chubbycheese
- Joined
- Jan 13, 2009
- Messages
- 18
- Thread Author
- #1
i don't see that option on the screen resolution page.Hi, under the screen resolution, there's an option in blue writing called "Connect to a Projector" click that and select the option you want, this worked for me.
The drivers were installed automatically. Windows Update shows that there's an update for it but errors when it tries to install. the error occurs when it's already been installed(according to the error description)
when i tell it to extend the desktop to the second display it errors "Unable to save display settings"
i've tried both the nvidia control panel and windows. still nothing.
Is it possible to use the up to date drivers for vista for the video card?
Thanks for the info! I am using an eVGA 7900GT, and no I have not used Vista prior to Windows 7. I think I would like to change the clock to factory speed. Do you have anything you can point me to? I will see about the 158.24 driver if I cant get the clock sorted. Thanks!
I am having the same problem with the blue and white lines, it looks like corrupted drivers, however it only works when I choose "extend display" I can use both displays fine individually, or cloned, but not as an extended desktop.
I am using an XFX Nvidia 7900GT, and have tried both the newest drivers and the 158.24 suggested. My card is not over clocked.
If anyone can offer any additional assistance it would be very helpful!
