Yobbo
This is a message for Thumper 1337x.
Hi Thumper can you verify if I need to uninstall Adobe Acrobat Pro DC 2020 before I install your upload Adobe Acrobat Pro DC 2023?
Thank you in advance
Yobbo in Hong Kong .
Installer requirements will vary between software applications and software vendors.
I would simply try and install the new version. It should prompt or guide you through any necessary steps.
Neemobeer
Windows Forum Team
