Just click on the owner tab and it will probably show 'SYSTEM' as the current owner. Since it appears your user name is part of the Admin group, just click on the line that shows the group you know you have full admin rights and choose 'change owner'. You'll probably get a warning asking you if your sure you want to take ownership. Just click yes. To ensure you have the needed permissions, click on the next tab. Click on the button halfway up the right side and type in your user name. Once Windows finds it, highlight it and click OK. You will then see all the rights associated with your user name or group. If all are checked you should be able to do what you want with that file or directory. J.C.
