Kyle75
Hello,
I have continued to get BSOD every few hours making work almost impossible, help would be greatly appreciated.
BugCheck D1, {fffff8800c774000, 2, 0, fffff880045d3fa0}
*** WARNING: Unable to verify timestamp for e22w7x64.sys
*** ERROR: Module load completed but symbols could not be loaded for e22w7x64.sys
Probably caused by : e22w7x64.sys ( e22w7x64+19fa0 )
Followup: MachineOwner
the...
the above dump file is blaming your Killer Network driver:
e22w7x64.sys Wed Dec 05 16:43:48 2012: Killer e2200 PCI-E Gigabit Ethernet Controller a later version is on webpage support:
http://uk.msi.com/support/mb/Z87G45_GAMING.html#down-driver&Win7 64
I also noticed this in your drivers:
CorsairLINK_HardwareMonitor.sys Sat Jul 26 14:29:37 2008: Corsair LINK Hardware Monitor Driver. Uses the WinRing0 libraries - also known to cause BSOD's. It might be worth removing if the bsod continues after replacing the above.
BiosVersion = V1.5
BiosReleaseDate = 09/22/2013
Current Bios version stands at v1.9
Post any new dump files
Edit:
I also moved your thread to the correct section.
