BSOD within 60 seconds of running IE8
#61
Try going to Start > Run, and type sfc/ scannow
Did you uninstall the toolbars?
Hi
thanks for your advice.
1. sfc/ scannow just flashes a box very briefly which disappears. I assume thats not supposed to happen.
2. All IE toolbars have been uninstalled
3. This machine is a brand new(ish) Medion Akoya bought over ebay. It is not/never been overclocked, and its power should be enough to run i8 on a 15" monitor for more than a minute.
4. The bios has not been touched.
Latest dump attached.
thanks,Shumit
#62
092010-17986-01.dmp
BugCheck 1000008E, {c0000005, 8522293e, 993c392c, 0}
Probably caused by : fltmgr.sys ( fltmgr!FltpPerformPreCallbacks+1a0 )
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
PROCESS_NAME: taskhost.exe
FAILURE_BUCKET_ID: 0x8E_VRF_fltmgr!FltpPerformPreCallbacks+1a0
fltmgr.sys - MS Filesystem Filter Manager
Update NForce drivers if possible:
nvmf6232.sys Fri Jul 31 02:47:55 2009
nvsmu.sys Mon Jun 29 10:36:34 2009
dump_nvstor32.sys Wed Aug 05 03:27:05 2009
NVIDIA nForce driver
cmd -> chkdsk /r /f if you haven't yet,
HDDScan
092010-17986-01.dmp
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\092010-17986-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x82a3c000 PsLoadedModuleList = 0x82b84810
System Uptime: 0 days 0:00:34.774
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
0: kd> !analyze -v
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 8522293e, The address that the exception occurred at
Arg3: 993c392c, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
8522293e 8b4224          mov     eax,dword ptr [edx+24h]
TRAP_FRAME:  993c392c -- (.trap 0xffffffff993c392c)
ErrCode = 00000000
eax=00000000 ebx=87569de0 ecx=87569e28 edx=00000080 esi=8a9a2ae0 edi=8a9a2bf4
eip=8522293e esp=993c39a0 ebp=993c39f8 iopl=0         nv up ei pl nz na po nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010202
fltmgr!FltpPerformPreCallbacks+0x1a0:
8522293e 8b4224          mov     eax,dword ptr [edx+24h] ds:0023:000000a4=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
BUGCHECK_STR:  0x8E
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 852259f0 to 8522293e
STACK_TEXT:
993c39f8 852259f0 993c3a3c 99b8a508 00000000 fltmgr!FltpPerformPreCallbacks+0x1a0
993c3a10 852391fe 993c3a3c 8523cf3c 00000000 fltmgr!FltpPassThroughInternal+0x40
993c3a24 852398b7 993c3a3c 8a303a80 99b89530 fltmgr!FltpCreateInternal+0x24
993c3a68 82d6b6c3 8a303a80 8a3fd008 99bda6a0 fltmgr!FltpCreate+0x2c9
993c3a8c 82a78473 00000000 99bda6fc 8a303a80 nt!IovCallDriver+0x258
993c3aa0 82c7c6ad b68d3ec0 993c3c48 00000000 nt!IofCallDriver+0x1b
993c3b78 82c5d26b 8a2cca30 85404d20 87403b68 nt!IopParseDevice+0xed7
993c3bf4 82c832d9 00000000 993c3c48 00000040 nt!ObpLookupObjectName+0x4fa
993c3c50 82c7b62b 0018f838 87404d20 82ac4701 nt!ObOpenObjectByName+0x165
993c3ccc 82cb667e 0018f874 00100020 0018f838 nt!IopCreateFile+0x673
993c3d14 82a7f44a 0018f874 00100020 0018f838 nt!NtOpenFile+0x2a
993c3d14 76ec64f4 0018f874 00100020 0018f838 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0018f86c 00000000 00000000 00000000 00000000 0x76ec64f4
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  fltmgr!FltpPerformPreCallbacks+1a0
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: fltmgr
IMAGE_NAME:  fltmgr.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bbf11
start    end        module name
80bd4000 80bdc000   kdcom    kdcom.dll    Tue Jul 14 04:08:58 2009 (4A5BDAAA)
82a05000 82a3c000   hal      halmacpi.dll Tue Jul 14 02:11:03 2009 (4A5BBF07)
82a3c000 82e4c000   nt       ntkrpamp.exe Sat Jun 19 06:55:24 2010 (4C1C3FAC)
84e09000 84e81000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:06:41 2009 (4A5BDA21)
84e81000 84e92000   PSHED    PSHED.dll    Tue Jul 14 04:09:36 2009 (4A5BDAD0)
84e92000 84e9a000   BOOTVID  BOOTVID.dll  Tue Jul 14 04:04:34 2009 (4A5BD9A2)
84e9a000 84edc000   CLFS     CLFS.SYS     Tue Jul 14 02:11:10 2009 (4A5BBF0E)
84edc000 84f87000   CI       CI.dll       Tue Jul 14 04:09:28 2009 (4A5BDAC8)
84f87000 84ff8000   Wdf01000 Wdf01000.sys Tue Jul 14 02:11:36 2009 (4A5BBF28)
85011000 8501f000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:11:25 2009 (4A5BBF1D)
8501f000 85067000   ACPI     ACPI.sys     Tue Jul 14 02:11:11 2009 (4A5BBF0F)
85067000 85070000   WMILIB   WMILIB.SYS   Tue Jul 14 02:11:22 2009 (4A5BBF1A)
85070000 85078000   msisadrv msisadrv.sys Tue Jul 14 02:11:09 2009 (4A5BBF0D)
85078000 850a2000   pci      pci.sys      Tue Jul 14 02:11:16 2009 (4A5BBF14)
850a2000 850ad000   vdrvroot vdrvroot.sys Tue Jul 14 02:46:19 2009 (4A5BC74B)
850ad000 850be000   partmgr  partmgr.sys  Tue Jul 14 02:11:35 2009 (4A5BBF27)
850be000 850ce000   volmgr   volmgr.sys   Tue Jul 14 02:11:25 2009 (4A5BBF1D)
850ce000 85119000   volmgrx  volmgrx.sys  Tue Jul 14 02:11:41 2009 (4A5BBF2D)
85119000 85120000   pciide   pciide.sys   Tue Jul 14 02:11:19 2009 (4A5BBF17)
85120000 8512e000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:11:15 2009 (4A5BBF13)
8512e000 85144000   mountmgr mountmgr.sys Tue Jul 14 02:11:27 2009 (4A5BBF1F)
85144000 8514d000   atapi    atapi.sys    Tue Jul 14 02:11:15 2009 (4A5BBF13)
8514d000 85170000   ataport  ataport.SYS  Tue Jul 14 02:11:18 2009 (4A5BBF16)
85170000 851a7000   nvstor32 nvstor32.sys Wed Aug 05 03:27:05 2009 (4A78D1D9)
851a7000 851ee000   storport storport.sys Tue Jul 14 02:45:58 2009 (4A5BC736)
851ee000 851f7000   amdxata  amdxata.sys  Tue May 19 20:57:35 2009 (4A12F30F)
85200000 85210000   termdd   termdd.sys   Tue Jul 14 03:01:35 2009 (4A5BCADF)
85220000 85254000   fltmgr   fltmgr.sys   Tue Jul 14 02:11:13 2009 (4A5BBF11)
85254000 85265000   fileinfo fileinfo.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
85265000 85394000   Ntfs     Ntfs.sys     Tue Jul 14 02:12:05 2009 (4A5BBF45)
85394000 853bf000   msrpc    msrpc.sys    Tue Jul 14 02:11:59 2009 (4A5BBF3F)
853bf000 853d2000   ksecdd   ksecdd.sys   Tue Jul 14 02:11:56 2009 (4A5BBF3C)
853d2000 853f7000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:11:20 2009 (4A5BBF18)
85400000 85432000   fvevol   fvevol.sys   Sat Sep 26 05:24:21 2009 (4ABD7B55)
85439000 85496000   cng      cng.sys      Tue Jul 14 02:32:55 2009 (4A5BC427)
85496000 854a4000   pcw      pcw.sys      Tue Jul 14 02:11:10 2009 (4A5BBF0E)
854a4000 854ad000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:11:14 2009 (4A5BBF12)
854ad000 85564000   ndis     ndis.sys     Tue Jul 14 02:12:24 2009 (4A5BBF58)
85564000 855a2000   NETIO    NETIO.SYS    Tue Jul 14 02:12:35 2009 (4A5BBF63)
855a2000 855c7000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:04:22 2009 (4B21C4C6)
855c7000 855d7000   mup      mup.sys      Tue Jul 14 02:14:14 2009 (4A5BBFC6)
855d7000 855e8000   disk     disk.sys     Tue Jul 14 02:11:28 2009 (4A5BBF20)
85604000 8574d000   tcpip    tcpip.sys    Mon Jun 14 06:36:59 2010 (4C15A3DB)
8574d000 8577e000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:12:03 2009 (4A5BBF43)
8577e000 857bd000   volsnap  volsnap.sys  Tue Jul 14 02:11:34 2009 (4A5BBF26)
857bd000 857c5000   spldr    spldr.sys    Mon May 11 19:13:47 2009 (4A084EBB)
857c5000 857f2000   rdyboost rdyboost.sys Tue Jul 14 02:22:02 2009 (4A5BC19A)
857f2000 857fa000   hwpolicy hwpolicy.sys Tue Jul 14 02:11:01 2009 (4A5BBF05)
8b200000 8b21f000   pacer    pacer.sys    Tue Jul 14 02:53:58 2009 (4A5BC916)
8b21f000 8b22d000   netbios  netbios.sys  Tue Jul 14 02:53:54 2009 (4A5BC912)
8b22d000 8b248000   luafv    luafv.sys    Tue Jul 14 02:15:44 2009 (4A5BC020)
8b248000 8b25b000   rspndr   rspndr.sys   Tue Jul 14 02:53:20 2009 (4A5BC8F0)
8b25b000 8b268000   tcpipreg tcpipreg.sys Tue Jul 14 02:54:14 2009 (4A5BC926)
8b278000 8b297000   cdrom    cdrom.sys    Tue Jul 14 02:11:24 2009 (4A5BBF1C)
8b297000 8b2ba000   MpFilter MpFilter.sys Sat Mar 20 06:03:26 2010 (4BA4490E)
8b2ba000 8b2c1000   Null     Null.SYS     Tue Jul 14 02:11:12 2009 (4A5BBF10)
8b2c1000 8b2c8000   Beep     Beep.SYS     Tue Jul 14 02:45:00 2009 (4A5BC6FC)
8b2c8000 8b2d4000   vga      vga.sys      Tue Jul 14 02:25:50 2009 (4A5BC27E)
8b2d4000 8b2f5000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:25:49 2009 (4A5BC27D)
8b2f5000 8b302000   watchdog watchdog.sys Tue Jul 14 02:24:10 2009 (4A5BC21A)
8b302000 8b30a000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:01:40 2009 (4A5BCAE4)
8b30a000 8b312000   rdpencdd rdpencdd.sys Tue Jul 14 03:01:39 2009 (4A5BCAE3)
8b312000 8b31a000   rdprefmp rdprefmp.sys Tue Jul 14 03:01:41 2009 (4A5BCAE5)
8b31a000 8b325000   Msfs     Msfs.SYS     Tue Jul 14 02:11:26 2009 (4A5BBF1E)
8b325000 8b333000   Npfs     Npfs.SYS     Tue Jul 14 02:11:31 2009 (4A5BBF23)
8b333000 8b34a000   tdx      tdx.sys      Tue Jul 14 02:12:10 2009 (4A5BBF4A)
8b34a000 8b355000   TDI      TDI.SYS      Tue Jul 14 02:12:12 2009 (4A5BBF4C)
8b355000 8b3af000   afd      afd.sys      Tue Jul 14 02:12:34 2009 (4A5BBF62)
8b3af000 8b3e1000   netbt    netbt.sys    Tue Jul 14 02:12:18 2009 (4A5BBF52)
