Peter H Williams
Just decided to use a second PC and trying to network.
Desktop 1 see a Media Server on Desktop machine (an Acer PC) but does not show computer in File Explorer
Desktop 2 sees Desktop 1 (I call STONE) and can access files etc
I believe I have the 'discoverable boxes ticked
Both can see the Brightbox2 router
Both run Windows 10
Not sure what to look for to change / check etc
Make sure they are both in the same workgroup
Make sure these are enabled on both devices under the network adapter properties
38135
Make sure the following two services are enabled and running
38136
Also verify your firewall profile is set to private
From a powershell prompt you can type Get-NetConnectionProfile and look at the NetworkCategory property it should say Private
Neemobeer
Windows Forum Team
38135
38136
Peter H Williams
Many thanks for such speedy response.
FDresPub was not running on Desktop2 - starting this seems to have solved the problem
Both are in WORKGROUP
I assume the graphics information is in Device Manager - if so can't see anything like above
Thanks again
