdi32.pdb" 0 {f7fd33c0-e378-f730-64e606e1626185c1} 1 2292530205>
DBG-MODULE<77080000 00158000 "gdi32full.dll" "wgdi32full.pdb" 0 {54a0d072-2c3b-5a69-4446839db73f6a15} 1 491066322>
DBG-MODULE<74020000 00079000 "msvcp_win.dll" "msvcp_win.pdb" 0 {3cfc2727-efe0-550c-01b0e5d44e78707c} 1 905935380>
DBG-MODULE<74D80000 01348000 "SHELL32.dll" "shell32.pdb" 0 {dd069019-6e25-1037-87aff404391e001e} 1 472323820>
DBG-MODULE<74D40000 00039000 "cfgmgr32.dll" "cfgmgr32.pdb" 0 {96d979f3-b413-53e8-658f8a76e8f854b8} 1 2777409106>
DBG-MODULE<740F0000 0008c000 "shcore.dll" "shcore.pdb" 0 {e129e884-3b89-9822-daa20dec3245d898} 1 2757756773>
DBG-MODULE<76D30000 00238000 "combase.dll" "combase.pdb" 0 {6d545165-06e9-5f4a-bc3fbdaf3373f96d} 1 2235815228>
DBG-MODULE<76750000 00584000 "windows.storage.dll" "Windows.Storage.pdb" 0 {1548c5ac-7237-3085-e217a2b72edc1997} 1 1150770240>
DBG-MODULE<74CF0000 00045000 "shlwapi.dll" "shlwapi.pdb" 0 {616822eb-d2b5-09b8-034e07287e41da3c} 1 1242082987>
DBG-MODULE<76FD0000 0000e000 "kernel.appcore.dll" "Kernel.Appcore.pdb" 0 {d032aa6a-8fe1-f88f-5c56b0303ba62f8c} 1 3237849843>
DBG-MODULE<76CE0000 00045000 "powrprof.dll" "powrprof.pdb" 0 {72ec47dd-ec94-a885-b7628aa8042d66d2} 1 3387423731>
DBG-MODULE<76FE0000 00010000 "profapi.dll" "profapi.pdb" 0 {923af0ba-6023-35ba-95a7badcbca0965d} 1 2457692879>
DBG-MODULE<747D0000 000f3000 "ole32.dll" "ole32.pdb" 0 {7fc4c706-891d-3f3c-342b266ded86e491} 1 865256936>
DBG-MODULE<73F80000 00096000 "OLEAUT32.dll" "oleaut32.pdb" 0 {0e04e5f7-ef6d-2c3d-eeed102ede8b06c2} 1 619026631>
DBG-MODULE<713F0000 002c1000 "WININET.dll" "wininet.pdb" 0 {16479d96-4589-3253-037c9afc2f9f16c0} 1 4097981381>
DBG-MODULE<73660000 000ad000 "WINHTTP.dll" "winhttp.pdb" 0 {1e6b89bc-924d-a2ca-43d54c8b5b2c1dd4} 1 3820975244>
DBG-MODULE<744A0000 00025000 "IMM32.DLL" "wimm32.pdb" 0 {5d76b13a-830e-890a-5f290e3f31ffb090} 1 2744945041>
DBG-MODULE<73330000 00078000 "uxtheme.dll" "wUxTheme.pdb" 0 {46fc36b4-a19e-8842-ace815a1718fa97f} 1 3317234206>
DBG-MODULE<74670000 00146000 "MSCTF.dll" "msctf.pdb" 0 {f2f0d4a2-ab8f-6b9c-cd9dceef5f65da5f} 1 4049209058>
DBG-MODULE<71DA0000 0000a000 "secur32.dll" "secur32.pdb" 0 {69ae82fa-5893-8391-a17cf925fb3a4435} 1 1112592277>
DBG-MODULE<73630000 0002f000 "IPHLPAPI.DLL" "iphlpapi.pdb" 0 {72d7d34a-d792-c514-d4f727fe9d1ea942} 1 2683254403>
DBG-MODULE<74190000 00007000 "NSI.dll" "nsi.pdb" 0 {350ee15e-251b-1bd6-f3ffea2d48c19def} 1 3175138541>
DBG-MODULE<72F40000 00013000 "dhcpcsvc6.DLL" "dhcpcsvc6.pdb" 0 {30840d91-ec01-5c0e-c69826fa4520f7b3} 1 3008708604>
DBG-MODULE<72F90000 00014000 "dhcpcsvc.DLL" "dhcpcsvc.pdb" 0 {4129ca59-2952-5406-20b7b761ab02cd79} 1 1244989054>
