Windows 10 Blue screen of death help
Conor Austin
Member
My computer is a Lenovo u530 touch and I got this message that said no hard disk detected and I was playing with the settings and I booted legacy mode I believe. Now I have a black screen that says no bootable device found insert boot disc. My computer doesn't even have a disc drive! WhAt do I do
Ps. It currently has a SSHD and I'm replacing it with a 500gn ssd .
Ok well if your machine came with an activation key (usually written on a sticker applied to the machine somewhere or you could try Jellybean to find out your key:
KeyFinder | Magical Jelly Bean )
You or your friend can then use this page to download the windows 8 or 8.1 install iso.
Upgrading Windows with only a product key - Windows Help
Place the iso files on the USB stick using this app:
Rufus - Create bootable USB drives the easy way
Once you complete the above you'll need to enter the bios and change the boot order so that your laptop will from the USB stick. Reboot and watch for any prompts to press any key. This is so you can re-install but access the repair console. When you get to the install page look...
You can further information on the recovery environment here:
Recovery options in Windows 10 - Windows Help
I just reread your post as well as the other thread you created (??)
Your running windows 10?
Did you check your machine was compatible?
If you have Windows 8.1 on a usb then you could always re-install that although you'll need a activation key.
However if your already using windows 10 then you may have lost the chance to use the jellybean key finder as you have already removed your original os.
Did you upgrade to Windows 10 or perform a clean install?
Yes I am running on windows ten but that recovery thing from the previous post picture is at the conclusion of anything I try ( when I power it on) but this is were I am now...
An image from 'Blue screen of death help'. Laptop screen displays Novo Button Menu with options for startup, BIOS, boot, and recovery.
Normal startup doesn't work as well as system recovery bios setup and boot menu DO work and I am currently on windows ten
The above is what I was asking you to do a post or two ago regarding this link:
Ok so if I'm correct you were originally running windows 8.1 and you upgraded to windows 10?
I forgot to ask, the 'recovery thing' you mentioned have you followed it to a conclusion like clicking on reset?
Resetting your PC
This process is a bit different depending on the version of Windows that you used to create the recovery drive.
If you created a recovery drive on Windows 8 or Windows 8.1:
  1. Connect the recovery drive and turn on your PC.
  2. On the Choose an option screen, select Troubleshoot > Reset your PC.
  3. Select Next > Yes, repartition the drives, and then follow the instructions on the screen.
If you created a recovery drive on Windows 10:
  2. On the Choose an option screen, select Troubleshoot > Reset this PC, then choose the reset option that’s best for you.
    If that doesn’t fix the problem, try Troubleshoot > Recover from a drive. This will remove your personal files, apps and drivers that you've installed and changes you've made to settings. If you've repartitioned the drive that Windows is installed on, note that this will restore the drive's default partitions.
Suppose I decide to just get a new windows. Would I just install my new ssd and then would it prompt me to buy a new windows? Further more
To be able to answer you properly I need answers to the questions below:
Ok so if I'm correct you were originally running windows 8.1 and you installed Windows 10.
The 'recovery thing' you mentioned have you followed it to a conclusion like clicking on reset?
1). Yes
2). Yes
3). I have tried but it says missing a key , or boot code Missing. So if I'm correct I need a usb with a 8.0 recovery drive
Ok,
using the recovery usb you have now boot back into the recovery console. Using this guide to open the command prompt app
When the computer boots off the recovery media, pick the Troubleshoot option
Then choose Advanced Options
and head on over to the Command Prompt.
If you can get the command prompt app working type:
bootrec.exe /rebuildbcd
Press enter.
If the above doesn't work then your going to need an install disk/USB of Windows 8.1 so you can boot from that and repair the bootloader.
Okay it said "0" but I have windows ten on the usb
So right now what about installing the new ssd and getting a completely new windows ?
That would work I guess as long as your machine is windows 10 compatible. You'll need to purchase a copy in order to get the activation key.
Could I buy a windows 8.1 the update?
And how would I do that ? Install the new ssd and then should it promt me?