8b3e1000 8b3e8000   wfplwf   wfplwf.sys   Tue Jul 14 02:53:51 2009 (4A5BC90F)
8b3e8000 8b3fb000   wanarp   wanarp.sys   Tue Jul 14 02:55:02 2009 (4A5BC956)
8c000000 8c017000   rassstp  rassstp.sys  Tue Jul 14 02:54:57 2009 (4A5BC951)
8c017000 8c031000   WudfPf   WudfPf.sys   Tue Jul 14 02:50:13 2009 (4A5BC835)
8c031000 8c072000   rdbss    rdbss.sys    Tue Jul 14 02:14:26 2009 (4A5BBFD2)
8c072000 8c07c000   nsiproxy nsiproxy.sys Tue Jul 14 02:12:08 2009 (4A5BBF48)
8c07c000 8c086000   mssmbios mssmbios.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
8c086000 8c092000   discache discache.sys Tue Jul 14 02:24:04 2009 (4A5BC214)
8c092000 8c0aa000   dfsc     dfsc.sys     Tue Jul 14 02:14:16 2009 (4A5BBFC8)
8c0aa000 8c0b8000   blbdrive blbdrive.sys Tue Jul 14 02:23:04 2009 (4A5BC1D8)
8c0b8000 8c0d9000   tunnel   tunnel.sys   Tue Jul 14 02:54:03 2009 (4A5BC91B)
8c0d9000 8c0eb000   intelppm intelppm.sys Tue Jul 14 02:11:03 2009 (4A5BBF07)
8c0eb000 8c0f4000   nvsmu    nvsmu.sys    Mon Jun 29 10:36:34 2009 (4A486F02)
8c0f4000 8c0fe000   usbohci  usbohci.sys  Tue Jul 14 02:51:14 2009 (4A5BC872)
8c0fe000 8c149000   USBPORT  USBPORT.SYS  Tue Jul 14 02:51:13 2009 (4A5BC871)
8c149000 8c158000   usbehci  usbehci.sys  Sat Oct 24 06:58:55 2009 (4AE27B7F)
8c158000 8c177000   HDAudBus HDAudBus.sys Tue Jul 14 02:50:55 2009 (4A5BC85F)
8c177000 8c1bb880   nvmf6232 nvmf6232.sys Fri Jul 31 02:47:55 2009 (4A72312B)
8c1bc000 8c1d4000   raspppoe raspppoe.sys Tue Jul 14 02:54:53 2009 (4A5BC94D)
8c1d4000 8c1eb000   raspptp  raspptp.sys  Tue Jul 14 02:54:47 2009 (4A5BC947)
8c1eb000 8c1fb000   lltdio   lltdio.sys   Tue Jul 14 02:53:18 2009 (4A5BC8EE)
8ca00000 8ca0d000   mouclass mouclass.sys Tue Jul 14 02:11:15 2009 (4A5BBF13)
8ca0d000 8ca0e380   swenum   swenum.sys   Tue Jul 14 02:45:08 2009 (4A5BC704)
8ca13000 8d490dc0   nvlddmkm nvlddmkm.sys Sat Jul 10 00:15:14 2010 (4C379162)
8d491000 8d492040   nvBridge nvBridge.kmd Sat Jul 10 00:10:11 2010 (4C379033)
8d493000 8d54a000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 03:48:33 2009 (4AC54DE1)
8d54a000 8d583000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:25:25 2009 (4A5BC265)
8d583000 8d58c000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:19:16 2009 (4A5BC0F4)
8d58c000 8d599000   CompositeBus CompositeBus.sys Tue Jul 14 02:45:26 2009 (4A5BC716)
8d599000 8d5ab000   AgileVpn AgileVpn.sys Tue Jul 14 02:55:00 2009 (4A5BC954)
8d5ab000 8d5c3000   rasl2tp  rasl2tp.sys  Tue Jul 14 02:54:33 2009 (4A5BC939)
8d5c3000 8d5ce000   ndistapi ndistapi.sys Tue Jul 14 02:54:24 2009 (4A5BC930)
8d5ce000 8d5f0000   ndiswan  ndiswan.sys  Tue Jul 14 02:54:34 2009 (4A5BC93A)
8d5f0000 8d5fd000   kbdclass kbdclass.sys Tue Jul 14 02:11:15 2009 (4A5BBF13)
8dc00000 8dc0a000   Dxapi    Dxapi.sys    Tue Jul 14 02:25:25 2009 (4A5BC265)
8dc0a000 8dc15000   monitor  monitor.sys  Tue Jul 14 02:25:58 2009 (4A5BC286)
8dc1a000 8dc4e000   ks       ks.sys       Tue Jul 14 02:45:13 2009 (4A5BC709)
8dc4e000 8dc5c000   umbus    umbus.sys    Tue Jul 14 02:51:38 2009 (4A5BC88A)
8dc5c000 8dca0000   usbhub   usbhub.sys   Sat Oct 24 07:00:05 2009 (4AE27BC5)
8dca0000 8dcb1000   NDProxy  NDProxy.SYS  Tue Jul 14 02:54:27 2009 (4A5BC933)
8dcb1000 8dd01000   HdAudio  HdAudio.sys  Tue Jul 14 02:51:46 2009 (4A5BC892)
8dd01000 8dd30000   portcls  portcls.sys  Tue Jul 14 02:51:00 2009 (4A5BC864)
8dd30000 8dd49000   drmk     drmk.sys     Tue Jul 14 03:36:05 2009 (4A5BD2F5)
8dd49000 8dd54000   hidusb   hidusb.sys   Tue Jul 14 02:51:04 2009 (4A5BC868)
8dd54000 8dd67000   HIDCLASS HIDCLASS.SYS Tue Jul 14 02:51:01 2009 (4A5BC865)
8dd67000 8dd6d480   HIDPARSE HIDPARSE.SYS Tue Jul 14 02:50:59 2009 (4A5BC863)
8dd6e000 8dd6f700   USBD     USBD.SYS     Tue Jul 14 02:51:05 2009 (4A5BC869)
8dd70000 8dd7b000   mouhid   mouhid.sys   Tue Jul 14 02:45:08 2009 (4A5BC704)
8dd7b000 8dd92000   usbccgp  usbccgp.sys  Tue Jul 14 02:51:31 2009 (4A5BC883)
8dd92000 8dd9e000   kbdhid   kbdhid.sys   Tue Jul 14 02:45:09 2009 (4A5BC705)
8dd9e000 8ddab000   crashdmp crashdmp.sys Tue Jul 14 02:45:50 2009 (4A5BC72E)
8ddab000 8ddb5000   dump_diskdump dump_diskdump.sys Tue Jul 14 02:45:49 2009 (4A5BC72D)
8ddb5000 8ddec000   dump_nvstor32 dump_nvstor32.sys Wed Aug 05 03:27:05 2009 (4A78D1D9)
8ddec000 8ddfd000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:12:47 2009 (4A5BBF6F)
94ed0000 9511a000   win32k   win32k.sys   Sat Jun 19 07:06:50 2010 (4C1C425A)
95130000 95139000   TSDDD    TSDDD.dll    unavailable (00000000)
95160000 9517e000   cdd      cdd.dll      Tue Jul 14 04:04:18 2009 (4A5BD992)
98c00000 98c0a000   secdrv   secdrv.SYS   Wed Sep 13 16:18:32 2006 (45080528)
98c0a000 98c2b000   srvnet   srvnet.sys   Tue Jul 14 02:14:45 2009 (4A5BBFE5)
98c37000 98cbc000   HTTP     HTTP.sys     Tue Jul 14 02:12:53 2009 (4A5BBF75)
98cbc000 98cd5000   bowser   bowser.sys   Tue Jul 14 02:14:21 2009 (4A5BBFCD)
98cd5000 98ce7000   mpsdrv   mpsdrv.sys   Tue Jul 14 02:52:52 2009 (4A5BC8D4)
98ce7000 98d0a000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:32:02 2010 (4B88CA72)
98d0a000 98d45000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:32:21 2010 (4B88CA85)
98d45000 98d60000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:32:11 2010 (4B88CA7B)
98d60000 98df7000   peauth   peauth.sys   Tue Jul 14 03:35:44 2009 (4A5BD2E0)
9b236000 9b285000   srv2     srv2.sys     Tue Jul 14 02:14:52 2009 (4A5BBFEC)
9b285000 9b2d6000   srv      srv.sys      Tue Jul 14 02:15:10 2009 (4A5BBFFE)
9b2d6000 9b2dee00   MpNWMon  MpNWMon.sys  Sat Mar 20 06:03:24 2010 (4BA4490C)
Unloaded modules:
98d60000 98d78000   parport.sys
    Checksum:  00000000
855e8000 855f5000   crashdmp.sys
    Checksum:  00000000
855f5000 855ff000   dump_storpor
    Checksum:  00000000
8b230000 8b267000   dump_nvstor3
    Checksum:  00000000
8b267000 8b278000   dump_dumpfve
    Checksum:  00000000
#64
Hi
Here are the printscreens from cpu-z:
All nforce/nvidia drivers have been updated earlier.
I have run HDDscan - the RD-Read ran ok lasting about an hour. The Temperature monitor is running now - all looks ok. What other tests should I run with it.
the aero trouble shooter didnt find any errors.
Latest dump attached which seemed to happen after a windows update.
Thanks,Shumit
ScreenShot002.jpg ScreenShot003.jpg ScreenShot001.jpg ScreenShot005.jpg ScreenShot006.jpg ScreenShot004.jpg
#65
Replace the RAM. It's bad.
#66
wow that was quick! it comes in 2x2gb so I'll take out each one to see which one is faulty!. Thanks
#67
Hi
just wondering what was the clue to the memory considering I have run memtest86 at least a couple of times through.
thanks,S
#68
I can see all of your drivers are well and not potential bsod issues. That leaves only one possibility.
Also, all of the different types of bsod mean a hardware issue.
Before you do that, check in your BIOS for inappropriate settings for the memory...
A quick check is to simply put your memory timing on "Auto".
reghakr
#70
Sorry, the proper use of sfc /scannow should be to first go to Start > Run, and type cmd. Now type sfc /scannow.
Go to Start > Run and type eventvwr.msc and look in the System log for recent errors.
Look especially for "disk" errors that may be an indication of drive corruption.
You can double click these to read the details and copy the description to the clipboard by clicking the double-paper copy icon.
#71
Hi
Thanks,Shumit
View attachment 8119 View attachment 8120 View attachment 8121 View attachment 8122 View attachment 8123 View attachment 8124
Run memtest OVERNIGHT.
Memtest86+ - Advanced Memory Diagnostic Tool
Update nForce drivers if you haven't done so yet:
nForce chipset driver
Drivers - Download NVIDIA Drivers
092110-13026-01.dmp
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. Typically the address is just plain bad or it is pointing at freed memory
READ_ADDRESS: GetPointerFromAddress: unable to read from 82b73718
Unable to read MiSystemVaType memory at 82b53160
8a5b1380
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BIT
Loading Dump File [F:\a\Minidump\092110-13026-01.dmp]
Machine Name:
Kernel base = 0x82a0b000 PsLoadedModuleList = 0x82b53810
System Uptime: 0 days 0:08:11.320
0: kd> !analyze -v
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: 8a5b1380, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 8c25b31d, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 00000000, (reserved)
Debugging Details:
 8a5b1380
FAULTING_IP:
rdbss!RxInitializeSecurityContext+2a3
8c25b31d 8b8b78830000    mov     ecx,dword ptr [ebx+8378h]
MM_INTERNAL_CODE:  0
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0x50
PROCESS_NAME:  explorer.exe
CURRENT_IRQL:  0
TRAP_FRAME:  8249b64c -- (.trap 0xffffffff8249b64c)
ErrCode = 00000000
eax=00000000 ebx=8a5a9008 ecx=00000000 edx=00000000 esi=00000000 edi=8a5a9d00
eip=8c25b31d esp=8249b6c0 ebp=8249b714 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
rdbss!RxInitializeSecurityContext+0x2a3:
8c25b31d 8b8b78830000    mov     ecx,dword ptr [ebx+8378h] ds:0023:8a5b1380=????????
