U
Unregistered
Guest
- Thread Author
- #1
Heya all, Im considering buying a acer 2920 which has vista installed. Now what i need to know is how to create a bootable installation disk (from the operating system itself)
Iv doen some research and found that already installed o/s are OEM. So phoned the people and they say they dont provide an installation disk - but a system recovery disk, and a recovery disk isnt the same as installation disk.
Ive googled that but havent found a solid answer - so how do i create a bootable vista installation disk from the laptop itself?
- Joined
- May 1, 2008
- Messages
- 5,555
Celestra
Former Moderator
- Joined
- Jan 15, 2008
- Messages
- 2,448
Build your own custom Vista installation DVD - Unattended Setup (part 1) Microsoft Windows
Get a copy of Acronis True Image. Make an image of the whole partition/HD and then use Acronis to make an autoboot acronis CD.
I agree with this recommendation 100%. If your information is critical you should use a 3rd party backup resource just in case.
03hdfatboy
Banned
- Joined
- Feb 8, 2008
- Messages
- 1,416
Me 2 Link Removed - Invalid URLI agree with this recommendation 100%. If your information is critical you should use a 3rd party backup resource just in case.
Celestra
Former Moderator
- Joined
- Jan 15, 2008
- Messages
- 2,448
03hdfatboy
Banned
- Joined
- Feb 8, 2008
- Messages
- 1,416
No but most new PC's don't come with them anymoreI don't understand, you guys got something against a Windows Bootable Installation Disk set-up ?
Similar threads
- Replies
- 3
- Views
- 3K
- Replies
- 1
- Views
- 2K
- Replies
- 8
- Views
- 9K
- Solved
- Replies
- 6
- Views
- 3K
- Replies
- 4
- Views
- 2K
