Windows 7 BSOD caused by Driver Power State Failure - now many programs no longer work
kbar918
Today my PC BSOD'd while I was in class, the message was a DRIVER POWER STATE FAILURE. This first crash did not create a dump file, leaving me to believe it was very serious. After the crash, the computer behaves very differently. Many of my programs still work, but the internet connection does not work at all (pings timeout, can't load any websites). However, the network diagnostic tool reports a valid internet connection, and several of my applications seem to think they are connected to the internet. They have even occasionally loaded data through network communication. Other strangeness: Steam no longer appears in my taskbar, but process runs for it at startup regardless. Attempts to launch any games in Steam cause the process to freeze in such a way that the Task Manager cannot kill it.
Since the first BSOD with no dump file, two more BSODs occurred (attached). With information I found online I made sure to update all of my drivers - there was an intel chipset driver out of date at the time of all of these crashes. I have since fixed that problem, but my internet problems persist (more info: after a very long amount of time some parts of some pages load, but I have yet to successfully get a ping response) and several of my programs no longer work. Can someone help me identify what could have happened during that first crash that caused all of this?Link RemovedLink Removed
I just removed McAfee with the Removal Tool, and immediately upon restart all of my problems have been solved. Thank you very much for that suggestion Elmer, and thanks to Saltgrass as well for all of your help the past few days. At the very least a bunch of my drivers are up to date now. :)
Please feel free to mark this thread solved.
For now, you may want to reinstall the driver for the Realtek network adapter. It seems to be showing up in the crash dump.
Do I understand you have not had any Blue Screens since you replaced the Intel drivers?
You also have another driver loaded, NBSPortDriver.sys, which seems to bring up mostly virus hits on the net when I search for it. But since it is from 2007, I would suggest you try for an update if you know what it belongs to. If you do not, you probably need to run some virus scanners.
Thanks, I reinstalled the Realtek network adapter driver but alas, my internet connection is still not working properly and I'm continuing to get strange errors from several programs. You are correct - I haven't had another BSOD since updating the chipset drivers. I do indeed know what the NBSPortDriver is (it is part of neurobs Presentation software) but I'm not able to find an update for it.
How were you able to determine the Realtek driver as the cause? I used Blue Screen Viewer but wasn't able to find that information there - do I need the tools that you can only get with an MSDN subscription to find that information?
For more info, I tried doing a system restore to a point before the first BSOD and had no luck. I've also checked the disk and run the memory diagnostic tool as well as prime95, no hits from anything. I really appreciate any insight, but I feel I may just have to reinstall Windows :(
I did not find the Realtek to be the cause, just mentioned. You are having network problems and you had a Crash. There is a possibility something got corrupted or something has been left in an intermediate state. So my thought was to eliminate the driver from being a possible problem.
You probably need to run a system file check to find out the status of the core files on your system. It has to be run from an Administrative command prompt, so use the Winkey then type cmd followed by CTRL+Shift+Enter.
After the window is open, type sfc /scannow hit enter and let it work. Report back if it finds any errors it cannot correct.
Scan showed no results - the machine did finally crash again though, so I guess the drivers I updated were not the cause. Unfortunate, but sort of good since it may be the case that finding the problem causing the crash will also fix the network problems and strange program behavior. Here's the dump file. Again, many thanks to anyone who can help - I'd really like to avoid reinstalling Windows.
I'll just show some things the dump file is saying.
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
FAILURE_BUCKET_ID: X64_0x9F_3_Rt64win7_IMAGE_pci.sys
I am not the expert in decoding dump files, but it looks like the Realtek driver is involved, but I can't really say it is the cause.
I do see some other drivers that are older. Doesn't mean they are a cause, but you might check for updates.
NBSPortDriver.sys Tue May 15 16:24:00 2007
BIOS64.sys Sat Jun 07 19:12:00 2003
BS_I2c64.sys Mon Jun 16 01:45:18 2008
If you can't get it solved by replacing the driver, we may have to go the Driver Verifier route and let it check the drivers. Post back prior to trying, if you want, but at least make sure you know how to turn it off with the /reset since it will give blue screens as long as the driver is causing problems.
