Windows 7 No sound on PC with GT 520 graphic card
xsone
First of all hello everyone on this forum, I am new here, and I hope that you might help me to solve this problem.
I googled past few days, and also searched topics on this forum but I couldn't find a solution.
I recently got new Leadtek WinFast GT 520 grapihic card, I bougth it because I don't use my PC for gaming or so, and after installing new OS ( Windows 7 x64 SP1) I don't have sound, speaker aren't detected, just HDMI outputs, and some kind of virtual spakers. I tried all kind of drivers, updates, enabled on board audio on motherboard in BIOS, anything I colud find online, I checked ports for speakers, even the speakers them selves, it's working. I tried with frend's graphic card, and with it I have audio.
So if someone knows how to slove this problem...please.
So if...
Please check in device manager to see if the driver is installed and working properly.
Please go to start>search>type device manager. (for Win 7 and Vista)
Are there any "unknown devices" with yellow triangles on them?
Is you driver there , listed, and working? (specifically sound devices)
If your driver is missing, or there is a yellow triangle on it, you will need to update it.
No, nothing like that, under "sounds" in device manager, I see NVIDIA High Defenition Audio and Realtek High Defenition Audio, btw I installed the newset realtek audio drivers...
If you right click on the speaker icon in your system tray and goto playback devices and select speakers and select as default. Hopefully you'll now have sound through your speakers.
HTH
Tried that already, but no sound again. Even when I unplug speaker from jack, they are shown as playback device.
How are you getting the HDMI audio? Are you using a SPDIF cable to the video card?
I would probably look for something that gives your the choice of type of audio out. Perhaps the one you have set now will not allow for the other one to work. Possibly the bios settings, or in the control panel of either the Basic Windows or Realtek mixer dialog windows.
Also make sure you are using the correct connections. The ports can be changed by the system depending on your configuration.
