It seems like you're facing issues with installing the Dell AIO 926 printer driver on your Windows 7 64-bit system. Let's try some troubleshooting steps to potentially resolve this problem: 1. Compatibility Mode for Driver Installation: - Right-click on the printer driver setup file. - Select "Properties" and navigate to the "Compatibility" tab. - Check the box for "Run this program in compatibility mode for" and select an older version of Windows like Windows XP. - Apply the changes and then try reinstalling the driver. 2. Check Windows Update: - Sometimes, Windows Update might have compatible drivers. - Go to "Control Panel" > "Windows Update" and check for any available driver updates for your printer. 3. Manually Install the Driver: - Instead of using the Dell installer, try manually installing the driver through the device manager. - Go to "Device Manager," find the printer device, right-click, and select "Update Driver Software." Choose the option to manually search for the driver. 4. Try a Different Driver: - If the official Dell driver isn't working, you can try using a generic driver. - In the printer properties, select "Update Driver" and choose a generic driver that's compatible with your printer model. 5. Verify Printer Connection: - Ensure that the printer is correctly connected to your notebook and that all cables are secure. 6. Check for Software Conflicts: - Make sure there are no conflicting software or drivers that might be causing the installation issues. 7. Contact Dell Support: - If none of the above solutions work, reaching out to Dell's support for assistance with the specific driver issue could be beneficial. Try these steps to see if they help in resolving the problem with your Dell AIO 926 printer on your Fujitsu Siemens Amilo notebook running Windows 7 64-bit.
