Windows 7 Problem with font apperance.
randycmj98
I need help here ! I cant get this " 1 " back straight . Most of the word i view in internet and games is all in Italic .
Any suggestion to help me out ?
Link Removed due to 404 Error
Try right-clicking on the desktop and choose personalize. Now click the Windows color entry, the the Advanced appearance settings and change the fonts here.
Don't mess around with any other entries as you will loose he Aero effects.
Now exit out and see if thisfthe problem./
Sorry, only allows 2.0MB
All I can say is find them on the Internet, you have the names
Do a google search for each one of the following
Calibri
Cambria
Consolas
Georgia
Segoe UI Symbol
Verdana
search Calibi font and go through the list
Calibri
Cambria
Consolas
Georgia
Segoe UI Symbol
Verdana
nono. i want to check out something there . Can you tell me ?
Are you an advanced user?
One mistake in the registry and your system will not boot.
Then just open Regedit and navigate to the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Font Management key
hmm , could you send me verdana regular font ? i try see whether its fix the italic problem. i cant find it on google.
And can you try pack up all win 7 fonts upload to some sites i download them from there ( try mediafire )
