LALynn1253
- Joined
- Feb 11, 2018
- Messages
- 3
- Thread Author
- #1
- Joined
- Aug 28, 2007
- Messages
- 36,159
eed_ec.dll file is part of the Samsung printer driver known as the Samsung Easy Eco Driver.
Try running these scans and if they fail to help re-install the above driver:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
File scans
sfc /scannow
LALynn1253
- Joined
- Feb 11, 2018
- Messages
- 3
- Thread Author
- #3
- Joined
- Aug 28, 2007
- Messages
- 36,159
LALynn1253
- Joined
- Feb 11, 2018
- Messages
- 3
- Thread Author
- #5
Ok thanksTry the scan first.
Similar threads
- Replies
- 0
- Views
- 49
- Solved
- Replies
- 9
- Views
- 1K
- Replies
- 1
- Views
- 733
- Solved
- Replies
- 1
- Views
- 886
