iOftheStorm
Hi guys.
Unfortunately I have lovely neighbours who keep hacking me and have done on my windows laptop for the last 7 months.
I want to switch off any facilities that allow them to make any changes to the laptop that will cause it to have problems.
So I would like network sharing off. Remote Desktop and remote admin and also any vpn site to site connections because they use them on all devices.
They have set up a Smb file share on my router.
How do I use the internet without them being able to play around and mess up my laptop.
It’s the second time it’s been wiped.
Also does anyone know how I can create a recovery usb and how I use it if I need it.
I have an updated Lenovo yoga 500 that was updated from win 8 to win 10 please help.
No, you can only Jailbreak up to iOS 11.1.2 at the moment, and if you restored, that means you're on a later version. I recommend you root the Android device using something such as KingRoot, or if you feel safe doing it and your device is supported, flash a custom recovery menu and root it, then use an application such as this to delete the files(because you will be the "root" user with this app and have all permissions)
libcrypto is a library for SSL, so I wouldn't be too worried about that file in general, but those being dumped is very suspicious. Where are these files dumped to? (What is the path)
The lib files seem to vary from device to device there is one called boringSSL another one libxml2 liboauth2 I think they are messing with the certificates on my devices and cracking passwords by tricking the phone into thinking it’s making an https connect but it’s http because when I’ve run a http sniffer before I reach the website I want I’m getting redirected and also I’ve put into my chrome browser Link Removed or whatever the site is and it’s got stuff about token data when they were last Downloaded. There’s like a table of things that are to be synced and it includes my credit card data which has been stored and I can’t get off I’ve reported it to the police now but they aren’t quick to react. They are taking forever. There was mention of them moving. But it won’t matter if they have that direct connection because I’ve noticed when I do a port scan over my local host when I’m away from home there is an open port named stun p1 when I’ve googled it. It’s to do with a Cisco tunnel. And that happens on mobile data and any other Wifi other than mine. If you do a port scan over my broadband ip I’ve got 80 http 139 netbios 443 smb over ip Microsoft ds 445 https 8080 sun answerbook gnu something and 10000 Amanda back up utility. These ports were not opened by me and were opened before I connected my laptop. I’m wondering does this mean they have a pc connected directly to my internet constantly. When you do a scan over my public ip (which is meant to be dynamic) but never changes I get port 7 echo port 21 22 and another port with pptp open for it there is more but can’t remember off the top of my head.
Oh yeah and for my streaming devices like chrome cast and fire stick they have set open ports that say apache jserv 3 I think it is have no idea what that means either if I posted something do you think you could try to make sense of it because I think they’ve routed my ipv4 and ipv6 to make it static
I used an app called landroid that tells you About your network and here was a recentish read of it
Should my net mask be 0.0.0.0
Interfaces:
dummy0
MAC: a2:4e:97:92:87:e9
sit0
p2p0
MAC: d6:0b:1a:5e:0f:74
lo
IPv6: ::1
IPv4: 127.0.0.1
rmnet_usb0
MAC: a2:4c:70:ae:34:fe
wlan0
IPv6: fdaa:bbcc:ddee:0:6897:ff42:1f05:e3c3
IPv6: 2a00:23c4:4f0f:a200:6897:ff42:1f05:e3c3
IPv6: 2a00:23c4:4f0f:a200:d60b:1aff:fe5e:f74
IPv6: fe80::d60b:1aff:fe5e:f74
IPv6: fdaa:bbcc:ddee:0:d60b:1aff:fe5e:f74
IPv4: 192.168.1.68
MAC: d4:0b:1a:5e:0f:74
Bytes: 90,609 IN, 21,450 OUT
Packets: 163 IN, 215 OUT
rev_rmnet0
MAC: ce:ff:22:0b:02:ae
rev_rmnet1
MAC: fa:54:aa:ee:f9:47
rev_rmnet6
MAC: 06:1f:05:28:38:6e
rev_rmnet5
MAC: ce:a1:eb:f5:32:72
rev_rmnet7
MAC: d6:ba:ad:44:3d:99
rev_rmnet3
MAC: ca:a5:b8:fc:03:3d
rev_rmnet2
MAC: e6:09:ee:80:a1:5f
rev_rmnet4
MAC: 2a:96:f2:26:e3:65
rev_rmnet8
MAC: 0a:c5:be:1c:de:b0
rmnet0
rmnet1
rmnet6
rmnet5
rmnet7
rmnet3
rmnet2
rmnet4
Ipv4 Routes:
192.168.0.0/255.255.0.0 dev wlan0
192.168.1.254/255.255.255.255 dev wlan0
default via 192.168.1.254 dev wlan0
IPv6 Routes:
2a00:1450:4009:809::200a/128 via fe80::42c7:29ff:fe17:7c25 dev wlan0
2a00:1450:4009:80a::2004/128 via fe80::42c7:29ff:fe17:7c25 dev wlan0
2a00:1450:4009:80a::200e/128 via fe80::42c7:29ff:fe17:7c25 dev wlan0
2a00:1450:4009:80c::200a/128 via fe80::42c7:29ff:fe17:7c25 dev wlan0
2a00:1450:400c:c09::bc/128 via fe80::42c7:29ff:fe17:7c25 dev wlan0
2a00:1450:4010:c0d::bc/128 via fe80::42c7:29ff:fe17:7c25 dev wlan0
2a00:23c4:4f0f:a200:6897:ff42:1f05:e3c3/128 dev lo
2a00:23c4:4f0f:a200::/64 dev wlan0
2a00:23c4:4f0f:a200:d60b:1aff:fe5e:f74/128 dev lo
::1/128 dev lo
default dev lo
default via fe80::42c7:29ff:fe17:7c25 dev wlan0
fdaa:bbcc:ddee:0:6897:ff42:1f05:e3c3/128 dev lo
fdaa:bbcc:ddee:0:d60b:1aff:fe5e:f74/128 dev lo
