brkkab
I has a bsod earlier that I need help with. I've slready run the following.
sfc/ scannow
DISM.exe /Online /Cleanup-image /Scanhealth
DISM.exe /Online /Cleanup-image /Restorehealth
None of them found any issues.
For about 2 2 1/2 weeks now my pc has frequently been turning itself off.
I know nothing is overheating as I have a Corsair H-100 heatsink.
I'm attaching a msinfo32.zip and the bsod.zip files
BugCheck 139, {3, ffffd00021e0d890, ffffd00021e0d7e8, 0}
*** WARNING: Unable to verify timestamp for avc3.sys
*** ERROR: Module load completed but symbols could not be loaded for avc3.sys
Probably caused by : avc3.sys ( avc3+7d1fb )
Followup: MachineOwner
the above Bugcheck...
brkkab
Haven't bothered with Defender as it always scores low for the last 2 or so years.
The uefi is set to the defaults, except my ram which has to be clocked down to DDR3 2133 per G-Skill. It's DDR3 2400 ram.
Only turns off if I run the full scan's.
That may not be the case, though.
It's pretty much on 24/7, but I restart it between 7-10 times daily.
brkkab
In a little while I have to go to the pharmacy to pick up some medicine.I'm gonna get some alcohol pad's while I'm there and clean my fans with them either tonight or tomorrow morning.
When I get home from there I need to go to bed. I never sleep at the same times due to my diabetes and complications from it.
brkkab
***SOLVED*** Mobo was going and finally went bad last month. Just got new one and am reinstalling all software/app/games now.Probably be at it until Tues/Weds., as I've had recent medical iaaue's. 8 9.2 mm. kidney stones and 8 smaller ones between both kidneys. Had surgery Friday ( stent in each kidney) and right stones were blasted. Left one's sometime before Thanksgiving. I hope atleast.
Glad to hear you found the issue.. Hope all goes well with the new board.. :)
brkkab
Hopefully, atleast until June, 2016. Should have the parts for my new pc by then.
