Andy emulator starting automatically
Marios1441
Andy android emulator for Windows is starting automatically during windows startup and is placing a hidden
icon on the secret icons area on the taskbar next to the clock. What should i do?
if you open the Task manager (right click on Task bar), look across the top for 'Start up' and click it. You'll then see a list of apps which start when Windows starts, simply find the app you want and disable it starting. It will still work if you click it but won't start automatically.. :)
This is of course if you actually want to use the application if you don't then simply remove it from the Programs section. (uninstall it)
Marios1441
I have managed to fix it like you instructed.
