SyazSkylex
UEFI legacy disabled - Operating system not found
Hi , well I'm trying to install remix os
It says I should disable secure boot
then I go to advance startup option to get into boot menu shift+restart
then i change something called uefi to lagacy to disable secure boot
Then I save n restart boom!
My laptops saids " operating system not found "
I tried press esc f1-f12 del not working
I need to go to the advance startup option OR boot menu
Acer V5 132 NO DVD
PLEASE HELP ME
Secure boot should be it's own setting. You don't need to switch from UEFI to legacy (MBR) nor do you really need to turn off secure boot for most linux distros.
