Display with DisplayPort, CPU with HDMI
usermn
There is a monitor with a DisplayPort input port. There is a desktop computer with an HDMI output port. Is it possible to connect the two?
you need an adapter like this:
Close-up of a multi-port video adapter cable with HDMI and DisplayPort connectors.
and a HDMI cable between the adapter and desktop
There might be cables that have one end HDMI male and the other DisplayPort, in that case you don't need this adapter.
livix07
Honorable Member
usermn
I think the adapter in your photo converts DisplayPort signal to HDMI, but not vice versa.
usermn
The suitable adapter would be too expensive for an adapter. I'll buy a new monitor that has many different digital ports.
