fillswitch
Member
Hello!
I've been troubleshooting this issue for months now and it is really frustrating. My issue is every time my computer goes to sleep/is shut down, when I start it back up, the computer works normally for about 7-10mins or so, and then BSODs. Once I reboot from the BSOD, my computer runs just fine until the next sleep-bsod episode
I've done Memtest86+ on my RAM modules to see if they were the culprit.
Module 1: Link Removed
Module 2: Link Removed
I noticed something strange on these tests though. When I would test my memory on slots 1-2, Memtest86+ would read my memory's speeds/timings correctly: 1866 9-10-9-28. But when I tested the same modules in slots 3-4, I would get half of that: DDR3-784 4-5-5-15. I then checked if slots 3-4 read with the lower speeds/timings in CPU-Z, but they did not; they read with the normal 1866 9-10-9-28. I'm not sure if that's an indicator of a problem at all, but it seems unlikely.
Trusting my logic, I decided to see if having both modules in slots 1-2 would alleviate the issue. I put the computer to sleep overnight (usually the scenario that results in a BSOD) and upon waking from sleep, it seemed fine for about 10 minutes (just like before every other BSOD), then it crashed: Link Removed
Here's my build for reference: Link Removed
Any ideas why this is happening?
Hey guys!
Got my RAM yesterday and installed them. I turned on XMP and let them run. By now, I've been through 4 wake cycles and NO BSODs!
:partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay::partay:
I think I can finally lay this one to rest. Thanks again for all your help! I really really appreciate it all!
This news has made my day! It may well have been a combination of things but as we were seeing lots of storage issues (as well as memory) it made sense to change some settings and have a look see. (We'd more or less tried everything else lol)
Much thanks for the update and I'm always here if anything should crop up again.
Best of luck! :)
Hey kemical,
I'm not sure what happened, but my comp was running for 4 days straight with no BSODs. This morning I accidentally hard powered-off my comp (thought my power button was set to sleep rather than shut off), which resulted in a "Enter recovery mode?... black screen on start up. Then, my comp blue screened 2x.
I'm thinking the blue screens had something to do with the improper shut off of my machine, but I'm not sure. Would you mind taking a look?
Thanks!
Fil
Hey Fil,
Downloading now.. Wow 112mb? Did you change your dump file settings? Please ensure they set like this:
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be
found later.
Click and apply to exit the dialogs, then reboot for the changes to take effect.
Hey kemical,
I added the MEMORY.DMP file to this zip (along with two dumps). Thought it might give you some context. I can always reupload without the .DMP file if you need it.
Thanks!
Fil
BugCheck 3B, {c000001d, fffffa800ad53940, fffff8800967ba50, 0}
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceHandler+7c )
Followup: MachineOwner
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION}  Illegal Instruction  An attempt was made to execute an illegal instruction.
Hey Fil,
The above means an app failed to start up correctly and I'd hazard that it's down to possible corruption caused by the hard shut down.
If the bsod has stopped it may well have cleared but personally I'd follow the instructions posted earlier and run a chkdsk as well as an SFC (system file check).If any corruption is around this will hopefully clear it up... :)
Sounds good Kemical. I thought it might be the cause. I'll run disk check and SFC just to be sure, but I'm sure it'll be fine. Thanks again!
Hope all goes well.. Any probs' just post back.
Just woke computer again and BSODs returned. Not sure why all of a sudden. I have a hunch that its related to my Z: drive (previously F:). Maybe something with the draw of power to 3 drives and 1 optical? I'm just shooting in the dark, but I'm going to try disconnecting it and seeing if BSODs return.
In the meantime SFC came up clean (Link Removed) and I'm running dsk chk now on all my drives. Here's my recent dump: Link Removed
BugCheck 3B, {c0000005, fffff960001014a7, fffff88008fbbf20, 0}
Probably caused by : win32k.sys ( win32k+d14a7 )
Hey Fil,
have you made any changes since the post that fixed it.... Didn't you add back some drives and return to using XMP profiles?
I also notice these drivers are still old:
mvs91xx.sys Tue Jul 30 07:52:22 2013: Marvel AHCI driver. 2014 version available on motherboard support page:
http://www.gigabyte.com/products/product-page.aspx?pid=4672#driver
AODDriver2.sys Wed Nov 21 07:44:04 2012: AMD Overdrive; also in EasyTune6 for Gigabyte motherboard Known BSOD issues in Win7 remove to test.
Was running chkdsk last night. Here's the BSOD this morning: Link Removed
I wasn't able to update the mvs91xx driver last time because the download wasn't an exe or msi file. It was just driver files and I wasn't sure how to upgrade it with just the files.
Also, for AODDriver2.sys, is there a way to remove a specific driver? Similar to removing a program? Or do I need to find a program corresponding to the driver and remove that program?
BugCheck 1E, {ffffffffc0000005, ffffffffff919260, 0, ffc30000}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+487ed )
Hey Fil,
The Marvel driver is actually quite important as the Marvel controller are known to cause issues from to time (my board which is revision 1.2 doesn't have a marvell controller). To install the driver you downloaded you need to access the Marvel controller via the Device manager. Right click on the controller and choose properties, driver and then update driver. On the next revealed box choose 'browse my computer for driver software' then 'let me pick from a list of device drivers on my computer' followed by 'Have Disk'. Use the browse option on the revealed box to find the downloaded driver. Your actually looking for the driver 'inf' and i'd try the Storport folder first.
AODDriver2.sys: This driver can be found in either AMD graphics driver, AMD overdrive (a tweaking app from AMD) and EasyTune6 from Gigabyte which has known bsod issues under windows 7. If you don't have these apps installed then do a search for the driver and if you can't remove it create a system repair point then break it by renaming it to AODdriver2.old.
How did the chkdsk results go?
Have you tried reverting settings as advised above?
So I'm not sure why, but 1 hour after waking my comp after work, no BSOD. This morning, I had disconnected my Z: drive on a hunch that this was the reason for the BSODs. I will report back if the comp blue screens after the next sleep/wake cycle.
Ok Fil, I'll await your next post.
Been on my comp for a few hours now, since waking it this morning. It looks like the Z: Drive being connected was the case. I'm not sure if maybe it was drawing too much power or if the actual drive is to blame. Since I ran SeaTools and dskchk on Z:, what can I do to see what's wrong with the drive?
Try checking the SMART data. You may need to enable it in the bios and then use something like speedfan to read the data. The other apps will tell you if a drive is about to fail or not or if you have bad sectors with SMART data you can see if the drive is wearing out.
Just as a side note how full is the drive?
Just got a recent BSOD, though from the blue screen, it looked like a different driver: Link Removed
I'll check the Z: drive another time. I had just reformatted it. It had something like < 100gb used out of 1TB.
BugCheck 1000007E, {ffffffffc0000005, fffff88011dbaebc, fffff88005fe24c8, fffff88005fe1d20}
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::DiscardAllocationInternal+50 )
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
Hey Fil,
looking through the dump file i see this originated in the GPU RAM. What make and model is your PSU?
Nvidia have recently released a new GPU driver try updating.
Did this occur after waking from sleep mode?
My PSU is: Rosewill Hive-750 (http://www.newegg.com/Product/Product.aspx?Item=N82E16817182133)
I'm downloading/installing the Nvidia driver now.
And yes, the previous BSOD was after waking from sleep mode.
Here's two more BSODs that just happened after waking this morning: Link Removed
Sorry for all this trouble. I guess the Z: drive wasn't the real issue =[
BugCheck A, {fffff6fb7a600300, 2, 0, fffff8000342f2fc}
Probably caused by : memory_corruption
Followup: memory_corruption
Although it say's memory corruption the dump file points to NTFS issues and indeed the other dump file was Bugcheck 124 NTFS issues.
I'd try different ports especially if your not going to update the driver below don't use the ports attributed to the Marvell controller as I mentioned before these controllers have been known for issues in the past.
The thing is you did get the machine to a point where the bsod stopped but only after you had removed several drives and a stick of RAM (as well as XMP settings). Personally I'd go back to square one and start again with that configuration. Once you've achieved a point of no bsod slowly add stuff back but this time only add one thing at a time then test.
I did get another BSOD, but it seems redundant to try and analyze it at this point.
Alright, I just manually installed the Mavell driver through Device Manager and I disabled AODDriver2.sys. I will go back to the following:
  • 1 stick of RAM in Slot 1
  • Default settings for XMP
  • New SATA setting (opposed to IDE) that you suggested earlier