LAST_CONTROL_TRANSFER:  from 82a51638 to 82a90903
STACK_TEXT:
8249b634 82a51638 00000000 8a5b1380 00000000 nt!MmAccessFault+0x106
8249b634 8c25b31d 00000000 8a5b1380 00000000 nt!KiTrap0E+0xdc
8249b714 8c257ebe 8a5a9d00 8c254fc5 8a5a9d09 rdbss!RxInitializeSecurityContext+0x2a3
8249b7d0 8c261653 8a5a9008 82307858 8249b7fc rdbss!RxFindOrConstructVirtualNetRoot+0x91
8249b81c 8c25a800 8a5a9008 82307858 ffffd8f0 rdbss!RxCreateTreeConnect+0x109
8249b84c 8c241fb1 8a5a9008 82307858 0e6c9ddb rdbss!RxCommonCreate+0x18e
8249b8d4 8c25ce2b 8c252240 82307858 89251ab8 rdbss!RxFsdCommonDispatch+0x646
8249b904 988d5298 99602020 00307858 90679330 rdbss!RxFsdDispatch+0x1ab
8249b920 82d3a6c3 99602020 01307858 82307934 mrxsmb!MRxSmbFsdDispatch+0x9a
8249b944 82a47473 00000000 82307958 99602020 nt!IovCallDriver+0x258
8249b958 857ecbb0 00000103 822673a8 89251ab8 nt!IofCallDriver+0x1b
8249b974 857ebb52 822673a8 c0000016 82307934 mup!MupiCallUncProvider+0x10f
8249b98c 857ebf5b 822673a8 073719d3 996f0e88 mup!MupStateMachine+0x9b
8249b9d8 82d3a6c3 8a4c5720 82307858 82307858 mup!MupCreate+0x109
8249b9fc 82a47473 00000000 89251ab8 8a4c5720 nt!IovCallDriver+0x258
8249ba10 85281883 8a4c50b0 997c5d68 82307858 nt!IofCallDriver+0x1b
8249ba50 82d3a6c3 8a4c50b0 8a4c6008 89251ab8 fltmgr!FltpCreate+0x295
8249ba74 82a47473 00000000 89251b14 8a4c50b0 nt!IovCallDriver+0x258
8249ba88 82c4b6ad adf47d25 8249bc30 00000000 nt!IofCallDriver+0x1b
8249bb60 82c2c26b 8a4c5720 85604d20 8a509d20 nt!IopParseDevice+0xed7
8249bbdc 82c522d9 00000000 8249bc30 00000040 nt!ObpLookupObjectName+0x4fa
8249bc38 82c4a62b 0612f120 87604d20 82279401 nt!ObOpenObjectByName+0x165
8249bcb4 82c55f42 0612f168 c0100000 0612f120 nt!IopCreateFile+0x673
8249bd00 82a4e44a 0612f168 c0100000 0612f120 nt!NtCreateFile+0x34
8249bd00 77a164f4 0612f168 c0100000 0612f120 nt!KiFastCallEntry+0x12a
0612f1a0 00000000 00000000 00000000 00000000 0x77a164f4
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !rdbss
    8c25b320 - rdbss!RxInitializeSecurityContext+2a6
    [ 03:83 ]
1 error : !rdbss (8c25b320)
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  ONE_BIT
Followup: memory_corruption
80bd0000 80bd8000   kdcom    kdcom.dll    Tue Jul 14 04:08:58 2009 (4A5BDAAA)
82a0b000 82e1b000   nt       ntkrpamp.exe Sat Jun 19 06:55:24 2010 (4C1C3FAC)
82e1b000 82e52000   hal      halmacpi.dll Tue Jul 14 02:11:03 2009 (4A5BBF07)
84e20000 84e98000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:06:41 2009 (4A5BDA21)
84e98000 84ea9000   PSHED    PSHED.dll    Tue Jul 14 04:09:36 2009 (4A5BDAD0)
84ea9000 84eb1000   BOOTVID  BOOTVID.dll  Tue Jul 14 04:04:34 2009 (4A5BD9A2)
84eb1000 84ef3000   CLFS     CLFS.SYS     Tue Jul 14 02:11:10 2009 (4A5BBF0E)
84ef3000 84f9e000   CI       CI.dll       Tue Jul 14 04:09:28 2009 (4A5BDAC8)
84f9e000 84fd5000   nvstor32 nvstor32.sys Wed Aug 05 03:27:05 2009 (4A78D1D9)
84fd5000 85000000   msrpc    msrpc.sys    Tue Jul 14 02:11:59 2009 (4A5BBF3F)
8500d000 8507e000   Wdf01000 Wdf01000.sys Tue Jul 14 02:11:36 2009 (4A5BBF28)
8507e000 8508c000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:11:25 2009 (4A5BBF1D)
8508c000 850d4000   ACPI     ACPI.sys     Tue Jul 14 02:11:11 2009 (4A5BBF0F)
850d4000 850dd000   WMILIB   WMILIB.SYS   Tue Jul 14 02:11:22 2009 (4A5BBF1A)
850dd000 850e5000   msisadrv msisadrv.sys Tue Jul 14 02:11:09 2009 (4A5BBF0D)
850e5000 8510f000   pci      pci.sys      Tue Jul 14 02:11:16 2009 (4A5BBF14)
8510f000 8511a000   vdrvroot vdrvroot.sys Tue Jul 14 02:46:19 2009 (4A5BC74B)
8511a000 8512b000   partmgr  partmgr.sys  Tue Jul 14 02:11:35 2009 (4A5BBF27)
8512b000 8513b000   volmgr   volmgr.sys   Tue Jul 14 02:11:25 2009 (4A5BBF1D)
8513b000 85186000   volmgrx  volmgrx.sys  Tue Jul 14 02:11:41 2009 (4A5BBF2D)
85186000 8518d000   pciide   pciide.sys   Tue Jul 14 02:11:19 2009 (4A5BBF17)
8518d000 8519b000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:11:15 2009 (4A5BBF13)
8519b000 851b1000   mountmgr mountmgr.sys Tue Jul 14 02:11:27 2009 (4A5BBF1F)
851b1000 851ba000   atapi    atapi.sys    Tue Jul 14 02:11:15 2009 (4A5BBF13)
851ba000 851dd000   ataport  ataport.SYS  Tue Jul 14 02:11:18 2009 (4A5BBF16)
851dd000 851fc000   pacer    pacer.sys    Tue Jul 14 02:53:58 2009 (4A5BC916)
85200000 85213000   wanarp   wanarp.sys   Tue Jul 14 02:55:02 2009 (4A5BC956)
85218000 8525f000   storport storport.sys Tue Jul 14 02:45:58 2009 (4A5BC736)
8525f000 85268000   amdxata  amdxata.sys  Tue May 19 20:57:35 2009 (4A12F30F)
85268000 8529c000   fltmgr   fltmgr.sys   Tue Jul 14 02:11:13 2009 (4A5BBF11)
8529c000 852ad000   fileinfo fileinfo.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
852ad000 853dc000   Ntfs     Ntfs.sys     Tue Jul 14 02:12:05 2009 (4A5BBF45)
853dc000 853ef000   ksecdd   ksecdd.sys   Tue Jul 14 02:11:56 2009 (4A5BBF3C)
853ef000 853ff000   termdd   termdd.sys   Tue Jul 14 03:01:35 2009 (4A5BCADF)
8543d000 8549a000   cng      cng.sys      Tue Jul 14 02:32:55 2009 (4A5BC427)
8549a000 854a8000   pcw      pcw.sys      Tue Jul 14 02:11:10 2009 (4A5BBF0E)
854a8000 854b1000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:11:14 2009 (4A5BBF12)
854b1000 85568000   ndis     ndis.sys     Tue Jul 14 02:12:24 2009 (4A5BBF58)
85568000 855a6000   NETIO    NETIO.SYS    Tue Jul 14 02:12:35 2009 (4A5BBF63)
855a6000 855cb000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:04:22 2009 (4B21C4C6)
855cb000 855f8000   rdyboost rdyboost.sys Tue Jul 14 02:22:02 2009 (4A5BC19A)
85600000 85611000   disk     disk.sys     Tue Jul 14 02:11:28 2009 (4A5BBF20)
85611000 8561f000   netbios  netbios.sys  Tue Jul 14 02:53:54 2009 (4A5BC912)
85625000 8576e000   tcpip    tcpip.sys    Mon Jun 14 06:36:59 2010 (4C15A3DB)
8576e000 8579f000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:12:03 2009 (4A5BBF43)
8579f000 857de000   volsnap  volsnap.sys  Tue Jul 14 02:11:34 2009 (4A5BBF26)
857de000 857e6000   spldr    spldr.sys    Mon May 11 19:13:47 2009 (4A084EBB)
857e6000 857f6000   mup      mup.sys      Tue Jul 14 02:14:14 2009 (4A5BBFC6)
857f6000 857fe000   hwpolicy hwpolicy.sys Tue Jul 14 02:11:01 2009 (4A5BBF05)
85800000 85832000   netbt    netbt.sys    Tue Jul 14 02:12:18 2009 (4A5BBF52)
85832000 85839000   wfplwf   wfplwf.sys   Tue Jul 14 02:53:51 2009 (4A5BC90F)
8583e000 85863000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:11:20 2009 (4A5BBF18)
85863000 8587d000   WudfPf   WudfPf.sys   Tue Jul 14 02:50:13 2009 (4A5BC835)
8587d000 8588d000   lltdio   lltdio.sys   Tue Jul 14 02:53:18 2009 (4A5BC8EE)
8588d000 858a0000   rspndr   rspndr.sys   Tue Jul 14 02:53:20 2009 (4A5BC8F0)
858a0000 858c1000   srvnet   srvnet.sys   Tue Jul 14 02:14:45 2009 (4A5BBFE5)
858c2000 858e1000   cdrom    cdrom.sys    Tue Jul 14 02:11:24 2009 (4A5BBF1C)
858e1000 85904000   MpFilter MpFilter.sys Sat Mar 20 06:03:26 2010 (4BA4490E)
85904000 8590b000   Null     Null.SYS     Tue Jul 14 02:11:12 2009 (4A5BBF10)
8590b000 85912000   Beep     Beep.SYS     Tue Jul 14 02:45:00 2009 (4A5BC6FC)
