Is my battery dying?
vaxxeene
My laptop shuts down when the battery charge is above 40%. Is the battery dying? Here are some details about the battery from the app "batterycare":
-current battery capacity: 100%
-battery remaining time: 3h58minutes
-battery status: full charge
-discharge cycle progress: 7/30
-Designed capacity: 48840 mWh
-Total capacity: 41925 mWh
-current capacity: 41925 mWh
-charge/discharge rate: +2.3 W
-Tension (voltage): 10491 mV
-wear level: 14.16%
-total discharge cycles: 7
The most common reason a system will power off besides a lack of power would be overheating. I would run a tool like speed fan to track your system temperatures. If they are getting to high CPU >90C
Neemobeer
Windows Forum Team
4uzindian
try setting your power options.also check advanced power options .as previously mentioned if it is over heating you might try cleaning your fan.it might have a lot of fuzz in it .
