scotty1105
Well-Known Member
- Joined
- Dec 28, 2010
- Messages
- 31
- Thread Author
- #1
I am looking for some serious help to a problem that is seriously going to put me in a padded room. I currently own an Hp Envy 1110NR 8g 2.53 GHz Intel-i5 460 with turbo boost an integrated Intel and discrete ATI Mobility Radeon 5650 with 1 GB of memory. Now I have never had any problems playing games high end or low end, my system seemed to always be able to handle it? About a month ago I did a complete update on all my drivers as some had not been updated since I bought this back in 2011. 2 weeks ago I got a game called Rage, but I couldn’t play it for some reason with my graphics card so I used an update on amds site to be able to play rage. This updated my driver and Catalyst control center. Game worked great no lag like before, now some of my other games didn't work at all with this new update. No big deal I figured I just roll back to my previous drivers. Finished the game used the update from hp and I got my old version of catalyst control center and ati driver 8.777 something.
Now all my games are the same I can play great for about 5-10 minutes then it goes into slow motion. This is not just 1 game, all my games, dead space 3, cod black ops 2, borderlands 2, mass effect 1, 2, 3, and NFS most wanted 2013 etc. This NEVER happened before ever, I have tried lowering settings to just about bust but it makes no real difference. I have tried changing the settings on my computer to run on peak performance instead of visual quality this only gives me a little fps. When I run benchmarks on games such as just cause 2 I am averaging about 24 fps, dead space 3 40 fps, Sleeping Dogs, is weird I max out at 63, average 46-47 and have a minimum of 12 fps. There is no steady constant; I tried all the same setting for each game still no change. I could be using the lowest settings say res- 1024x768, I get 10 mins or so or great game play then slow motion like my computer is trying to catch up. I have a 150gbs of free hard drive space at all times. So it cant be space.
I have tried different versions of catalyst control downloads that didn’t work. I have put the original drivers back on in hopes that would fix the issue, nope. I went as far as taking my computer apart to clean the fans from dust and debree giving the inside a nice clean job. I used amds cleaner tool to uninstall all the old drivers then did a new fresh install of the hp graphic driver package located on there site. Just tried to play sleeping dogs and same thing slows down during play.
I am so frustrated with this can somebody please offer some help to me any suggestions would be so appreciated, this is totally ruining my games, and I am a huge gamer.
I don’t want to do a reboot to factory settings that would be a last last last resort.
Thank You
Thank You