fdaa:bbcc:ddee::/64 dev wlan0
fe80::/64 dev wlan0
fe80::d60b:1aff:fe5e:f74/128 dev lo
ff00::/8 dev wlan0
ff02::1/128 dev wlan0
ff02::1:ff05:e3c3/128 dev wlan0
Wifi connection:
AP(BSSID): 40:c7:29:17:7c:28
Name(SSID): "BTHub6-MX3S"
Signal(Rssi): -70
IP: 192.168.1.68
Netmask: 0.0.0.0
Gateway: 192.168.1.254
Dns1: 8.8.8.8
Dns2: 0.0.0.0
Dhcp Server: 0.0.0.0
Lease duration: 0s
Sockets Information:
sockets: used 211
TCP: inuse 0 orphan 0 tw 2 alloc 1 mem 1
UDP: inuse 0 mem 0
UDPLITE: inuse 0
RAW: inuse 0
FRAG: inuse 0 memory 0
See how the ip is being routed I just don’t understand how to explain this to the internet provider Bt
My home hub doesn’t have Mac filtering plus I’ve had upto like 9 Mac spoofed Mac addresses a day. I reckon they are using a pentesting tool particularly metasploit just because of all the information I’ve been researching. I’ve been sending the details to Bt internet security team so I’m waiting for a call off them tomorrow.
As to regard to the neighbours. I think one of them is a software programmer because I’m pretty sure they’ve changed they flashed my router because it’s not booting up like it did before I moved. The only reason I know it’s them is because of thin walls and them boasting about it.
And these people are clearly damaged to be constantly connecting to my internet atleast once a day. Why bother ??
My life is so uninteresting.
Im thinking of getting a professional in but it’s so expensive plus. They are Cisco trained. Everything they are doing is Cisco network related like a lot of the stuff that I’ve accidentally come across and google has come straight up with Cisco related information.
I’m also annoyed by the fact that not only have they hacked my internet but when they have they have also hacked each device connected and add a site to site vpn so when I’m away from my house on someone else’s Wifi or on my mobile data they can still access whatever I’m using.
So pathetic!
Anyone wanna house swap lol
May be he has your mac address
that why he always know your wifi password
U can reset your router and enable to mac binding
and allocate your IP address
change your ssid and change your security on wp2 encrryption
then u can protect your pc as well wifi data
When I factory reset the router the last time it was showing 2 WiFi’s with the same name and on was wep key and one was wpa2 I got the screen shots on my iPhone but when I connect it’s saying I got wpa 2. Unfortunately my Bt home hub doesn’t allow for all that I don’t have a separate router. I’m scared to go out and pay over 100 pound for one. And for them to damage it by flashing it with a Linux based kernel which is what they seem to be doing with all my devices
If I make a list of some of the lib’s could you give me an idea of what they are for / doing to my device because they also flashed my PS4 and I would like to know what’s going on with that as well
If your ISP has IPv6 then none of that output is unusual
They said they don’t support it yet when I spoke to them so how is that possible
Buddy, you can make your mac binding on your router
and relieve this problems
If there are open ports on the router going to the Internet, MAC address filtering will not prevent wide area network attacks. Although it does sound like someone is directly accessing LAN traffic. Either way, if the router is compromised, MAC address filtering is useless since someone can just turn it off. Hey, do we know for sure this is real hacking? Who are your neighbors, members of the CIA or something? If the router has been hacked, file a police report and tell them to knock it off. Maybe you can get them on damage to property, unauthorized access of a computer system or network, etc. Maybe you could reflash the router and harden the password, but how did they get in originally? If they used WIFI, most routers will reject requests to access the gateway/admin console, by default, from WiFi. Also, maybe you should just buy a new router :/
No. There is a long explanation for this, but lets not get into it. Either way, that is not a "real" IP address. It literally means the range of IP addresses you can use on your network is nothing. You would want it, in most instances, to be 255.255.255.0.
It's a cell phone, they do support IPv6. The Ipv6 address that start with FF or FE are local addresses. The ones that start with 2 are resolvable over the internet. I believe those 2a00... are all google addresses
I’ve done all you’ve said bin the past and they are quick enough to run to the police. They don’t leave the house honest. So they just have time on their hands I reckon. Yup they have lan access I can’t tell you that for a fact as I’m seeing spoofed Mac addresses on my technical logs on the router. If I go out and buy another router how do I know they won’t pentest that one and get through.
:cry_smile:
But 0.0.0.0 is show as key mask
I wasn’t using a SIM card at the time just Wifi
The subnet mask typically comes as an option from the dhcp server and since you have no dhcp server listed (also 0.0.0.0) you wouldn't get the mask
