Windows 7 headset wont work when mic works
xXwhygodwhyXx
Ok I bought this nice headset for pc gaming NOT RECORDING and when I want to use the mic I get no sound, I hope I dont have to send it back. Ive been looking all over for this problem and cant find any solutions there is got to be a a way to fix this. Yes I know both work.
It sounds like you're experiencing issues with your headset microphone not producing any sound while gaming on your PC. This problem can be frustrating, but there are a few troubleshooting steps you can try before considering sending the headset back. Here are some common solutions to fix microphone issues on a PC:
Steps to Fix Microphone Issues:​
  1. Check Hardware:
    • Ensure that your headset is properly connected to the correct ports on your PC.
    • Check if there are any physical damages to the headset or its cables.
    []Set Microphone as Default Device:
    • Right-click on the volume icon in the taskbar and select "Sounds."
    • Go to the "Recording" tab and set your headset microphone as the default...
  1. Check Hardware:
    • Go to the "Recording" tab and set your headset microphone as the default device.
    ]Adjust Microphone Settings:
    • Right-click on the volume icon in the taskbar and select "Open Sound settings."
    • Under the "Input" section, select your headset microphone and adjust the volume levels.
    []Update Audio Drivers:
    • Outdated or missing audio drivers can cause microphone issues. Update your audio drivers through the Device Manager or the manufacturer's website.
    ]Check Privacy Settings:
    • Make sure that apps have permission to access your microphone. Go to Settings > Privacy > Microphone and check the app permissions.
    []Test on Another Device:
    • To determine if the issue is with the headset or the PC, try using the headset on another device to see if the microphone works.
    ]Run Troubleshooters:
    • Windows has built-in troubleshooters that can help identify and fix sound and hardware issues. Run the "Recording Audio" troubleshooter.
  2. Check Application Settings:
    • Ensure that the application you're using recognizes the headset microphone as the input device.
      Additional Tips:​
      • Restart your PC after making any changes to apply the settings.
      • Try using a different USB port or audio jack on your PC.
      If you've tried these steps and are still facing issues, it might be worth reaching out to the headset manufacturer's support for specific troubleshooting assistance. Please let me know if you need further assistance with any of these steps!
