Windows 7 Desktop help please...
richardeldritch
I have the following, on the top left corner of my desktop, and want it gone.
If you can tell me how to get rid of it, I would be most grateful...
Cheers,
Richard
The thing to do would probably be a thorough scan. Be sure you have the latest updates for your antivirus, and you could make another scan with Malwarebytes.
There is a virus called Seres, seres.exe Windows process - What is it?
It's probably a "gift" from duiops.net. I would do the scans, and check that the seres is mentioned in the scan report as dangerous. If you can't see it there, you can do a normal search for the file, and delete it manually. As far as I can see, no seres anything is vital for Windows.
EDIT: Might be wise to avoid duiops.net? Or at least improve your protection level?
