Mitchell_A
Former Moderator
I bought this router in July 2012 and suffered issues with all wireless clients being frequently disconnected.
I tried everything to fix it, from changing the channel, to the security, to adjusting the Tx power on the three antenna's. None of it worked. It made trying to do anything that required a consistent connection to the internet (gaming) a pain.
After several months of playing around with it and making no progress, I decided I would take it to work to replace our ISP supplied router from 2001. Much to my surprise, with ~100 different people connecting per day, not a single disconnect occurred throughout the entire summer. So I decided to take it home again and re-evaluate what might be causing the problem. Some sort of interference was my first guess. This turned out not to be the case as with almost every device that could possibly interfere unplugged it still occurred. The event log on the router would always show "Signal 15 received-goodbye" right at the time of the disconnect. So I contacted ASUS and had an RMA sent. Very fast customer service and handling times, by the way.
Needless to say, the unit I received also had the same issue. So I looked at my connection to the internet. I have an ADSL2+ connection which logs in via PPPoE. In theory, my router modem combo supplied by my ISP could be configured to hand the login over to the ASUS router, however the firmware was very locked down and had no easy settings for bridge mode. Instead, I configured the local IP network settings as "custom" and was able to check off the option "Enable PPPoE pass-through" (which is essentially a more technical way of saying bridge mode). With that enabled, I set my PPPoE connection type and username on the ASUS router and have not experienced another issue since. Anyone who has a DSL connection and a similar problem may want to make sure their modem is configured correctly to enable the router to handle login functions with your ISP. At work we have a static IP connection which requires no such configuration, hence why the disconnects never occurred there.
So now instead of another 9-months of my 2-year warranty remaining, I have a 90-day "reconditioned parts warranty" on my RMA. Oh well, at least it finally works. For anyone looking at this router as a potential option, it is simply exceptional assuming it's configured correctly.
It seems like you went through quite an ordeal with your router back in 2012, dealing with frequent disconnections and troubleshooting various settings to resolve the issue. Here's a breakdown of the key points from your experience: 1. Issue with Wireless Disconnects: - You faced issues where all wireless clients on your router were frequently disconnected, causing disruptions, especially during activities like gaming. - Despite trying different solutions such as changing channels, adjusting security settings, and tweaking Tx power levels, the problem persisted. 2. Router Performance at Work: - Surprisingly, when you took the router to work to replace the ISP's old router, it worked flawlessly with approximately 100 daily connections, without any disconnections throughout the entire summer. 3. Investigation and Resolution: - Upon bringing the router back home, you suspected interference as the cause of the issue but found that even with potential sources of interference unplugged, the problem persisted. - The router's event log showed a consistent message "Signal 15 received-goodbye" at the time of disconnects. - Contacting ASUS for support led to an RMA process, but the replacement router exhibited the same disconnect issue. 4. Configuration Fix: - You identified a potential solution by configuring your ADSL2+ connection to enable the router to handle the login functions with your ISP. - While your ISP-supplied modem-router combo lacked an easy bridge mode setting, you managed to set up the ASUS router with "Enable PPPoE pass-through," effectively allowing it to handle the PPPoE connection. - This configuration change resolved the disconnection issue, providing a stable connection without further disruptions. 5. Warranty Situation: - Despite the RMA process, you ended up with a reconditioned parts warranty of 90 days instead of the original 2-year warranty. Nevertheless, the router now works seamlessly after the correct configuration. In conclusion, the ASUS router proved to be exceptional in performance once configured correctly to handle the PPPoE connection, showcasing the importance of proper setup, especially for DSL connections. Your experience provides valuable insights for users facing similar disconnection issues with their routers, emphasizing the significance of ISP configuration compatibility for a stable network experience.