85912000 8591e000   vga      vga.sys      Tue Jul 14 02:25:50 2009 (4A5BC27E)
8591e000 8593f000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:25:49 2009 (4A5BC27D)
8593f000 8594c000   watchdog watchdog.sys Tue Jul 14 02:24:10 2009 (4A5BC21A)
8594c000 85954000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:01:40 2009 (4A5BCAE4)
85954000 8595c000   rdpencdd rdpencdd.sys Tue Jul 14 03:01:39 2009 (4A5BCAE3)
8595c000 85964000   rdprefmp rdprefmp.sys Tue Jul 14 03:01:41 2009 (4A5BCAE5)
85964000 8596f000   Msfs     Msfs.SYS     Tue Jul 14 02:11:26 2009 (4A5BBF1E)
8596f000 8597d000   Npfs     Npfs.SYS     Tue Jul 14 02:11:31 2009 (4A5BBF23)
8597d000 85994000   tdx      tdx.sys      Tue Jul 14 02:12:10 2009 (4A5BBF4A)
85994000 8599f000   TDI      TDI.SYS      Tue Jul 14 02:12:12 2009 (4A5BBF4C)
8599f000 859f9000   afd      afd.sys      Tue Jul 14 02:12:34 2009 (4A5BBF62)
8c200000 8c20d000   kbdclass kbdclass.sys Tue Jul 14 02:11:15 2009 (4A5BBF13)
8c20d000 8c21a000   mouclass mouclass.sys Tue Jul 14 02:11:15 2009 (4A5BBF13)
8c21a000 8c235000   luafv    luafv.sys    Tue Jul 14 02:15:44 2009 (4A5BC020)
8c23f000 8c280000   rdbss    rdbss.sys    Tue Jul 14 02:14:26 2009 (4A5BBFD2)
8c280000 8c28a000   nsiproxy nsiproxy.sys Tue Jul 14 02:12:08 2009 (4A5BBF48)
8c28a000 8c294000   mssmbios mssmbios.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
8c294000 8c2a0000   discache discache.sys Tue Jul 14 02:24:04 2009 (4A5BC214)
8c2a0000 8c2b8000   dfsc     dfsc.sys     Tue Jul 14 02:14:16 2009 (4A5BBFC8)
8c2b8000 8c2c6000   blbdrive blbdrive.sys Tue Jul 14 02:23:04 2009 (4A5BC1D8)
8c2c6000 8c2e7000   tunnel   tunnel.sys   Tue Jul 14 02:54:03 2009 (4A5BC91B)
8c2e7000 8c2f9000   intelppm intelppm.sys Tue Jul 14 02:11:03 2009 (4A5BBF07)
8c2f9000 8c302000   nvsmu    nvsmu.sys    Mon Jun 29 10:36:34 2009 (4A486F02)
8c302000 8c30c000   usbohci  usbohci.sys  Tue Jul 14 02:51:14 2009 (4A5BC872)
8c30c000 8c357000   USBPORT  USBPORT.SYS  Tue Jul 14 02:51:13 2009 (4A5BC871)
8c357000 8c366000   usbehci  usbehci.sys  Sat Oct 24 06:58:55 2009 (4AE27B7F)
8c366000 8c385000   HDAudBus HDAudBus.sys Tue Jul 14 02:50:55 2009 (4A5BC85F)
8c385000 8c3c9880   nvmf6232 nvmf6232.sys Fri Jul 31 02:47:55 2009 (4A72312B)
8c3ca000 8c3e1000   raspptp  raspptp.sys  Tue Jul 14 02:54:47 2009 (4A5BC947)
8c3e1000 8c3f8000   rassstp  rassstp.sys  Tue Jul 14 02:54:57 2009 (4A5BC951)
8da00000 8da22000   ndiswan  ndiswan.sys  Tue Jul 14 02:54:34 2009 (4A5BC93A)
8da22000 8da3a000   raspppoe raspppoe.sys Tue Jul 14 02:54:53 2009 (4A5BC94D)
8da3a000 8da3b380   swenum   swenum.sys   Tue Jul 14 02:45:08 2009 (4A5BC704)
8da3e000 8e4bbdc0   nvlddmkm nvlddmkm.sys Sat Jul 10 00:15:14 2010 (4C379162)
8e4bc000 8e4bd040   nvBridge nvBridge.kmd Sat Jul 10 00:10:11 2010 (4C379033)
8e4be000 8e575000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 03:48:33 2009 (4AC54DE1)
8e575000 8e5ae000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:25:25 2009 (4A5BC265)
8e5ae000 8e5b7000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:19:16 2009 (4A5BC0F4)
8e5b7000 8e5c4000   CompositeBus CompositeBus.sys Tue Jul 14 02:45:26 2009 (4A5BC716)
8e5c4000 8e5d6000   AgileVpn AgileVpn.sys Tue Jul 14 02:55:00 2009 (4A5BC954)
8e5d6000 8e5ee000   rasl2tp  rasl2tp.sys  Tue Jul 14 02:54:33 2009 (4A5BC939)
8e5ee000 8e5f9000   ndistapi ndistapi.sys Tue Jul 14 02:54:24 2009 (4A5BC930)
92200000 92217000   usbccgp  usbccgp.sys  Tue Jul 14 02:51:31 2009 (4A5BC883)
92217000 92223000   kbdhid   kbdhid.sys   Tue Jul 14 02:45:09 2009 (4A5BC705)
92227000 9225b000   ks       ks.sys       Tue Jul 14 02:45:13 2009 (4A5BC709)
9225b000 92269000   umbus    umbus.sys    Tue Jul 14 02:51:38 2009 (4A5BC88A)
92269000 922ad000   usbhub   usbhub.sys   Sat Oct 24 07:00:05 2009 (4AE27BC5)
922ad000 922be000   NDProxy  NDProxy.SYS  Tue Jul 14 02:54:27 2009 (4A5BC933)
922be000 9230e000   HdAudio  HdAudio.sys  Tue Jul 14 02:51:46 2009 (4A5BC892)
9230e000 9233d000   portcls  portcls.sys  Tue Jul 14 02:51:00 2009 (4A5BC864)
9233d000 92356000   drmk     drmk.sys     Tue Jul 14 03:36:05 2009 (4A5BD2F5)
92356000 92363000   crashdmp crashdmp.sys Tue Jul 14 02:45:50 2009 (4A5BC72E)
92363000 9236d000   dump_diskdump dump_diskdump.sys Tue Jul 14 02:45:49 2009 (4A5BC72D)
9236d000 923a4000   dump_nvstor32 dump_nvstor32.sys Wed Aug 05 03:27:05 2009 (4A78D1D9)
923a4000 923b5000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:12:47 2009 (4A5BBF6F)
923b5000 923bf000   Dxapi    Dxapi.sys    Tue Jul 14 02:25:25 2009 (4A5BC265)
923bf000 923ca000   hidusb   hidusb.sys   Tue Jul 14 02:51:04 2009 (4A5BC868)
923ca000 923dd000   HIDCLASS HIDCLASS.SYS Tue Jul 14 02:51:01 2009 (4A5BC865)
923dd000 923e3480   HIDPARSE HIDPARSE.SYS Tue Jul 14 02:50:59 2009 (4A5BC863)
923e4000 923e5700   USBD     USBD.SYS     Tue Jul 14 02:51:05 2009 (4A5BC869)
923e6000 923f1000   mouhid   mouhid.sys   Tue Jul 14 02:45:08 2009 (4A5BC704)
923f1000 923fc000   monitor  monitor.sys  Tue Jul 14 02:25:58 2009 (4A5BC286)
95420000 9566a000   win32k   win32k.sys   Sat Jun 19 07:06:50 2010 (4C1C425A)
95680000 95689000   TSDDD    TSDDD.dll    unavailable (00000000)
956b0000 956ce000   cdd      cdd.dll      Tue Jul 14 04:04:18 2009 (4A5BD992)
9880f000 98894000   HTTP     HTTP.sys     Tue Jul 14 02:12:53 2009 (4A5BBF75)
98894000 988ad000   bowser   bowser.sys   Tue Jul 14 02:14:21 2009 (4A5BBFCD)
988ad000 988bf000   mpsdrv   mpsdrv.sys   Tue Jul 14 02:52:52 2009 (4A5BC8D4)
988bf000 988e2000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:32:02 2010 (4B88CA72)
988e2000 9891d000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:32:21 2010 (4B88CA85)
9891d000 98938000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:32:11 2010 (4B88CA7B)
98950000 989e7000   peauth   peauth.sys   Tue Jul 14 03:35:44 2009 (4A5BD2E0)
989e7000 989f1000   secdrv   secdrv.SYS   Wed Sep 13 16:18:32 2006 (45080528)
989f1000 989fe000   tcpipreg tcpipreg.sys Tue Jul 14 02:54:14 2009 (4A5BC926)
99e05000 99e54000   srv2     srv2.sys     Tue Jul 14 02:14:52 2009 (4A5BBFEC)
99e54000 99ea5000   srv      srv.sys      Tue Jul 14 02:15:10 2009 (4A5BBFFE)
99ea5000 99eade00   MpNWMon  MpNWMon.sys  Sat Mar 20 06:03:24 2010 (4BA4490C)
Unloaded modules:
99eae000 99f18000   spsys.sys
    Checksum:  00000000
98938000 98950000   parport.sys
    Checksum:  00000000
85863000 85870000   crashdmp.sys
    Checksum:  00000000
85870000 8587a000   dump_storpor
    Checksum:  00000000
8587a000 858b1000   dump_nvstor3
    Checksum:  00000000
858b1000 858c2000   dump_dumpfve
    Checksum:  00000000
#72
Below are just the critical and the errors I got. There were a few hundred warnings as well but no 'disk' errors. Not sure which ones to show you details of but let me know.
As to getting to the bios - Im having problems - F11 takes me to recovery, F8 takes me to the boot manager...
I also ran the windows memory diagnostic tool which seemed to run ok although I am not sure where it keeps the logs.