DBG-MODULE<73850000 0004e000 "mswsock.dll" "wmswsock.pdb" 0 {a5bf5b0f-32c8-b6cd-c42f8fb854f2c400} 1 570384264>
DBG-MODULE<72020000 00067000 "TextInputFramework.dll" "TextInputFramework.pdb" 0 {be30cd4e-32c8-19ae-12d85d2c55fdf0cc} 1 3485696452>
DBG-MODULE<71C10000 0008f000 "CoreMessaging.dll" "CoreMessaging.pdb" 0 {b54ecba8-cc72-c574-3e31441da35735ac} 1 3217873122>
DBG-MODULE<70020000 00227000 "CoreUIComponents.dll" "CoreUIComponents.pdb" 0 {b374329c-85b1-73b6-e2970ed31fe3b93d} 1 4211427643>
DBG-MODULE<72FD0000 00028000 "ntmarta.dll" "ntmarta.pdb" 0 {5b699728-42de-2f49-db841b04f940603a} 1 337285895>
DBG-MODULE<72010000 00010000 "usermgrcli.dll" "usermgrcli.pdb" 0 {01af41ae-a64d-5c74-27623322209b4308} 1 898237729>
DBG-MODULE<71B30000 000d1000 "wintypes.dll" "WinTypes.pdb" 0 {200d9197-7687-a4a5-da202a59d4ec1354} 1 4201011529>
DBG-MODULE<73060000 0007f000 "DNSAPI.dll" "dnsapi.pdb" 0 {9cbfe351-9452-9ac8-4dbb725cc3bf6ee1} 1 992606832>
DBG-MODULE<73050000 00008000 "rasadhlp.dll" "rasadhlp.pdb" 0 {22b30da8-68e1-0243-f1dbb64aeb99fd0d} 1 1288392509>
DBG-MODULE<720E0000 00023000 "dwmapi.dll" "dwmapi.pdb" 0 {c89cc2c7-deef-a46c-f5169c5dad09c4b2} 1 1544467047>
DBG-MODULE<73000000 0004a000 "fwpuclnt.dll" "fwpuclnt.pdb" 0 {6e01c085-9bc5-ecd3-16ad457d831b137d} 1 594892385>
DBG-MODULE<738A0000 00018000 "bcrypt.dll" "bcrypt.pdb" 0 {0eb587be-b5f3-e370-2580dd38f5b563e4} 1 2985302899>
DBG-MODULE<6FE00000 00212000 "iertutil.dll" "iertutil.pdb" 0 {97ed2964-8bc9-5bc9-9307b1590474a9b6} 1 1318770714>
DBG-MODULE<716F0000 0015d000 "dbghelp.dll" "dbghelp.pdb" 0 {57c04494-da4c-46c3-5620dbe432bebb51} 1 638024248>
DBG-MODULE<716C0000 00025000 "dbgcore.DLL" "dbgcore.pdb" 0 {030459d2-e4ee-a339-15a5383c30d86e53} 1 1209478918>
DBG-MODULE<74180000 00006000 "psapi.dll" "psapi.pdb" 0 {e9377720-2835-cb76-7039dc46247e44c6} 1 1899160143>
<:Inspector.DebugModules>
x86 Registers
EAX = 02c1cb24 EBX = 6fe01d20 ECX = 6fe111bc EDX = 6fea2d48
ESI = 714cf3fc EDI = 6fe111a8 EBP = 02c1cab8 ESP = 02c1cab4
EIP = 6ff9bda0 FLG = 00010202 CS = 0023 DS = 002b
ES = 002b FS = 0053 GS = 002b SS = 002b
Memory Dump
Code: 16 bytes starting at (EIP = 6FF9BDA0)
6FF9BDA0: 8B 02 8B 0E 3B C8 74 09 1B C0 83 E0 FE 40 5E 5D ....;.t......@^]
Stack: 1024 bytes starting at (ESP = 02C1CAB4)
02C1CAB4: 01 00 00 00 DC CA C1 02 F9 B3 F1 73 24 CB C1 02 ...........s$...
02C1CAC4: 64 97 E0 6F 00 00 00 00 34 D3 67 71 34 D1 C1 02 d..o....4.gq4...
02C1CAD4: 64 97 E0 6F 1D 06 00 00 60 D0 C1 02 6A 70 F9 6F d..o....`...jp.o
02C1CAE4: 24 CB C1 02 20 1D E0 6F 77 18 00 00 14 00 00 00 $... ..ow.......
