Find and replace TEXT with FILENAME
marcoswebot
Hello. I have several hundred text files in a folder. I would like to replace the text "Hello" present in every files with the actual "filename".
How to do that? Can I use a Script or PowerShell?
Thank you!
Neemobeer
Windows Forum Team
With PowerShell
$SearchDirectory = "C:\path\to\directory"
$Files = Get-ChildItem -Path $SearchDirectory -File
foreach($File in $Files)
    $FileData = Get-Content $File.FullName
    $ReplaceString = "Hello"
    $ReplaceData = "Hello+$($File.Name)"
    $NewFileData = $FileData.Replace($ReplaceString,$ReplaceData)
    Out-File -FilePath $File.FullName -InputObject $NewFileData -Force
marcoswebot
With PowerShell
    $ReplaceData = $File.Name
Thanks Neemobeer, but this did not work for me.
I did not explain very good. I try again:
What I need to do is to change the TEXT "Hello" with the TEXT "Hello+filename"
Neemobeer
Windows Forum Team
You need to change the path mentioned in the first line
Otherwise post the error "this is not working" doesn't tell me much.
marcoswebot
Neemobeer, thanks again for your help.
It works but somehow when I open the file with my program i get this: ÿþ% instead of the full text.
If I open the program with text editor it works but with my special text editor no :-/ Do you know which could be the reason?
Thanks a lot :-D