Critical 07/09/2010 08:37:07 Kernel-Power 41 (63)
Critical 05/09/2010 23:03:43 Kernel-Power 41 (63)
Critical 04/09/2010 16:32:45 Kernel-Power 41 (63)
Critical 08/09/2010 15:35:26 Kernel-Power 41 (63)
Critical 08/09/2010 17:44:24 Kernel-Power 41 (63)
Critical 06/09/2010 14:20:57 Kernel-Power 41 (63)
Critical 05/09/2010 18:19:00 Kernel-Power 41 (63)
Critical 06/09/2010 00:06:52 Kernel-Power 41 (63)
Critical 04/09/2010 19:00:16 Kernel-Power 41 (63)
Critical 04/09/2010 17:39:04 Kernel-Power 41 (63)
Critical 04/09/2010 19:56:11 Kernel-Power 41 (63)
Critical 20/09/2010 16:50:36 Kernel-Power 41 (63)
Critical 04/09/2010 19:16:38 Kernel-Power 41 (63)
Critical 16/09/2010 09:20:59 Kernel-Power 41 (63)
Critical 16/09/2010 14:39:48 Kernel-Power 41 (63)
Critical 06/09/2010 10:18:48 Kernel-Power 41 (63)
Critical 05/09/2010 21:06:30 Kernel-Power 41 (63)
Critical 06/09/2010 23:10:13 Kernel-Power 41 (63)
Critical 05/09/2010 21:41:46 Kernel-Power 41 (63)
Critical 05/09/2010 19:58:36 Kernel-Power 41 (63)
Critical 06/09/2010 22:03:01 Kernel-Power 41 (63)
Critical 08/09/2010 16:10:32 Kernel-Power 41 (63)
Critical 05/09/2010 22:27:03 Kernel-Power 41 (63)
Critical 06/09/2010 19:10:10 Kernel-Power 41 (63)
Critical 04/09/2010 16:34:42 Kernel-Power 41 (63)
Critical 05/09/2010 22:50:09 Kernel-Power 41 (63)
Critical 07/09/2010 18:00:54 Kernel-Power 41 (63)
Critical 05/09/2010 13:03:22 Kernel-Power 41 (63)
Critical 05/09/2010 12:28:55 Kernel-Power 41 (63)
Critical 08/09/2010 08:43:27 Kernel-Power 41 (63)
Critical 08/09/2010 16:20:30 Kernel-Power 41 (63)
Critical 20/09/2010 16:09:03 Kernel-Power 41 (63)
Critical 06/09/2010 19:13:15 Kernel-Power 41 (63)
Critical 05/09/2010 13:19:18 Kernel-Power 41 (63)
Critical 05/09/2010 23:26:19 Kernel-Power 41 (63)
Critical 16/09/2010 09:43:07 Kernel-Power 41 (63)
Critical 05/09/2010 11:53:13 Kernel-Power 41 (63)
Critical 08/09/2010 17:00:39 Kernel-Power 41 (63)
Critical 08/09/2010 09:16:37 Kernel-Power 41 (63)
Critical 05/09/2010 20:25:36 Kernel-Power 41 (63)
Critical 06/09/2010 15:34:52 Kernel-Power 41 (63)
Critical 21/09/2010 12:01:35 Kernel-Power 41 (63)
Critical 08/09/2010 16:06:47 Kernel-Power 41 (63)
Critical 06/09/2010 19:22:20 Kernel-Power 41 (63)
Critical 06/09/2010 16:12:47 Kernel-Power 41 (63)
Critical 07/09/2010 08:49:30 Kernel-Power 41 (63)
Critical 08/09/2010 18:38:32 Kernel-Power 41 (63)
Critical 07/09/2010 19:25:47 Kernel-Power 41 (63)
Critical 08/09/2010 16:01:33 Kernel-Power 41 (63)
Critical 16/09/2010 17:08:13 Kernel-Power 41 (63)
Critical 07/09/2010 16:31:55 Kernel-Power 41 (63)
Critical 04/09/2010 16:24:09 Kernel-Power 41 (63)
Critical 08/09/2010 21:34:48 Kernel-Power 41 (63)
Critical 06/09/2010 16:16:29 Kernel-Power 41 (63)
Critical 04/09/2010 19:03:44 Kernel-Power 41 (63)
Critical 04/09/2010 16:07:19 Kernel-Power 41 (63)
Critical 04/09/2010 16:27:13 Kernel-Power 41 (63)
Critical 08/09/2010 09:23:44 Kernel-Power 41 (63)
Critical 08/09/2010 18:06:57 Kernel-Power 41 (63)
Critical 07/09/2010 17:52:48 Kernel-Power 41 (63)
Critical 16/09/2010 11:49:22 Kernel-Power 41 (63)
Error 06/09/2010 19:15:32 Service Control Manager 7001 None
Error 06/09/2010 19:10:53 Service Control Manager 7031 None
Error 04/09/2010 16:41:25 Service Control Manager 7031 None
Error 16/09/2010 11:49:35 DNS Client Events 1012 None
Error 16/09/2010 11:49:37 DNS Client Events 1012 None
Error 05/09/2010 18:19:06 Microsoft Antimalware 2004 None
Error 16/09/2010 11:49:29 EventLog 6008 None
Error 05/09/2010 18:19:08 BugCheck 1001 None
Error 06/09/2010 19:15:31 EventLog 6008 None
Error 06/09/2010 19:13:43 DistributedCOM 10005 None
Error 05/09/2010 23:00:06 Microsoft Antimalware 2001 None
Error 06/09/2010 19:13:28 Microsoft Antimalware 2004 None
Error 06/09/2010 19:13:23 EventLog 6008 None
Error 16/09/2010 11:49:31 BugCheck 1001 None
Error 06/09/2010 09:50:46 Service Control Manager 7016 None
Error 05/09/2010 18:19:04 EventLog 6008 None
Error 16/09/2010 14:39:57 Service Control Manager 7001 None
Error 06/09/2010 10:00:15 Service Control Manager 7031 None
Error 06/09/2010 10:00:15 Microsoft Antimalware 3002 None
Error 05/09/2010 22:55:55 Service Control Manager 7001 None
Error 16/09/2010 14:40:01 DistributedCOM 10005 None
Error 05/09/2010 22:55:45 Service Control Manager 7001 None
Error 16/09/2010 14:40:06 DistributedCOM 10005 None
Error 16/09/2010 14:40:07 DistributedCOM 10005 None
Error 16/09/2010 14:39:58 Service Control Manager 7026 None
Error 16/09/2010 12:56:53 Kernel-General 5 None
Error 06/09/2010 19:10:21 BugCheck 1001 None
Error 06/09/2010 19:10:21 EventLog 6008 None
Error 06/09/2010 09:54:53 Microsoft Antimalware 3002 None
Error 06/09/2010 09:54:53 Microsoft Antimalware 5008 None
Error 16/09/2010 11:49:44 DNS Client Events 1012 None
Error 08/09/2010 09:48:15 Microsoft Antimalware 2004 None
Error 16/09/2010 12:53:28 Kernel-General 5 None
Error 16/09/2010 12:51:01 Kernel-General 5 None
Error 05/09/2010 22:56:30 Microsoft Antimalware 2001 None
Error 06/09/2010 09:58:59 Service Control Manager 7031 None
Error 05/09/2010 22:56:30 DistributedCOM 10005 None
Error 06/09/2010 10:00:15 Microsoft Antimalware 5008 None
Error 06/09/2010 09:56:15 Service Control Manager 7011 None
Error 04/09/2010 16:40:54 EventLog 6008 None
Error 06/09/2010 09:57:44 Service Control Manager 7011 None
Error 16/09/2010 14:39:57 EventLog 6008 None
Error 06/09/2010 09:58:57 Microsoft Antimalware 3002 None
Error 06/09/2010 09:46:59 Service Control Manager 7016 None
Error 16/09/2010 09:29:24 DNS Client Events 1012 None
Error 16/09/2010 09:29:32 DNS Client Events 1012 None
Error 05/09/2010 23:03:58 BugCheck 1001 None
Error 16/09/2010 09:29:33 DNS Client Events 1012 None
Error 06/09/2010 09:44:01 Microsoft Antimalware 2001 None
Error 04/09/2010 19:03:53 BugCheck 1001 None
Error 16/09/2010 09:29:22 DNS Client Events 1012 None
Error 04/09/2010 19:03:50 EventLog 6008 None
Error 16/09/2010 09:30:49 DistributedCOM 10010 None
Error 04/09/2010 19:00:21 EventLog 6008 None
Error 16/09/2010 09:32:05 DNS Client Events 1012 None
Error 16/09/2010 09:32:15 DNS Client Events 1012 None
Error 16/09/2010 09:32:19 DNS Client Events 1012 None
Error 16/09/2010 09:32:18 DNS Client Events 1012 None
Error 16/09/2010 09:32:02 EventLog 6008 None
Error 16/09/2010 09:30:49 Microsoft Antimalware 2001 None
Error 06/09/2010 19:26:17 Service Control Manager 7016 None
Error 04/09/2010 19:00:23 BugCheck 1001 None
Error 06/09/2010 09:43:22 WindowsUpdateClient 20 Windows Update Agent
Error 04/09/2010 19:08:34 EventLog 6008 None
Error 04/09/2010 19:06:06 Service Control Manager 7001 None
Error 06/09/2010 20:56:00 Kernel-General 5 None
Error 06/09/2010 20:56:34 Kernel-General 5 None
Error 16/09/2010 09:25:51 WindowsUpdateClient 20 Windows Update Agent
Error 06/09/2010 09:42:09 Service Control Manager 7000 None
Error 06/09/2010 09:42:09 Service Control Manager 7009 None
Error 04/09/2010 19:04:17 Service Control Manager 7001 None
Error 04/09/2010 19:04:05 DistributedCOM 10005 None
Error 04/09/2010 19:04:07 Service Control Manager 7001 None
Error 04/09/2010 19:03:59 DistributedCOM 10005 None
Error 04/09/2010 19:03:57 Service Control Manager 7026 None
Error 04/09/2010 19:04:12 Service Control Manager 7001 None
Error 04/09/2010 19:04:11 DistributedCOM 10005 None
Error 06/09/2010 09:50:34 Microsoft Antimalware 2001 None
Error 04/09/2010 17:39:19 EventLog 6008 None
Error 06/09/2010 09:50:25 Microsoft Antimalware 2001 None
Error 06/09/2010 09:50:27 Service Control Manager 7030 None
Error 06/09/2010 09:50:31 Service Control Manager 7030 None
Error 06/09/2010 09:50:29 Microsoft Antimalware 2001 None
Error 16/09/2010 09:43:20 DNS Client Events 1012 None
Error 06/09/2010 19:16:32 Microsoft Antimalware 2001 None
Error 06/09/2010 09:50:45 WindowsUpdateClient 20 Windows Update Agent
Error 16/09/2010 09:43:24 DNS Client Events 1012 None
Error 16/09/2010 09:43:29 DNS Client Events 1012 None
Error 06/09/2010 19:15:32 Service Control Manager 7026 None
Error 07/09/2010 09:05:46 Service Control Manager 7001 None
Error 07/09/2010 09:05:49 Service Control Manager 7001 None
Error 07/09/2010 09:05:38 DistributedCOM 10005 None
Error 07/09/2010 09:05:36 Service Control Manager 7026 None
Error 07/09/2010 09:05:43 DistributedCOM 10005 None
Error 07/09/2010 09:05:46 DistributedCOM 10005 None
Error 07/09/2010 09:07:52 Service Control Manager 7001 None
Error 16/09/2010 09:43:15 EventLog 6008 None
Error 06/09/2010 09:50:25 Microsoft Antimalware 2003 None
Error 16/09/2010 09:43:16 BugCheck 1001 None
Error 07/09/2010 09:05:59 Service Control Manager 7001 None
Error 16/09/2010 22:00:36 WindowsUpdateClient 20 Windows Update Agent
Error 05/09/2010 19:58:42 EventLog 6008 None
Error 05/09/2010 22:50:14 EventLog 6008 None
Error 05/09/2010 22:45:38 Service Control Manager 7001 None
Error 05/09/2010 22:46:03 DistributedCOM 10010 None
Error 04/09/2010 16:34:48 EventLog 6008 None
Error 04/09/2010 16:34:51 Service Control Manager 7001 None
Error 05/09/2010 18:50:39 Kernel-General 5 None
Error 16/09/2010 22:00:09 WindowsUpdateClient 20 Windows Update Agent
Error 04/09/2010 16:34:50 BugCheck 1001 None
Error 05/09/2010 22:45:34 DistributedCOM 10005 None
Error 20/09/2010 16:09:18 DistributedCOM 10005 None
Error 05/09/2010 22:45:27 DistributedCOM 10005 None
Error 05/09/2010 22:45:33 DistributedCOM 10005 None
Error 20/09/2010 16:09:16 BugCheck 1001 None
Error 05/09/2010 22:45:36 Service Control Manager 7001 None
Error 06/09/2010 14:21:25 EventLog 6008 None
Error 05/09/2010 22:45:35 Service Control Manager 7001 None
