Windows 7 Keyboard and Mouse problem
chugnalng
Awakening from overnight sleep mode keyboard and mouse lockup. They are fine for opening explorer 8 and when I try yo open a link the puter freezes. I have to shutdown with the on and off button to reboot. Then all is well. Any solutions?
Aspire 5515
So many years of Sleep/Hibernating and still so many issues. I don't even use Sleep or hibernate, I just set the displays to shut off after 1 hour and the hard drive to shut off after 2 hours.
Are you using wireless devices? If so, and if they are Microsoft devices, there are, I believe, 2 HID updates available that might help. Windows update should find and install them automatically if you have it setup that way.
If not wireless, are they wired USB or PS/2 devices? Serial?
mike2k9
chugnalng
Thanks Mike!
It's a notebook....touchpad & keyboard.......updates are automatic. I close the lid for the night and it goes into sleep mode.
Doesn't happen unless it sleeps along time (probably a coma) ......Its not really that important.....just curious
Dan
