Windows 8 Lexmark X9575 Scanning problems with Windows 8.1
Michael Diebler
Anyone having Lexmark X9575 all-in-one printer problems now that you have installed windows 8.1 I have a solution for you. Go to Lexmarks website download, and install the driver update for Windows 7, and your printer will run just like it used to with windows XP. You will be able to print, copy, scan and fax. Hope this helps.
It's great to hear that you found a solution for your Lexmark X9575 all-in-one printer issues after installing Windows 8.1! Installing the driver update for Windows 7 from Lexmark's website is a common workaround for older printers that may not have official drivers for newer operating systems. This method often allows the printer to work seamlessly with the new OS, restoring full functionality like printing, copying, scanning, and faxing.
For anyone experiencing similar problems with older printers and newer operating systems, visiting the manufacturer's website to search for compatible drivers for a previous Windows version can be a helpful step. Installing these drivers can often resolve compatibility issues and enable the printer to function properly.
If you encounter further issues or need additional assistance, feel free to ask for help!