Error 04/09/2010 16:35:11 DistributedCOM 10005 None
Error 04/09/2010 16:35:10 DistributedCOM 10005 None
Error 04/09/2010 16:35:11 Service Control Manager 7001 None
Error 16/09/2010 17:08:34 DNS Client Events 1012 None
Error 04/09/2010 16:35:12 Service Control Manager 7001 None
Error 04/09/2010 16:34:53 Service Control Manager 7026 None
Error 04/09/2010 16:35:00 DistributedCOM 10005 None
Error 05/09/2010 18:48:33 Kernel-General 5 None
Error 05/09/2010 22:45:25 Microsoft Antimalware 2004 None
Error 06/09/2010 14:22:00 Service Control Manager 7034 None
Error 20/09/2010 16:10:49 DNS Client Events 1012 None
Error 07/09/2010 09:27:00 EventLog 6008 None
Error 20/09/2010 16:10:59 DNS Client Events 1012 None
Error 05/09/2010 20:25:40 EventLog 6008 None
Error 06/09/2010 14:21:43 Service Control Manager 7031 None
Error 06/09/2010 16:14:45 Microsoft Antimalware 2003 None
Error 06/09/2010 16:14:45 Microsoft Antimalware 2001 None
Error 04/09/2010 16:27:20 BugCheck 1001 None
Error 05/09/2010 22:44:32 Service Control Manager 7016 None
Error 04/09/2010 16:27:18 EventLog 6008 None
Error 06/09/2010 14:26:23 Service Control Manager 7016 None
Error 04/09/2010 16:24:19 EventLog 6008 None
Error 06/09/2010 16:12:58 Microsoft Antimalware 2004 None
Error 05/09/2010 22:40:48 Service Control Manager 7016 None
Error 07/09/2010 16:32:02 EventLog 6008 None
Error 20/09/2010 16:13:18 WindowsUpdateClient 20 Windows Update Agent
Error 08/09/2010 09:16:46 BugCheck 1001 None
Error 05/09/2010 20:25:44 BugCheck 1001 None
Error 08/09/2010 09:16:46 EventLog 6008 None
Error 20/09/2010 16:13:18 Microsoft Antimalware 2001 None
Error 20/09/2010 16:09:26 Service Control Manager 7001 None
Error 20/09/2010 16:09:25 DNS Client Events 1012 None
Error 20/09/2010 16:09:27 Service Control Manager 7001 None
Error 20/09/2010 16:09:26 DistributedCOM 10005 None
Error 20/09/2010 16:09:17 Service Control Manager 7026 None
Error 05/09/2010 22:45:22 Service Control Manager 7026 None
Error 20/09/2010 16:09:24 DistributedCOM 10005 None
Error 20/09/2010 16:09:25 DistributedCOM 10005 None
Error 20/09/2010 16:09:24 Microsoft Antimalware 2004 None
Error 06/09/2010 16:16:37 EventLog 6008 None
Error 06/09/2010 16:16:41 BugCheck 1001 None
Error 06/09/2010 14:21:28 Service Control Manager 7031 None
Error 06/09/2010 16:15:01 Microsoft Antimalware 2001 None
Error 08/09/2010 09:23:52 EventLog 6008 None
Error 20/09/2010 16:09:36 Service Control Manager 7001 None
Error 08/09/2010 09:23:54 BugCheck 1001 None
Error 20/09/2010 16:09:49 Service Control Manager 7001 None
Error 06/09/2010 17:28:00 Kernel-General 5 None
Error 06/09/2010 17:28:55 Kernel-General 5 None
Error 06/09/2010 17:27:08 Kernel-General 5 None
Error 06/09/2010 17:26:16 Kernel-General 5 None
Error 06/09/2010 17:26:28 Kernel-General 5 None
Error 06/09/2010 17:29:50 Kernel-General 5 None
Error 06/09/2010 17:33:32 Kernel-General 5 None
Error 06/09/2010 10:18:55 EventLog 6008 None
Error 06/09/2010 17:32:35 Kernel-General 5 None
Error 06/09/2010 17:30:44 Kernel-General 5 None
Error 06/09/2010 17:31:42 Kernel-General 5 None
Error 05/09/2010 18:22:32 Microsoft Antimalware 2001 None
Error 05/09/2010 18:22:18 Microsoft Antimalware 2001 None
Error 05/09/2010 18:22:47 WindowsUpdateClient 20 Windows Update Agent
Error 05/09/2010 22:54:14 DistributedCOM 10005 None
Error 05/09/2010 22:54:14 Microsoft Antimalware 2001 None
Error 16/09/2010 14:42:28 DNS Client Events 1012 None
Error 16/09/2010 14:42:23 DNS Client Events 1012 None
Error 06/09/2010 17:23:48 Kernel-General 5 None
Error 05/09/2010 18:22:18 Microsoft Antimalware 2003 None
Error 04/09/2010 16:38:29 Service Control Manager 7016 None
Error 16/09/2010 14:40:08 Service Control Manager 7001 None
Error 16/09/2010 14:41:18 DistributedCOM 10005 None
Error 16/09/2010 14:40:07 Service Control Manager 7001 None
Error 05/09/2010 22:55:36 DistributedCOM 10005 None
Error 05/09/2010 22:55:41 DistributedCOM 10005 None
Error 05/09/2010 22:55:31 Service Control Manager 7026 None
Error 06/09/2010 10:14:06 Service Control Manager 7034 None
Error 06/09/2010 10:14:03 Microsoft Antimalware 5008 None
Error 05/09/2010 22:55:42 DistributedCOM 10005 None
Error 05/09/2010 22:55:43 Service Control Manager 7001 None
Error 16/09/2010 14:41:18 Service Control Manager 7001 None
Error 05/09/2010 22:53:43 Service Control Manager 7001 None
Error 05/09/2010 22:50:33 Service Control Manager 7001 None
Error 05/09/2010 22:50:34 Service Control Manager 7001 None
Error 16/09/2010 17:08:26 DNS Client Events 1012 None
Error 05/09/2010 22:50:32 DistributedCOM 10005 None
Error 05/09/2010 22:50:46 Service Control Manager 7001 None
Error 05/09/2010 22:51:44 Microsoft Antimalware 2001 None
Error 04/09/2010 16:35:18 Service Control Manager 7001 None
Error 04/09/2010 16:35:21 Service Control Manager 7001 None
Error 05/09/2010 22:50:25 DistributedCOM 10005 None
Error 05/09/2010 22:50:31 DistributedCOM 10005 None
Error 05/09/2010 22:50:20 Service Control Manager 7026 None
Error 04/09/2010 16:37:04 EventLog 6008 None
Error 16/09/2010 17:08:28 DNS Client Events 1012 None
Error 05/09/2010 22:53:29 Service Control Manager 7001 None
Error 06/09/2010 17:14:35 Microsoft Antimalware 3002 None
Error 06/09/2010 17:14:36 Service Control Manager 7031 None
Error 05/09/2010 22:53:31 Service Control Manager 7001 None
Error 06/09/2010 17:15:20 Service Control Manager 7031 None
Error 16/09/2010 14:42:33 DNS Client Events 1012 None
Error 06/09/2010 17:15:19 Microsoft Antimalware 5008 None
Error 05/09/2010 22:53:19 Service Control Manager 7001 None
Error 05/09/2010 22:53:19 Service Control Manager 7026 None
Error 05/09/2010 22:53:14 EventLog 6008 None
Error 16/09/2010 17:08:22 EventLog 6008 None
Error 05/09/2010 22:53:21 DistributedCOM 10005 None
Error 06/09/2010 17:14:34 Microsoft Antimalware 5008 None
Error 05/09/2010 22:53:29 DistributedCOM 10005 None
Error 05/09/2010 22:53:28 DistributedCOM 10005 None
Error 06/09/2010 22:31:58 Service Control Manager 7001 None
Error 06/09/2010 22:31:56 Service Control Manager 7001 None
Error 06/09/2010 22:32:09 Service Control Manager 7001 None
Error 06/09/2010 22:33:58 DistributedCOM 10005 None
Error 06/09/2010 22:33:59 DistributedCOM 10005 None
Error 06/09/2010 22:33:53 DistributedCOM 10005 None
Error 06/09/2010 22:33:49 Service Control Manager 7026 None
Error 06/09/2010 22:31:46 Service Control Manager 7001 None
Error 08/09/2010 16:02:10 Service Control Manager 7031 None
Error 06/09/2010 22:31:46 Service Control Manager 7031 None
Error 06/09/2010 22:31:46 Kernel-General 5 None
Error 06/09/2010 22:31:54 DistributedCOM 10005 None
Error 06/09/2010 22:31:55 DistributedCOM 10005 None
Error 06/09/2010 22:31:49 DistributedCOM 10005 None
Error 08/09/2010 16:06:59 EventLog 6008 None
Error 06/09/2010 22:31:46 Service Control Manager 7026 None
Error 05/09/2010 12:10:00 WindowsUpdateClient 20 Windows Update Agent
Error 05/09/2010 12:12:55 Service Control Manager 7031 None
Error 05/09/2010 12:59:15 Service Control Manager 7016 None
Error 08/09/2010 16:09:02 EventLog 6008 None
Error 05/09/2010 12:09:36 WindowsUpdateClient 20 Windows Update Agent
Error 05/09/2010 12:26:46 Service Control Manager 7034 None
Error 05/09/2010 12:29:01 EventLog 6008 None
Error 05/09/2010 12:29:02 BugCheck 1001 None
Error 06/09/2010 22:34:00 Service Control Manager 7001 None
Error 08/09/2010 17:00:49 BugCheck 1001 None
Error 06/09/2010 22:34:01 Service Control Manager 7001 None
Error 06/09/2010 22:34:12 Service Control Manager 7001 None
Error 06/09/2010 22:36:22 EventLog 6008 None
Error 08/09/2010 17:00:46 EventLog 6008 None
Error 08/09/2010 17:44:29 EventLog 6008 None
Error 06/09/2010 22:25:27 Service Control Manager 7001 None
Error 06/09/2010 09:29:14 DistributedCOM 10005 None
Error 06/09/2010 09:28:36 Service Control Manager 7001 None
Error 06/09/2010 09:29:14 Microsoft Antimalware 2001 None
Error 06/09/2010 22:29:00 EventLog 6008 None
Error 06/09/2010 22:25:13 Service Control Manager 7026 None
Error 06/09/2010 22:25:19 DistributedCOM 10005 None
Error 08/09/2010 18:07:18 EventLog 6008 None
Error 06/09/2010 22:25:11 Service Control Manager 7001 None
Error 06/09/2010 22:25:25 DistributedCOM 10005 None
Error 06/09/2010 22:25:27 DistributedCOM 10005 None
Error 06/09/2010 22:25:26 DistributedCOM 10005 None
Error 06/09/2010 22:29:17 DistributedCOM 10005 None
Error 06/09/2010 22:29:18 Service Control Manager 7001 None
Error 06/09/2010 22:29:16 DistributedCOM 10005 None
Error 06/09/2010 22:29:10 DistributedCOM 10005 None
Error 06/09/2010 22:29:15 DistributedCOM 10005 None
Error 06/09/2010 09:28:03 Kernel-General 5 None
Error 06/09/2010 22:31:46 Service Control Manager 7000 None
Error 06/09/2010 22:29:29 Service Control Manager 7001 None
Error 06/09/2010 09:28:25 Service Control Manager 7001 None
Error 06/09/2010 09:28:25 DistributedCOM 10005 None
Error 06/09/2010 09:28:26 Service Control Manager 7001 None
Error 06/09/2010 09:28:13 Service Control Manager 7026 None
Error 06/09/2010 22:29:05 Service Control Manager 7026 None
Error 06/09/2010 09:28:14 Microsoft Antimalware 2004 None
Error 06/09/2010 09:28:24 DistributedCOM 10005 None
Error 06/09/2010 09:28:18 DistributedCOM 10005 None
Error 06/09/2010 00:12:18 EventLog 6008 None
Error 05/09/2010 12:32:06 WindowsUpdateClient 20 Windows Update Agent
Error 05/09/2010 12:32:05 WindowsUpdateClient 20 Windows Update Agent
Error 06/09/2010 22:40:49 DistributedCOM 10005 None
Error 06/09/2010 22:40:50 DistributedCOM 10005 None
Error 08/09/2010 16:10:56 Service Control Manager 7001 None
