voyager
I am in the process of cleaning and neatening up my PC.
My PC has 6 drives:
(C:) - Primary - M.2 - 1TB O.S. Drive - 3 Win Install partitions
(D:) - Primary - SSD - 1TB Installation Drive - 1 Partition
(E:) - Primary - HDD - 2TB Data Drive - 1 Partition
(F:) - Primary - HDD - 2TB Data Drive - 1 Partition
(G:) - Primary - HDD - 4TB Data Drive - 1 Partition
(H:) - Logical - HDD - 2TB Data Drive - 1 Partition
C: & D: need to be Primary & Active because of the OS and installed applications.
My conceen is with drives (E:), (F:) and (G:).
They're DATA drives and have no need to be active primary drives or partitions.
I would like to convert them to being logical, but worry about DATA loss.
Can they be converted to logical without DATA loss?
An image from 'My PC has 6 drives'. Disk Management showing multiple NTFS partitions across seven disks, all healthy.
Untrue, malware can just as easily install on any of those drives and run; however, most malware generally installs in well-known locations. The only meaningful reason to use primary vs logical is that Windows needs to be installed on a primary partition.
voyager
I see that there is.
A primary drive/partition can be made active, which these already are.
Which tells me that actions can be initiated from them as in drives C: and D:, by installed apps.
By everything as I understand, malware and other things could be installed there and be active.
If they're logical they should be inert.
Neemobeer
Windows Forum Team
voyager
OK, I think I may be beginning to understand why I'm having so much trouble trying to convert drives E/ thru G/ to being Logical drives.
MBR drives, D/: and H/: can have both primary and logical partitions.
C/:, E/:, F/:, and G/: are GPT drives.
Their 1st partition must be primary.
C/: requires primary because of the OS.
I set D/: as primary because of plans to install applications there rather than on C/:.
E/:, F/:, and G/: have a single partition and are GPT.
H/: is MBR allowing it to have its single partition to be logical.
Don't know how clear that is to everyone else, but I understand it.
I may not like it.
But, I now understand that's how the world works.
Neemobeer
Windows Forum Team
Having an extended partition allows you to create 1 or more logical partitions, this was/is a way to overcome the 4 partition limit on an MBR disk. GPT can handle 128 partitions so doesn't have the limitation and no reason for having logical partitions.