02C1CAF4: 90 BD F9 6F 00 00 00 00 00 00 00 00 34 D1 C1 02 ...o........4...
02C1CB04: 40 15 1D 00 94 CC C1 02 00 00 00 00 00 00 00 00 @...............
02C1CB14: 34 D3 67 71 F0 EF 1E 00 00 00 00 00 01 00 00 00 4.gq............
02C1CB24: FC F3 4C 71 00 00 00 00 00 00 00 00 00 00 00 00 ..Lq............
02C1CB34: 00 00 00 00 56 00 00 00 60 02 1C 00 B3 26 5D 74 ....V...`....&]t
02C1CB44: C2 5D 21 B2 E8 CD C1 02 D0 9F 27 77 12 FA 9B C4 .]!.......'w....
02C1CB54: FE FF FF FF A8 CB C1 02 D7 0A 24 77 00 00 00 00 ..........$w....
02C1CB64: 38 00 1F 00 38 00 1F 00 00 00 00 00 D0 00 1F 00 8...8...........
02C1CB74: CA 5D 21 B2 38 00 1F 00 70 35 22 00 38 00 1F 00 .]!.8...p5".8...
02C1CB84: 7C 32 CD 73 F0 36 22 00 38 00 1F 00 AC CB C1 02 |2.s.6".8.......
02C1CB94: 31 28 24 77 18 6E 31 77 38 00 1F 00 70 35 22 00 1($w.n1w8...p5".
02C1CBA4: 38 00 1F 00 F8 CD C1 02 E1 73 5B 74 00 00 1C 00 8........s[t....
02C1CBB4: 00 00 00 00 38 00 1F 00 26 68 5B 74 82 5B 21 B2 ....8...&h[t.[!.
02C1CBC4: 00 00 00 00 00 00 00 00 41 68 5B 74 70 35 22 00 ........Ah[tp5".
02C1CBD4: 10 00 00 00 E0 C4 1F 00 70 00 00 00 0E 00 00 00 ........p.......
02C1CBE4: FC 52 1E 00 E0 10 CD 73 6C 00 00 00 01 00 00 00 .R.....sl.......
02C1CBF4: 06 00 00 00 00 00 00 00 70 35 22 00 E8 02 1F 00 ........p5".....
02C1CC04: 00 00 00 00 01 00 00 00 00 40 AD 00 70 35 22 00 [email protected]".
02C1CC14: 4A 32 CD 73 70 35 22 00 D0 CB C1 02 00 40 AD 00 J2.sp5"......@..
02C1CC24: 94 CC C1 02 94 CC C1 02 78 CE C1 02 00 00 00 00 ........x.......
02C1CC34: 94 CC C1 02 24 CE C1 02 00 00 00 00 00 40 AD 00 ....$........@..
02C1CC44: 00 40 AD 00 00 00 00 00 94 CC C1 02 00 00 00 00 .@..............
02C1CC54: 00 00 00 00 00 00 00 00 78 13 1D 00 00 00 00 00 ........x.......
02C1CC64: B4 CD C1 02 19 00 02 00 78 13 1D 00 60 33 14 B0 ........x...`3..
02C1CC74: 06 00 00 00 B4 CD C1 02 00 00 00 00 78 13 1D 00 ............x...
02C1CC84: 70 35 22 00 78 13 1D 00 00 00 00 00 01 00 00 00 p5".x...........
02C1CC94: D0 CB C1 02 34 C5 1F 00 E0 C4 1F 00 50 C5 1F 00 ....4.......P...
02C1CCA4: E0 C4 1F 00 60 00 00 00 00 00 00 00 70 CE C1 02 ....`.......p...
02C1CCB4: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02C1CCC4: 00 00 00 00 00 00 00 00 0C 00 00 00 1C 00 00 00 ................
02C1CCD4: 00 00 00 00 1B 00 00 00 E0 CC CD 73 F0 DA CD 73 ...........s...s
02C1CCE4: 1C CE C1 02 00 00 00 00 00 00 00 00 E8 02 1F 00 ................
02C1CCF4: 10 10 CD 73 00 00 00 00 00 00 00 00 00 00 00 00 ...s............
02C1CD04: 80 11 00 00 02 00 00 00 00 00 00 00 00 00 00 00 ................
02C1CD14: CA 15 24 77 82 CC 75 B1 E8 FB 20 00 00 00 1C 00 ..$w..u... .....
