IT Fachbereich
- Joined
- Nov 2, 2010
Hi.
I don't know if this is the right forum for my problem.
Anyway,
I have a problem with my Windows Services.
Each time when I launch Windows Services window, I get a warning:
One or more activex controls could not be displayed because either:
1. your current security settings prohibit running activex
controls on this page, or
2. you have blocked a publisher of one of the controls.
as a result, the page may not display correctly.
The warning pop-up opens only when I click on Extended tab.
The problem has nothing to do with IE security, because I can open pages with ActiveX controls on them and so.
I have installed Spybot spyware/malware removal tool. Then uninstalled it.
I'm not sure if this is the cause of the problem. But I presume it is.
So, may be someone was facing the same problem and knows the cause for it.
Thanks.
Anyway,
Thanks.