Hi kbar, you've a load of very old drivers in the dump file. At the moment the dog is chewing my leg off as he wants a walk, if nobody beats me to it I'll post a report when I get back.
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes:
Device driver
Your latest dump file lists pci.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
McAfee is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall McAfee using the McAfee Removal Tool. Download Link Removed due to 404 Error as its replacement. Make sure your Windows firewall is enabled! Once your BSOD issues are resolved, feel free to try the latest version of McAfee.
Drivers that pre-date Windows 7. Update:
BIOS64.sys Sun Jun 08 01:12:00 2003 This is probably a Link Removed
BS_I2c64.sys Mon Jun 16 07:45:18 2008
BS_TPIO64.sys Thu Apr 30 04:17:44 2009
Found in Link Removed
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
Drivers with Updates:
MBfilt64.sys Fri Jul 31 04:40:32 2009
RTKVHD64.sys Tue Oct 05 10:58:40 2010
nusb3hub.sys Fri Apr 23 02:34:35 2010
nusb3xhc.sys Fri Apr 23 02:34:36 2010
Go to your Motherboard Mfr. Support website (or Link Removed - Invalid URL) and update your USB 3.0 drivers. A June 2011 set are available Here.
Rt64win7.sys Wed Jan 26 13:34:03 2011 Link Removed If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
Bugcheck Analysis:
BugCheck 9F, {3, fffffa8006eec060, fffff80004d303d8, fffffa800cd6ae10}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8006eec060, Physical Device Object of the stack
Arg3: fffff80004d303d8, Functional Device Object of the stack
Arg4: fffffa800cd6ae10, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7928f
MODULE_NAME: pci
FAULTING_MODULE: fffff88000f1f000 pci
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`04d30388 fffff800`03700cd2 : 00000000`0000009f 00000000`00000003 fffffa80`06eec060 fffff800`04d303d8 : nt!KeBugCheckEx
fffff800`04d30390 fffff800`0369e5fc : fffff800`04d30508 fffff800`04d30508 00000000`00000000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`04d30430 fffff800`0369e496 : fffffa80`0a983c68 fffffa80`0a983c68 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x6c
fffff800`04d304a0 fffff800`0369e37e : 00000009`8cc07798 fffff800`04d30b18 00000000`0004030a fffff800`0380b3c8 : nt!KiProcessExpiredTimerList+0xc6
fffff800`04d30af0 fffff800`0369e167 : 00000003`2b89dcc5 00000003`0004030a 00000003`2b89dc80 00000000`0000000a : nt!KiTimerExpiration+0x1be
fffff800`04d30b90 fffff800`0368a96a : fffff800`03808e80 fffff800`03816cc0 00000000`00000001 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`04d30c40 00000000`00000000 : fffff800`04d31000 fffff800`04d2b000 fffff800`04d30c00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
Drivers:
fffff880`04585000 fffff880`045c3000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00eb5000 fffff880`00f0c000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01400000 fffff880`01489000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`04410000 fffff880`04426000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0109f000 fffff880`010aa000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0a0d1000 fffff880`0a0dc000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00cc0000 fffff880`00cc9000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01075000 fffff880`0109f000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01671000 fffff880`01678000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`02ec1000 fffff880`02ec9000   BIOS64   BIOS64.sys   Sun Jun 08 01:12:00 2003 (3EE27F50)
fffff880`02eb0000 fffff880`02ec1000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`064e8000 fffff880`06506000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`02ea8000 fffff880`02eb0000   BS_I2c64 BS_I2c64.sys Mon Jun 16 07:45:18 2008 (48560BFE)
fffff880`02ea1000 fffff880`02ea8000   BS_TPIO64 BS_TPIO64.sys Thu Apr 30 04:17:44 2009 (49F91858)
fffff960`00630000 fffff960`00657000   cdd      cdd.dll      unavailable (00000000)
fffff880`0163e000 fffff880`01668000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`06826000 fffff880`06834200   cfwids   cfwids.sys   Mon Oct 10 21:45:40 2011 (4E935974)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01bcb000 fffff880`01bfb000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d35000 fffff880`00d93000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`014a7000 fffff880`01519000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`04400000 fffff880`04410000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05fad000 fffff880`05fbb000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`02e00000 fffff880`02e83000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`02e83000 fffff880`02ea1000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`02fb4000 fffff880`02fc3000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05a33000 fffff880`05a55000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05fc7000 fffff880`05fd0000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05fbb000 fffff880`05fc7000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05fd0000 fffff880`05fe3000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05fe3000 fffff880`05fef000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0fea1000 fffff880`0ff95000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0ff95000 fffff880`0ffdb000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`010f6000 fffff880`0110a000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010aa000 fffff880`010f6000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0152a000 