02C1CD24: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02C1CD34: FC BD C1 02 00 00 00 00 E0 00 1F 00 1C CE C1 02 ................
02C1CD44: A0 0E 21 00 5B 00 00 00 7B E9 FF FF F5 FF FF FF ..!.[...{.......
02C1CD54: 00 00 00 00 02 00 00 02 00 00 00 00 E2 16 00 F4 ................
02C1CD64: 00 00 00 00 27 00 00 27 00 00 00 00 01 08 00 00 ....'..'........
02C1CD74: 00 00 00 00 B4 13 1D 00 00 00 00 00 68 CE C1 02 ............h...
02C1CD84: 00 00 00 00 1C 00 00 1C 00 00 00 00 24 CE C1 02 ............$...
02C1CD94: DB 09 24 77 00 00 1C 00 41 00 00 00 68 0E 21 00 ..$w....A...h.!.
02C1CDA4: 70 35 22 00 48 ED 1E 00 E8 FB 20 00 5D 00 00 00 p5".H..... .]...
02C1CDB4: 7C 97 1C 00 80 00 00 00 00 00 00 00 08 0D 0F 00 |...............
02C1CDC4: 1C 36 22 00 38 00 1F 00 C4 CE C1 02 01 00 00 00 .6".8...........
02C1CDD4: EC CD C1 02 00 00 00 00 4E 00 00 00 E3 14 45 76 ........N.....Ev
02C1CDE4: 00 00 1C 00 98 03 1C 00 01 00 00 00 4C 30 14 B0 ............L0..
02C1CDF4: 1C 00 00 00 00 00 00 00 80 00 00 00 20 CE C1 02 ............ ...
02C1CE04: CE 00 23 77 F0 FB 20 00 5D 00 00 00 36 00 00 00 ..#w.. .]...6...
02C1CE14: F8 38 22 00 00 00 00 00 40 06 01 01 CE 00 00 CE .8".....@.......
02C1CE24: 40 15 1D 00 F8 38 22 00 F0 FB 20 00 00 00 8A B5 @....8"... .....
02C1CE34: 00 FB 20 00 58 FB 20 00 00 00 00 00 5D 00 00 00 .. .X. .....]...
02C1CE44: 60 02 1C 00 64 20 00 01 5D 00 00 00 0C 00 00 00 `...d ..].......
02C1CE54: 00 00 1C 00 F0 CE C1 02 60 02 1C 00 E8 CE C1 02 ........`.......
02C1CE64: F0 CE C1 02 B4 E9 C1 02 D0 9F 27 77 18 00 00 00 ..........'w....
02C1CE74: D0 07 0F 00 00 00 00 00 70 EE 1E 00 38 42 22 00 ........p...8B".
02C1CE84: 01 00 00 00 00 00 0F 00 C4 01 0F 00 1E 00 00 00 ................
02C1CE94: 00 00 0F 00 20 00 00 00 54 42 22 00 54 42 22 00 .... ...TB".TB".
02C1CEA4: F8 08 0F 00 00 00 00 00 00 00 00 00 E8 CE C1 02 ................
An image from '100% Disk Usage Issue'. Two-screen setup showing a Google search for a Windows 10 error and a runtime error popup on the desktop.
BIGBEARJEDI
Glad to hear the first issue is solved! :up:
On the second, looking at your screenshot, you have a ton of online games installed. I do not play those on any of my computers, but several of our Admins here are avid gamers and may be able to help you. Also, have you tried posting your error message on the forum board of the maker of the game you are having the error with? Battle-something???
You said you didn't have this problem with this Game before. What is your EXACT version of W10 you are running please? To find it, take a look here at this Post I just did for another user: Windows 10 - Laptop appeared to reset when I clicked on restart
There are 3 major versions of W10; as you can see from my linked Post (v1511: 2015, v1607: 2016, and v1703: April 2017). Have you updated your computer to any of these newer versions since you last played/installed this Game? If so, you might need to visit the website or phone up the company who writes that Game and see if there are any newer updates or patches need to run the latest W10 version, also called the CREATORS UPDATE, v1703. If so, download that version from them, after uninstalling your broken version and see if it works. If it works, your Game was simply out of date and you're all set to go!:up:
If the problem persists, I would then begin checking for driver support and installing all current drivers and updates including BIOS and CHIPSET updates from your PC or Motherboard manufacturer. We don't have you hardware specs, but that would also be helpful to have. Remember, if you've never applied either BIOS or CHIPSET drivers to your computer before, it is an extremely HIGH-RISK procedure, and 95% of first-time users who try it fail and can bork your Motherboard/PC.:waah: Better to pay a licensed Tech to do this for you.
