Windows 7 BSOD Reference by Pointer!
Jayis
Member
Hey I have started getting this the last few weeks there doesn't seem to be any triggers it just randomly happens regardless if I'm idle browsing or anything. Any help would be much appreciated thanks!
BugCheck 18, {fffffa800f719de0, fffffa800ff543e0, 1, 500}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4165a )
Followup:     MachineOwner
both dump files were the same and point to a possibly corrupted driver although it's difficult to say what or which...
both dump files were the same and point to a possibly corrupted driver although it's difficult to say what or which driver.
I see you have the Intel extreme overclocking utility installed. If your overclocking then please stop until source of bsod is found.
This:
NTIOLib_X64.sys Mon Mar 17 10:24:03 2014: MSI Afterburner driver (known BSOD issues with Windows) Also found to be a part of MSI Live Update 5, MSI Super Charger & MSI Smart Utilities.
Please find cmd prompt, right click on it and run as admin
Type: sfc /scannow then press enter
Have you changed anything recently like new hardware/software?
You could also try running the driver verifier and see if this trips anything up into blue screening:
Post any new dump files
