Windows 7 Bluescreen issues, plz help :-(
i just bought the ram like 2 weeks ago my previous ram used to do the same thing :-(. I'll prob run memtest again to see if the errors come back :/
the two most important faq needed here is your exact ram model\type and your motherboard model number, it can be very tricky matching ram which will work properly on a certain motherboard so we need to check they are even compatible, such as voltages and timings ?
from the CPUZ txt file I can see you have a P5QL PRO motherboard with DDR2 kingston memory PC2-6400 (400 MHz) but for some reason the Part number isn't filled out, does this mean it's the value ram ??
Top Bottom
