Nawaf
Dears,
Good day,
I have Asus PC with built in window, i am trying to boot recovery mood f9 when the PC start off.
unfortunately the recovery not solve the problem even when i select full format for PC.
the PC run and shut down again and again (unlimited loop) seems that there is a software problem.
i have decided to use a original windows 7 installation file and boot using DVD or USB.
but i could not find a way to download windows 7
even when i use Microsoft website and use serial number it gave me a message
Error
The product key you entered appears to be for software pre-installed by the device manufacturer. Please contact the device manufacturer for software recovery options.​
How could i get legally ISO file for windows home premium 64 bit ?
Hi and welcome to the forum :up:
That's easy. Go to this Microsoft site where you can download the Win7 ISO file and create bootable windows media: Link Removed
Take a look also at this article which gives some good tips on using the Win7 install media here: Link Removed
Once you create your Win7 installation media you should be able to reinstall your Windows. If this still doesn't work for you, you may have to use a 3rd party utility such as DBAN (which you can google) to completely erase your hard drive. Then attempt to once again install Win7 from the bootable media (DVD or USB) you created in the steps above. That will usually take of your problem. :up: If it still doesn't work, you may have a faulty hard...
BIGBEARJEDI
Once you create your Win7 installation media you should be able to reinstall your Windows. If this still doesn't work for you, you may have to use a 3rd party utility such as DBAN (which you can google) to completely erase your hard drive. Then attempt to once again install Win7 from the bootable media (DVD or USB) you created in the steps above. That will usually take of your problem. :up: If it still doesn't work, you may have a faulty hard drive and that will require hardware testing. Here's a link on how to do that: Link Removed
Since you are running Win7 on your computer, bear in mind that if you have never replaced the hard drive in your computer since you owned it, your computer is now 7 years old, it is extremely likely your Hard Drive has failed.:( Hard Drives these days are only designed to last 3 years in desktop PCs and 2 years in laptops. If the Hard Drive diagnostics return errors, your drive has failed and must be replaced.:waah:
Good luck,:encouragement:
<<<BIGBEARJEDI>>>
Nawaf
Thank for your reply,
as i mentioned the Microsoft URL is not work it gave me the below message
Error
Neemobeer
Windows Forum Team
If you get that message, it means you have a system builder/oem license so you will need to get install media from the computer manufacturer.
Neemobeer
Windows Forum Team
You'll just need to look at the manufacturer site. They may have the option to download the media or you can pay for physical media I've seen them range from $10-50
BIGBEARJEDI
Actually, it's now between $29-$99 US for factory Recovery Media.:cash: I order them for all the major computer makers for use in rebuilding broken customer computers from Dell, Acer, ASUS, HP, Lenovo, and Toshiba. This cost may be more outside the US; we have users here who tell us they have paid up to $300 US for Recovery Media outside the US, due to import restrictions and taxes.
FYI.
BBJ
Nawaf
FYI.
BBJ
thank for all these information,
i have opened ticket with the manufacture and waiting their reply.
sincerely.
