hawkeye62
I am using IE 11.0.9600.17690, update version 11.0.17 on windows 8.1 64 bit. Very often I get a window that pops up with a message that IE has stopped working. If I ignore the message and click to close the window, IE works as if nothing had happened.
Does anyone know if this is a known issue? Maybe I have something wrong with my configuration?
Thanks for any advice.
Regards, Jim
Jimbo22
What if any add-on's and or extensions do you have installed in IE? Have you tried resetting IE to default settings?
hawkeye62
Thanks for your reply.
I don't have any extensions. I really haven't done any setting changes other than syncing Favorites across my Windows 8.1 PCs.
I guess this not some known issue?
Regards, Jim