Error 06/09/2010 22:44:18 EventLog 6008 None
Error 06/09/2010 22:41:04 Service Control Manager 7001 None
Error 08/09/2010 16:11:06 Service Control Manager 7001 None
Error 08/09/2010 16:12:48 EventLog 6008 None
Error 05/09/2010 12:56:56 EventLog 6008 None
Error 08/09/2010 16:11:24 DistributedCOM 10010 None
Error 08/09/2010 16:10:56 Microsoft Antimalware 2004 None
Error 06/09/2010 22:40:51 Service Control Manager 7001 None
Error 06/09/2010 22:40:54 Service Control Manager 7001 None
Error 06/09/2010 22:40:52 Service Control Manager 7001 None
Error 06/09/2010 22:40:44 DistributedCOM 10005 None
Error 08/09/2010 16:20:56 DistributedCOM 10005 None
Error 08/09/2010 16:20:55 Service Control Manager 7001 None
Error 08/09/2010 16:20:57 DistributedCOM 10005 None
Error 08/09/2010 16:20:57 Service Control Manager 7001 None
Error 08/09/2010 16:20:54 Service Control Manager 7001 None
Error 08/09/2010 16:20:46 DistributedCOM 10005 None
Error 08/09/2010 16:10:40 BugCheck 1001 None
Error 08/09/2010 16:20:53 DistributedCOM 10005 None
Error 08/09/2010 16:20:54 DistributedCOM 10005 None
Error 08/09/2010 16:21:41 Microsoft Antimalware 2001 None
Error 08/09/2010 16:10:40 EventLog 6008 None
Error 08/09/2010 16:23:09 EventLog 6008 None
Error 06/09/2010 00:07:09 BugCheck 1001 None
Error 08/09/2010 16:10:43 Service Control Manager 7026 None
Error 06/09/2010 00:07:00 EventLog 6008 None
Error 08/09/2010 16:20:40 BugCheck 1001 None
Error 08/09/2010 16:20:38 EventLog 6008 None
Error 08/09/2010 16:10:44 DistributedCOM 10005 None
Error 06/09/2010 22:40:38 Service Control Manager 7026 None
Error 08/09/2010 16:10:54 Service Control Manager 7001 None
Error 08/09/2010 16:10:54 DistributedCOM 10005 None
Error 08/09/2010 16:10:52 DistributedCOM 10005 None
Error 08/09/2010 16:20:41 Service Control Manager 7001 None
Error 08/09/2010 16:20:42 Service Control Manager 7026 None
Error 05/09/2010 23:12:15 Service Control Manager 7001 None
Error 05/09/2010 23:12:17 Service Control Manager 7001 None
Error 04/09/2010 19:56:18 BugCheck 1001 None
Error 06/09/2010 23:10:27 BugCheck 1001 None
Error 05/09/2010 23:13:05 DistributedCOM 10005 None
Error 05/09/2010 23:12:27 Service Control Manager 7001 None
Error 08/09/2010 21:35:03 DNS Client Events 1012 None
Error 05/09/2010 23:11:58 Service Control Manager 7026 None
Error 05/09/2010 23:12:07 DistributedCOM 10005 None
Error 05/09/2010 13:19:31 EventLog 6008 None
Error 06/09/2010 09:38:41 Microsoft Antimalware 2001 None
Error 08/09/2010 21:44:57 WindowsUpdateClient 20 Windows Update Agent
Error 05/09/2010 23:12:13 DistributedCOM 10005 None
Error 08/09/2010 21:35:06 DNS Client Events 1012 None
Error 04/09/2010 19:56:17 EventLog 6008 None
Error 05/09/2010 23:12:14 DistributedCOM 10005 None
Error 06/09/2010 09:36:22 Service Control Manager 7001 None
Error 05/09/2010 23:16:27 Service Control Manager 7026 None
Error 08/09/2010 21:34:56 BugCheck 1001 None
Error 06/09/2010 09:36:23 Service Control Manager 7001 None
Error 06/09/2010 09:36:21 DistributedCOM 10005 None
Error 06/09/2010 09:36:14 DistributedCOM 10005 None
Error 06/09/2010 09:36:10 Service Control Manager 7026 None
Error 06/09/2010 09:36:20 DistributedCOM 10005 None
Error 08/09/2010 21:34:53 EventLog 6008 None
Error 05/09/2010 23:14:15 Service Control Manager 7001 None
Error 05/09/2010 23:16:24 EventLog 6008 None
Error 08/09/2010 21:34:59 DNS Client Events 1012 None
Error 05/09/2010 23:14:13 DistributedCOM 10005 None
Error 08/09/2010 21:34:58 DNS Client Events 1012 None
Error 06/09/2010 09:36:34 Service Control Manager 7001 None
Error 08/09/2010 15:54:26 WindowsUpdateClient 20 Windows Update Agent
Error 07/09/2010 08:47:01 Service Control Manager 7031 None
Error 07/09/2010 08:47:01 Service Control Manager 7034 None
Error 16/09/2010 09:23:07 DNS Client Events 1012 None
Error 16/09/2010 09:24:04 Microsoft Antimalware 2001 None
Error 07/09/2010 08:49:43 NetBT 4300 None
Error 07/09/2010 08:50:20 EventLog 6008 None
Error 08/09/2010 15:35:35 BugCheck 1001 None
Error 07/09/2010 08:37:17 BugCheck 1001 None
Error 08/09/2010 15:35:34 EventLog 6008 None
Error 16/09/2010 09:21:07 EventLog 6008 None
Error 05/09/2010 13:19:35 BugCheck 1001 None
Error 07/09/2010 08:37:15 EventLog 6008 None
Error 04/09/2010 19:23:41 Service Control Manager 7031 None
Error 06/09/2010 21:40:30 Service Control Manager 7016 None
Error 04/09/2010 19:16:44 EventLog 6008 None
Error 07/09/2010 08:41:05 WindowsUpdateClient 20 Windows Update Agent
Error 07/09/2010 08:46:58 WindowsUpdateClient 20 Windows Update Agent
Error 04/09/2010 19:16:45 BugCheck 1001 None
Error 16/09/2010 09:21:08 BugCheck 1001 None
Error 05/09/2010 13:21:34 Service Control Manager 7023 None
Error 16/09/2010 09:21:14 Microsoft Antimalware 2004 None
Error 16/09/2010 09:23:01 EventLog 6008 None
Error 05/09/2010 13:22:25 Service Control Manager 7016 None
Error 05/09/2010 23:16:32 DistributedCOM 10005 None
Error 06/09/2010 09:32:06 Microsoft Antimalware 2001 None
Error 08/09/2010 18:07:51 Service Control Manager 7034 None
Error 06/09/2010 09:32:09 Microsoft Antimalware 2001 None
Error 06/09/2010 22:22:46 VDS Basic Provider 1 None
Error 06/09/2010 22:22:47 VDS Basic Provider 1 None
Error 08/09/2010 18:07:36 Service Control Manager 7031 None
Error 06/09/2010 09:31:25 Service Control Manager 7001 None
Error 06/09/2010 09:31:36 Service Control Manager 7001 None
Error 06/09/2010 09:32:06 DistributedCOM 10005 None
Error 06/09/2010 22:52:31 DistributedCOM 10010 None
Error 08/09/2010 18:38:40 BugCheck 1001 None
Error 05/09/2010 13:05:47 Service Control Manager 7031 None
Error 05/09/2010 13:06:02 Service Control Manager 7032 None
Error 06/09/2010 09:33:15 Service Control Manager 7026 None
Error 08/09/2010 18:38:40 EventLog 6008 None
Error 06/09/2010 09:32:10 Service Control Manager 7001 None
Error 05/09/2010 11:53:20 BugCheck 1001 None
Error 08/09/2010 18:07:19 BugCheck 1001 None
Error 08/09/2010 16:01:46 EventLog 6008 None
Error 05/09/2010 11:53:19 EventLog 6008 None
Error 06/09/2010 09:31:23 DistributedCOM 10005 None
Error 06/09/2010 09:31:22 DistributedCOM 10005 None
Error 06/09/2010 09:31:23 Service Control Manager 7001 None
Error 06/09/2010 09:31:21 DistributedCOM 10005 None
Error 08/09/2010 18:07:21 Service Control Manager 7031 None
Error 04/09/2010 20:19:15 Service Control Manager 7031 None
Error 06/09/2010 09:31:11 Service Control Manager 7026 None
Error 06/09/2010 09:31:16 DistributedCOM 10005 None
Error 06/09/2010 22:24:13 Service Control Manager 7016 None
Error 06/09/2010 09:33:28 DistributedCOM 10005 None
Error 08/09/2010 18:53:53 DNS Client Events 1012 None
Error 05/09/2010 13:14:10 EventLog 6008 None
Error 05/09/2010 23:18:40 Service Control Manager 7001 None
Error 05/09/2010 23:16:52 Service Control Manager 7001 None
Error 05/09/2010 13:12:43 Service Control Manager 7000 None
Error 05/09/2010 13:12:28 Service Control Manager 7031 None
Error 05/09/2010 13:12:28 Service Control Manager 7000 None
Error 05/09/2010 13:12:30 Service Control Manager 7038 None
Error 05/09/2010 13:12:43 Service Control Manager 7038 None
Error 05/09/2010 13:12:34 Service Control Manager 7024 None
Error 05/09/2010 23:16:38 DistributedCOM 10005 None
Error 05/09/2010 23:16:39 Service Control Manager 7001 None
Error 06/09/2010 23:10:22 EventLog 6008 None
Error 05/09/2010 23:16:37 DistributedCOM 10005 None
Error 06/09/2010 22:08:42 Service Control Manager 7016 None
Error 05/09/2010 23:16:40 Service Control Manager 7001 None
Error 06/09/2010 09:33:38 Service Control Manager 7001 None
Error 06/09/2010 09:33:39 Service Control Manager 7001 None
Error 06/09/2010 09:33:41 Service Control Manager 7001 None
Error 06/09/2010 09:33:36 Service Control Manager 7001 None
Error 06/09/2010 09:33:35 DistributedCOM 10005 None
Error 06/09/2010 09:33:34 DistributedCOM 10005 None
Error 06/09/2010 09:34:12 Microsoft Antimalware 2001 None
Error 06/09/2010 09:34:12 DistributedCOM 10005 None
Error 05/09/2010 13:12:27 Microsoft Antimalware 3002 None
Error 05/09/2010 13:12:28 Service Control Manager 7038 None
Error 06/09/2010 09:33:51 Service Control Manager 7001 None
Error 06/09/2010 09:33:43 Service Control Manager 7001 None
Error 04/09/2010 20:14:00 Service Control Manager 7016 None
Error 06/09/2010 15:55:09 Service Control Manager 7001 None
Error 07/09/2010 22:35:04 Service Control Manager 7043 None
Error 06/09/2010 15:55:40 Microsoft Antimalware 2001 None
Error 06/09/2010 15:55:40 DistributedCOM 10005 None
Error 07/09/2010 18:03:40 Service Control Manager 7001 None
Error 07/09/2010 18:03:48 Service Control Manager 7001 None
Error 06/09/2010 15:54:57 Service Control Manager 7001 None
Error 06/09/2010 15:56:57 Service Control Manager 7001 None
Error 04/09/2010 15:57:04 Service Control Manager 7022 None
Error 04/09/2010 15:57:02 Service Control Manager 7022 None
Error 04/09/2010 15:57:06 Service Control Manager 7022 None
Error 21/09/2010 11:52:59 DNS Client Events 1012 None
Error 06/09/2010 15:57:30 Service Control Manager 7001 None
Error 06/09/2010 15:57:10 Service Control Manager 7001 None
Error 06/09/2010 15:57:22 Service Control Manager 7001 None
Error 06/09/2010 15:54:55 Service Control Manager 7001 None
Error 07/09/2010 18:03:39 DistributedCOM 10005 None
Error 21/09/2010 11:57:36 WindowsUpdateClient 20 Windows Update Agent
Error 20/09/2010 16:50:54 DNS Client Events 1012 None
Error 07/09/2010 18:03:39 Service Control Manager 7001 None
Error 07/09/2010 18:03:38 DistributedCOM 10005 None
Error 20/09/2010 16:50:52 DNS Client Events 1012 None
Error 05/09/2010 22:27:11 EventLog 6008 None
Error 21/09/2010 19:04:51 WindowsUpdateClient 20 Windows Update Agent
Error 20/09/2010 16:50:49 DNS Client Events 1012 None
Error 06/09/2010 15:03:54 MemoryDiagnostics-Results 1202 None
Error 06/09/2010 15:03:54 MemoryDiagnostics-Results 1102 None
Error 07/09/2010 17:53:34 Service Control Manager 7031 None
Error 06/09/2010 14:45:41 Service Control Manager 7011 None
Error 06/09/2010 15:43:00 DistributedCOM 10005 None
Error 22/09/2010 17:14:45 Microsoft Antimalware 2004 None
Error 21/09/2010 11:52:51 DNS Client Events 1012 None
Error 06/09/2010 15:43:01 Service Control Manager 7001 None
Error 06/09/2010 15:03:42 EventLog 6008 None
Error 06/09/2010 15:38:48 Service Control Manager 7000 None
Error 06/09/2010 14:46:11 Service Control Manager 7011 None
Error 06/09/2010 16:05:44 Service Control Manager 7000 None
Error 05/09/2010 22:03:57 Service Control Manager 7016 None
Error 06/09/2010 15:43:49 DistributedCOM 10005 None
Error 06/09/2010 15:43:49 Microsoft Antimalware 2001 None
Error 20/09/2010 16:14:25 DNS Client Events 1012 None
Error 05/09/2010 21:42:12 DistributedCOM 10005 None
Error 06/09/2010 14:42:53 MemoryDiagnostics-Results 1102 None
Error 06/09/2010 14:42:53 MemoryDiagnostics-Results 1202 None
Error 06/09/2010 15:43:12 Service Control Manager 7001 None
Error 04/09/2010 16:12:33 Service Control Manager 7016 None
Error 07/09/2010 16:43:08 Microsoft Antimalware 2001 None
Error 05/09/2010 22:27:12 BugCheck 1001 None
Error 07/09/2010 16:42:52 Microsoft Antimalware 2001 None
Error 21/09/2010 11:52:54 DNS Client Events 1012 None
Error 04/09/2010 16:10:03 Service Control Manager 7034 None
Error 07/09/2010 16:43:29 WindowsUpdateClient 20 Windows Update Agent
Error 29/06/2010 11:39:29 Service Control Manager 7022 None
Error 06/09/2010 15:49:56 Service Control Manager 7000 None
Error 20/09/2010 16:48:11 Service Control Manager 7031 None
Error 06/09/2010 15:42:54 DistributedCOM 10005 None
Error 06/09/2010 15:42:59 DistributedCOM 10005 None
Error 20/09/2010 16:48:10 Microsoft Antimalware 3002 None
Error 29/06/2010 11:39:27 Service Control Manager 7022 None
Error 20/09/2010 16:50:45 BugCheck 1001 None
Error 29/06/2010 11:39:25 Service Control Manager 7022 None
Error 06/09/2010 15:42:49 Service Control Manager 7026 None
Error 20/09/2010 16:50:42 EventLog 6008 None
Error 07/09/2010 18:01:36 Service Control Manager 7001 None
Error 07/09/2010 18:01:36 DistributedCOM 10010 None
Error 07/09/2010 18:01:38 Service Control Manager 7001 None
Error 06/09/2010 16:01:45 Service Control Manager 7000 None
Error 06/09/2010 15:52:47 DistributedCOM 10005 None
Error 07/09/2010 18:01:25 DistributedCOM 10005 None
Error 06/09/2010 15:40:19 Microsoft Antimalware 2001 None
Error 21/09/2010 12:01:47 DNS Client Events 1012 None
Error 07/09/2010 18:01:10 EventLog 6008 None
Error 07/09/2010 18:03:28 DistributedCOM 10005 None
Error 05/09/2010 21:06:52 BugCheck 1001 None
Error 07/09/2010 19:25:53 EventLog 6008 None
Error 06/09/2010 15:11:11 Service Control Manager 7016 None
Error 05/09/2010 21:00:56 Kernel-General 5 None
Error 20/09/2010 16:53:05 DNS Client Events 1012 None
Error 20/09/2010 16:53:06 DNS Client Events 1012 None
Error 07/09/2010 18:03:23 EventLog 6008 None
Error 07/09/2010 17:57:53 Service Control Manager 7031 None
Error 07/09/2010 18:01:24 DistributedCOM 10005 None
Error 06/09/2010 15:52:56 Service Control Manager 7001 None
Error 07/09/2010 17:44:24 Microsoft Antimalware 2004 None
Error 06/09/2010 15:53:06 Service Control Manager 7001 None
Error 20/09/2010 16:53:10 DNS Client Events 1012 None
Error 20/09/2010 16:53:11 DNS Client Events 1012 None
Error 06/09/2010 15:52:55 Service Control Manager 7001 None
Error 21/09/2010 12:01:53 DNS Client Events 1012 None
Error 06/09/2010 15:53:44 DistributedCOM 10005 None
Error 29/06/2010 11:40:37 Service Control Manager 7016 None
Error 06/09/2010 15:52:46 Service Control Manager 7026 None
Error 06/09/2010 15:40:19 Service Control Manager 7016 None
Error 07/09/2010 18:01:19 DistributedCOM 10005 None
Error 07/09/2010 18:01:15 Service Control Manager 7026 None
Error 21/09/2010 12:01:51 DNS Client Events 1012 None
Error 06/09/2010 15:53:44 Microsoft Antimalware 2001 None
Error 06/09/2010 15:52:55 DistributedCOM 10005 None
Error 06/09/2010 15:52:54 DistributedCOM 10005 None
Error 06/09/2010 15:41:06 Service Control Manager 7026 None
Error 20/09/2010 16:51:24 Service Control Manager 7031 None
Error 07/09/2010 18:03:27 Service Control Manager 7001 None
Error 06/09/2010 15:54:42 DistributedCOM 10005 None
Error 06/09/2010 15:54:52 DistributedCOM 10005 None
Error 06/09/2010 15:54:47 DistributedCOM 10005 None
Error 06/09/2010 15:51:42 Microsoft Antimalware 2001 None
Error 06/09/2010 15:54:41 Service Control Manager 7026 None
Error 21/09/2010 12:01:42 BugCheck 1001 None
Error 21/09/2010 12:01:40 EventLog 6008 None
Error 20/09/2010 16:51:22 Windows Media Player Network Sharing Service 14317 None
Error 06/09/2010 15:51:37 Microsoft Antimalware 2003 None
Error 06/09/2010 15:51:37 Microsoft Antimalware 2001 None
Error 04/09/2010 16:07:27 BugCheck 1001 None
Error 06/09/2010 15:54:53 DistributedCOM 10005 None
Error 20/09/2010 16:51:22 Service Control Manager 7023 None
Error 07/09/2010 18:03:28 Service Control Manager 7026 None
Error 06/09/2010 15:41:18 Service Control Manager 7001 None
Error 06/09/2010 15:41:11 DistributedCOM 10005 None
Error 05/09/2010 21:41:51 EventLog 6008 None
Error 06/09/2010 15:41:16 DistributedCOM 10005 None
Error 06/09/2010 15:41:18 DistributedCOM 10005 None
Error 06/09/2010 15:41:17 DistributedCOM 10005 None
Error 20/09/2010 16:53:00 EventLog 6008 None
Error 20/09/2010 16:51:24 DNS Client Events 1012 None
Error 06/09/2010 15:41:30 Service Control Manager 7001 None
Error 05/09/2010 21:41:53 BugCheck 1001 None
Error 20/09/2010 16:51:29 Service Control Manager 7023 None
Error 07/09/2010 18:08:34 Service Control Manager 7001 None
Error 22/09/2010 17:14:48 DNS Client Events 1012 None
Error 07/09/2010 18:08:34 Service Control Manager 7026 None
Error 06/09/2010 15:46:28 EventLog 6008 None
Error 05/09/2010 22:02:57 Service Control Manager 7031 None
Error 22/09/2010 17:14:56 DNS Client Events 1012 None
Error 07/09/2010 18:08:50 Service Control Manager 7001 None
Error 07/09/2010 16:32:03 BugCheck 1001 None
Error 20/09/2010 16:14:20 DNS Client Events 1012 None
Error 05/09/2010 22:02:56 DistributedCOM 10010 None
Error 06/09/2010 15:35:04 Microsoft Antimalware 2004 None
Error 06/09/2010 15:34:57 EventLog 6008 None
Error 06/09/2010 15:35:01 BugCheck 1001 None
Error 05/09/2010 22:03:27 Service Control Manager 7034 None
Error 06/09/2010 15:48:51 Microsoft Antimalware 2001 None
Error 05/09/2010 21:43:48 EventLog 6008 None
Error 07/09/2010 20:22:43 Kernel-General 5 None
Error 04/09/2010 16:02:26 Service Control Manager 7016 None
Error 06/09/2010 15:38:43 EventLog 6008 None
Error 05/09/2010 20:30:48 Service Control Manager 7000 None
Error 06/09/2010 15:59:49 Service Control Manager 7000 None
Error 05/09/2010 22:02:31 Service Control Manager 7031 None
Error 06/09/2010 15:46:35 Service Control Manager 7000 None
Error 20/09/2010 16:14:24 DNS Client Events 1012 None
Error 05/09/2010 22:03:17 Service Control Manager 7030 None
Error 07/09/2010 18:08:49 DistributedCOM 10005 None
Error 07/09/2010 18:08:43 DistributedCOM 10005 None
Error 07/09/2010 18:08:48 DistributedCOM 10005 None
Error 22/09/2010 17:14:53 DNS Client Events 1012 None
Error 07/09/2010 18:08:49 Service Control Manager 7001 None
Error 08/09/2010 17:44:36 BugCheck 1001 None
Error 07/09/2010 17:52:56 EventLog 6008 None
Error 05/09/2010 22:03:13 Service Control Manager 7030 None
Error 07/09/2010 17:52:57 BugCheck 1001 None
#73
The final word.
I pulled out each ram stick and the computer ran ok, put a single ram into each slot and all worked ok, then when I put in both sticks the machine crashes. So it appears the machine does not run with two sticks in it!
Many thanks for your help.
#74
Raise the vdimm (memory voltage) by .1 in the bios with both sticks in and see if it crashes like that.
#75
Re: BSOD within 60 seconds of running IE8
Unfortunately I have a ms-7366 motherboard that doesnt have that option within the bios - I cant find any software to do it either.
#76
You're the second person to say that in the last 24 hours and the answer is the same to you. Of course you have that in the bios. All motherboards do, even the cheapest and oldest.
It's in the top right under Frequency/Voltage Control.
Download your manual if you need help:
http://www.msi.com/index.php?func=downloadfile&dno=6006&type=manual
#77
Well this is mysterious as I appear to have the up to date bios(1/4/2010) but no voltage option on the top right hand side as described in the manual.
I have tried the msi live update and it says I dont need to update the bios. Any ideas?
Shumit
#78
Yeah, MSI gets a little weird on some revisions of the board and locks the options. In almost all cases, you can find a bios version made by a hobbyist or enthusiast that unlocks those settings and shows it in the menu. I myself have MSI-7211 and needed to install the unlocked bios to have the options.
So you could try that or simply replace the memory instead, with a matching set.
#79
I tried a matching set and got the same issues. I will hunt around for a hacked bios but there seems to be little out there.
thanks,Shumit
#80
Search for your board and this name: 1234s282. He made my bios and tons of others for MSI.