Hopefully, some of our other Gamer experts here can chime in and direct you to other possibilities I don't know about. Information is the biggest thing we need on your computer, since we can't see it and touch it from here if you know what I mean!
<<BIGBEARJEDI>>
nmsuk
if you've never applied either BIOS or CHIPSET drivers to your computer before, it is an extremely HIGH-RISKprocedure, and 95% of first-time users who try it fail and can bork your Motherboard/PC.
In the past this may have been true, but no longer. Most UEFI based systems now have a bios flash util you can boot to. As an example mine has M Flash and my other board has @bios. Always use them and never flash from within windows and the likely hood of bricking a board is minimal. As for chipset drivers installing them isn't high risk at all. Also 95% I'm sorry but thats just complete nonsense.
SomeRandom
Thanks bigbeard jedi! I did the command to find the version and that is listed below:
version 1703 os build 15063.483
also some other things:
1. I do want to find information for you and if you list or link how I can do that I would!
2. I think there might be more wrong than appears. I tried downloading the graphics card (nividia geforce gtrx 1060 3gb) drivers but they were failing to install.
3. Actually I seem to not be able to download and install any programs and I am not sure why.
4. I tried even reverting to a earlier save state and even wiping the machine clean and doing a clean reset of the computer but both times it gave me an error and then just stopped!
5. I am worried and wondering why this is happening any advice to try and figure it out?
6. As your advice I tried the company forums but there advice was delete files in program data folder and reinstall but I cannot seem to be able to boot up the app when I download so they are not helping/
SomeRandom
Sorry It did not give me an error. It said "an error has occurred all changed have been reverted " or something close to this nature.
I did also try fixing an image of the drive but got a super big error print out: at this link
I tried copying here but it was to big so it is on google docs. Also any advice on to do something to try and create an error. I am trying to find them but I am sort of newbish at this. But I do know I cannot open many programs (it seems chrome, slack, and pokemon tcg can open most others will not for some reason it just stalls out. Any time I try and install a program nothing happens. It starts then just dissapears. I am unable to clean reboot the machine like I said.
nmsuk
On a quick look you're suffering file corruption. Can you run chkdsk c: /f /r in a admin command prompt which may take awhile. After that can you run sfc /scannow and follow that with dism /online /cleanup-image /restorehealth and then try installing them again. The chkdsk command will require you to reboot.
nmsuk
On looking closer there are hundreds of them which just isn't right. So I'm thinking the hard disk is on it's way out. Could you download hwinfo64 and post a screenshot of the smart info for your hard disk please. I've never seen so many corrupted files in the driver store before and I've been doing this for nearly 30 years.
SomeRandom
Ok will try doing that
can't open after install got this error, I had seen this before when I tried installing a program
An image from '100% Disk Usage Issue'. Two computer screens showing a forum page and a file download folder with an error popup.
SomeRandom
also to give context it is a newish hard drive (got in February-ish), but rest is parts from amazon and made the computer with friends help
nmsuk
Are you taking screenshots with prnt screen, if you just want to share an app with select the app and press alt + prnt screen, then paste into paint so you can save it. The HDD though it could just be a bad drive, but won't give up on it yet. Have you tried a clean install of windows, which would be the best way to see if its the drive. But before that if you get seatools and create a bootable dvd/usb with it, you could do an extended drive error test which would help rule out this being the hardware and not windows or a driver doing this.
nmsuk
Another thought before I head off, in HWINFO find the SSD drive, then find what the drive health is. It's under drives, sata. In the morning I'll check back and continue helping. In the mean time another member will hopefully be around in your timezone.
SomeRandom
yes sorry the important part on that one was the external exception c0000006.
ok for the last parts you were saying I am not 100% sure on what to do to try that and anyway you could link or make it more , clear? I am not sure what seatools is ? I am willing try those more of not 100% they are or how to do it. I do want to try and fugyre this out
also I am not able to install the hwinfo32 at all period
SomeRandom
An image from '100% Disk Usage Issue'. Screenshots show HWiNFO software download and detailed system hardware info on Windows desktop.
Okay here is a photo of the app before it crashes, It seems like it installed but crashed 10-15 seconds after I boot it :( then it crashed
And also thank you for helping me ! I am not trying to stop you from your sleep ! Any help is appreciated and on your time and conditions I am just thankful you are willing to help!
I think this is a better picture I can capture before it crashes!!
