Welcome!
By registering with us, you'll be able to discuss, share and private message with other members of our community.
SignUp Now!
Windows 10 Is there an inherent problem in Windows 10 basic typing?
hamsimp
When using the on-screen keyboard, if I type a capital letter immediately after an opening quotation mark, it screws up the computer so badly that I have to trick the computer into allowing me to save my work, and then reboot the computer. It appears to be a windows 10 problem because it has happened on my last 3 windows 10 computers. The only other possibility I can think of is it happens most when I am posting on Quora. Is anyone here familiar with this problem, and is there a solution?
i don't use Quora but i do use the touch keyboard a fair bit and have never had the issue of a lock up
if you make quote links here in this forum does the same issue pop up?
I'll give it a try "This" ought to be good enough. Well what do you know it's a Quora problem. "I guess i'll start writing my Quora "Posts" in a note pad and paste them into Quora. Thanks "For" "The" "Help" ussnorway:)