fffff880`01534000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a7a000 fffff880`01ac4000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`045cf000 fffff880`045dc000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`03bff000 fffff800`03c48000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0ffdb000 fffff880`0ffff000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0f200000 fffff880`0f211000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`05f53000 fffff880`05f6c000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05f6c000 fffff880`05f74080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05f45000 fffff880`05f53000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0641f000 fffff880`064e8000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01bc2000 fffff880`01bcb000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`045e5000 fffff880`045fb000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`04b23000 fffff880`04b32000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05f9f000 fffff880`05fad000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00ba3000 fffff800`00bad000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04b43000 fffff880`04b86000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013d9000 fffff880`013f4000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`05a55000 fffff880`05a5a200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05ad1000 fffff880`05ae6000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05c00000 fffff880`05c23000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`05e8d000 fffff880`05e9b000   MBfilt64 MBfilt64.sys Fri Jul 31 04:40:32 2009 (4A7267B0)
fffff880`00cd2000 fffff880`00d21000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`06800000 fffff880`06825300   mfeapfk  mfeapfk.sys  Mon Oct 10 21:41:23 2011 (4E935873)
fffff880`05e9b000 fffff880`05ed1000   mfeavfk  mfeavfk.sys  Mon Oct 10 21:41:51 2011 (4E93588F)
fffff880`05ed1000 fffff880`05f44380   mfefirek mfefirek.sys Mon Oct 10 21:44:46 2011 (4E93593E)
fffff880`0110a000 fffff880`011a5580   mfehidk  mfehidk.sys  Mon Oct 10 21:40:22 2011 (4E935836)
fffff880`01492000 fffff880`014a2b00   mfenlfk  mfenlfk.sys  Mon Oct 10 21:41:04 2011 (4E935860)
fffff880`01ac4000 fffff880`01b07600   mfewfpk  mfewfpk.sys  Mon Oct 10 21:40:40 2011 (4E935848)
fffff880`05fef000 fffff880`05ffd000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04b32000 fffff880`04b41000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05f75000 fffff880`05f82000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00d93000 fffff880`00dad000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`06506000 fffff880`0651e000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0651e000 fffff880`0654b000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0654b000 fffff880`06599000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`06599000 fffff880`065bd000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01562000 fffff880`0156d000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f15000 fffff880`00f1f000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`02fa9000 fffff880`02fb4000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01bb0000 fffff880`01bc2000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`04b10000 fffff880`04b18000   NBSPortDriver NBSPortDriver.sys Tue May 15 22:24:00 2007 (464A24F0)
fffff880`01689000 fffff880`0177c000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0444a000 fffff880`04456000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`05b39000 fffff880`05b4c000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04456000 fffff880`04485000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04a72000 fffff880`04a87000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`01226000 fffff880`01235000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`015ad000 fffff880`015f2000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0177c000 fffff880`017dc000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0156d000 fffff880`0157e000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02f9d000 fffff880`02fa9000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03616000 fffff800`03bff000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01236000 fffff880`013d9000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01668000 fffff880`01671000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04a5a000 fffff880`04a72000   nusb3hub nusb3hub.sys Fri Apr 23 02:34:35 2010 (4BD0F92B)
fffff880`04553000 fffff880`04583000   nusb3xhc nusb3xhc.sys Fri Apr 23 02:34:36 2010 (4BD0F92C)
fffff880`0fe9c000 fffff880`0fea1000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`04a87000 fffff880`04ab4000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f225000 fffff880`0fe9c000   nvlddmkm nvlddmkm.sys Tue Nov 08 01:04:52 2011 (4EB88034)
fffff880`04b86000 fffff880`04b96000   nvoclk64 nvoclk64.sys Tue Sep 15 22:59:25 2009 (4AB00E3D)
fffff880`05ae6000 fffff880`05b39000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`01200000 fffff880`01226000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f5f000 fffff880`00f74000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f1f000 fffff880`00f52000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fe5000 fffff880`00fec000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fec000 fffff880`00ffc000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01519000 fffff880`0152a000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0684c000 fffff880`068f2000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04ba8000 fffff880`04be5000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d21000 fffff880`00d35000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04426000 fffff880`0444a000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`011de000 fffff880`011f9000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04ad5000 fffff880`04af6000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04af6000 fffff880`04b10000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02f4c000 fffff880`02f9d000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04b18000 fffff880`04b23000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`017ec000 fffff880`017f5000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017f5000 fffff880`017fe000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01559000 fffff880`01562000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01b76000 fffff880`01bb0000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05b4c000 fffff880`05b64000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`044e9000 fffff880`04553000   Rt64win7 Rt64win7.sys Wed Jan 26 13:34:03 2011 (4D4022CB)
fffff880`05c29000 fffff880`05e8c800   RTKVHD64 RTKVHD64.sys Tue Oct 05 10:58:40 2010 (4CAAF6D0)
fffff880`02f32000 fffff880`02f4c000   SCDEmu   SCDEmu.SYS   Mon Apr 12 09:52:25 2010 (4BC2DF49)
fffff880`068f2000 fffff880`068fd000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`045c3000 fffff880`045cf000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`011a6000 fffff880`011c3000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01b6c000 fffff880`01b76000   speedfan speedfan.sys Fri Mar 18 16:08:46 2011 (4D83838E)
fffff880`01b64000 fffff880`01b6c000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`05b64000 fffff880`05bfc000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06940000 fffff880`069a9000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`068fd000 fffff880`0692e000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04b41000 fffff880`04b42480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01876000 fffff880`01a7a000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`0692e000 fffff880`06940000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`015a0000 fffff880`015ad000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0157e000 fffff880`015a0000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`02f1e000 fffff880`02f32000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`02edd000 fffff880`02f1e000   truecrypt truecrypt.sys Sun Sep 05 15:23:16 2010 (4C83A7D4)
fffff960`00470000 fffff960`0047a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`02fc3000 fffff880`02fe9000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`05a5b000 fffff880`05ab0000   udfs     udfs.sys     Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`04b96000 fffff880`04ba8000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05f82000 fffff880`05f9f000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`04583000 fffff880`04584f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`0f211000 fffff880`0f222000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04a00000 fffff880`04a5a000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04493000 fffff880`044e9000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00f52000 fffff880`00f5f000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01678000 fffff880`01686000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01534000 fffff880`01559000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00dad000 fffff880`00de9000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`01b08000 fffff880`01b18000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00f74000 fffff880`00f89000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00f89000 fffff880`00fe5000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01b18000 fffff880`01b64000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0105e000 fffff880`01074000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`011c3000 fffff880`011de000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`017dc000 fffff880`017ec000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e02000 fffff880`00ea6000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ea6000 fffff880`00eb5000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`01489000 fffff880`01492000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00334000   win32k   win32k.sys   unavailable (00000000)
fffff880`00de9000 fffff880`00dfd000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`045dc000 fffff880`045e5000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f0c000 fffff880`00f15000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05ab0000 fffff880`05ad1000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0a060000 fffff880`0a0d1000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`069a9000 fffff880`069df000   mfeavfk01.sy
    Checksum:  00000000
    ImageSize:  00036000
fffff880`01850000 fffff880`0185e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0185e000 fffff880`0186a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0186a000 fffff880`01873000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0162b000 fffff880`0163e000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Thank you, I've started to install some of these drivers (it's a slow process using another computer to download and transfer), no progress so far but I did figure something out: if I run Windows in safe mode with networking my internet connection works fine. I'll update all the drivers you mentioned and let you know how it goes.
