alienwhere
- Joined
- Dec 1, 2010
- Messages
- 6
- Thread Author
- #1
I'm a PC gamer, and my dual screens would work great for an online game that has dual screen set up options in game. I have an Alienware M15x laptop, with a Toshiba 19 inch screen hooked up via VGA cable + audio. I have it already set up to extend so i can go between the two seperate desktop spaces with no problem...
...except that when i go from laptop screen to TV screen, my cursor and whatever screen I'm dragging over jumps up to a higher spot upon entering the TV screen. Other than that I can dragg the window to the top and bottom of the TV screen the same as i can on the laptop screen. I can upsize it to fit the TV screen with no problem.
Cutting to the chase: when I run the game on windowed mode and streach it between the two screens, the game goes from top to botttom of the laptop screen, but on the TV screen it shows half the window... the rest goes out of the top of the screen where I can essentialy only see the bottom half of the left side of the game on my TV screen while seeing the whole half of the right side on my laptop screen. Needless to say, that doesn't work out very well. I've looked through the control panel menu concerning dual monitor hook ups and I've messed around with the TV monitor's computer compatability settings to no avail. Is there anything I'm missing? Did I set it up incorrectly/have the wrong type of TV?
Thanks in advance =)
