veloth
When I connect my HDTV to the laptop with an HDMI cable nothing shows on the TV, even when the TV is selected in Catalyst control panel. If I restart the laptop the TV will show what the Laptop screen shows until the laptop reaches the windows start screen then it goes blank. I would like to use my TV as my laptop screen but I can't seem to get it to work. Below are the system info.
Graphic Card>>
AMD Radeon HD 7640G>>
AMD Catalyst Driver>>
AMD Driver 9.12.0.0>>
BIOS Version/Date Acer V1.03, 5/23/2012>>
OS Name Microsoft Windows 8 Pro with Media Center>>
Version 6.2.9200 Build 9200>>
System Manufacturer Acer>>
System Model Aspire V3-551>>
System Type x64-based PC>>
Processor AMD A8-4500M APU with Radeon(tm) HD Graphics, 1900 Mhz, 4 Core(s), 4 Logical Processor(s)>>
SMBIOS Version 2.7>>
Embedded Controller Version 255.255>>
BIOS Mode Legacy>>
BaseBoard Manufacturer Acer>>
BaseBoard Model Not Available>>
BaseBoard Name Base Board>>
Platform Role Mobile>>
Secure Boot State Unsupported>>
PCR7 Configuration Binding Not Possible>>
Windows Directory C:\WINDOWS>>
System Directory C:\WINDOWS\system32>>
Boot Device \Device\HarddiskVolume2>>
Locale United States>>
Hardware Abstraction Layer Version = "6.2.9200.16442">>
Installed Physical Memory (RAM) 4.00 GB>>
Total Physical Memory 3.48 GB>>
Available Physical Memory 2.14 GB>>
Total Virtual Memory 6.73 GB>>
Available Virtual Memory 5.26 GB>>
Page File Space 3.25 GB>>
Page File C:\pagefile.sys>>
Hyper-V - VM Monitor Mode Extensions Yes>>
Hyper-V - Second Level Address Translation Extensions Yes>>
Hyper-V - Virtualization Enabled in Firmware Yes>>
Hyper-V - Data Execution Protection Yes>>
Thanks for your reply. I had tried that without success. I did solve the problem by getting a new 60" LED and then removing Windows 8. Thanks for the help!
Mitchell_A
Former Moderator
Have you tried pressing Win+P and selecting extend or secondary screen only? Just a thought.
veloth
