cybercore
BugCheck 3B, {c0000005, fffff960000ffbc8, fffff88006275160, 0}
Probably caused by : win32k.sys ( win32k!xxxDestroyWindow+160 )
I don't see much sence in reading your new dumps: you keep getting same messages related to memory. Even if you update ATI and Realtek audio to the latest, and even if you reformat and reinstall, it won't fix you at all. You can try if you have the faith.
What I suggest is that you turn on Cool and Quiet and diagnose your hardware starting with RAM:
10 passes overnight Memtest86+ - Advanced Memory Diagnostic Tool
It doesn't always detect errors right away, and is recommended to test sticks separately one by one and in different slots.
HDDScan
HD Tune website
If you haven't, type in the command prompt > chkdsk /f - just in case.
Bios upgrade would be good too.
And again, TURN ON the Cool and Quiet feature. Everything must be at stock.
CRASH DUMPS
Loading Dump File [F:\DMP\033011-29156-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02e61000 PsLoadedModuleList = 0xfffff800`030a6e90
Debug session time: Thu Mar 31 01:09:19.641 2011 (UTC - 4:00)
System Uptime: 0 days 3:03:56.233
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff960000ffbc8, Address of the instruction which caused the bugcheck
Arg3: fffff88006275160, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff960`000ffbc8 488b02 mov rax,qword ptr [rdx]
CONTEXT: fffff88006275160 -- (.cxr 0xfffff88006275160)
rax=fffff900c2153a60 rbx=fffff900c0877f10 rcx=000007ffffff0000
rdx=0080000000000000 rsi=0000000000000000 rdi=fffff900c2153a60
rip=fffff960000ffbc8 rsp=fffff88006275b40 rbp=0000000000000000
r8=fffff80002e61000 r9=0000000000000000 r10=fffff900c2153a60
r11=fffff88006275b10 r12=000000007efd8000 r13=000000000254fd20
r14=000000000254e990 r15=0000000075072450
iopl=0 nv up ei pl nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010206
win32k!xxxDestroyWindow+0x160:
fffff960`000ffbc8 488b02 mov rax,qword ptr [rdx] ds:002b:00800000`00000000=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x3B
PROCESS_NAME: WerFault.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff9600010098b to fffff960000ffbc8
STACK_TEXT:
fffff880`06275b40 fffff960`0010098b : 00000000`00000000 00000000`00000000 fffff880`06275ca0 00000000`00000000 : win32k!xxxDestroyWindow+0x160
fffff880`06275bf0 fffff800`02ee08d3 : fffffa80`080a8490 fffff880`06275ca0 00000000`00e97f10 00000000`00000000 : win32k!NtUserDestroyWindow+0x3b
fffff880`06275c20 00000000`75072e09 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0254e918 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x75072e09
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: win32k!xxxDestroyWindow+160
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4d2415ea
STACK_COMMAND: .cxr 0xfffff88006275160 ; kb
FAILURE_BUCKET_ID: X64_0x3B_win32k!xxxDestroyWindow+160
DRIVERS
start end module name
fffff880`00eba000 fffff880`00f11000 ACPI ACPI.sys Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`040be000 fffff880`04147000 afd afd.sys Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`051d0000 fffff880`051e6000 AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0787b000 fffff880`07990000 am10w7 am10w7.sys Fri Jan 15 03:15:48 2010 (4B502434)
fffff880`04243000 fffff880`04257000 amdiox64 amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
fffff880`01000000 fffff880`01015000 amdppm amdppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00c2a000 fffff880`00c35000 amdxata amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`079c2000 fffff880`079cd000 asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00ff1000 fffff880`00ffa000 atapi atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c00000 fffff880`00c2a000 ataport ataport.SYS Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`0486e000 fffff880`0516a000 atikmdag atikmdag.sys Wed Jan 26 17:48:28 2011 (4D40A4BC)
fffff880`042ea000 fffff880`04338000 atikmpag atikmpag.sys Wed Jan 26 17:13:33 2011 (4D409C8D)
fffff880`0164f000 fffff880`01656000 Beep Beep.SYS Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040a6000 fffff880`040b7000 blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`067cc000 fffff880`067ea000 bowser bowser.sys Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00650000 fffff960`00677000 cdd cdd.dll Sat Nov 20 07:55:34 2010 (4CE7C546)
fffff880`0161c000 fffff880`01646000 cdrom cdrom.sys Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00cff000 fffff880`00dbf000 CI CI.dll Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`019af000 fffff880`019df000 CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00ca1000 fffff880`00cff000 CLFS CLFS.SYS Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01108000 fffff880`0117a000 cng cng.sys Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`051c0000 fffff880`051d0000 CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`06d50000 fffff880`06d59000 cpuz135_x64 cpuz135_x64.sys Wed Jan 19 11:42:06 2011 (4D37145E)
fffff880`06b47000 fffff880`06b55000 crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`011ad000 fffff880`011cb000 dfsc dfsc.sys Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`04097000 fffff880`040a6000 discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01999000 fffff880`019af000 disk disk.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06652000 fffff880`06674000 drmk drmk.sys Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06b61000 fffff880`06b6a000 dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06b55000 fffff880`06b61000 dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06b6a000 fffff880`06b7d000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06b7d000 fffff880`06b89000 Dxapi Dxapi.sys Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`02c55000 fffff880`02d49000 dxgkrnl dxgkrnl.sys Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`02d49000 fffff880`02d8f000 dxgmms1 dxgmms1.sys Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`066cd000 fffff880`06703000 fastfat fastfat.SYS Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01089000 fffff880`0109d000 fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0103d000 fffff880`01089000 fltmgr fltmgr.sys Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0122c000 fffff880`01236000 Fs_Rec Fs_Rec.sys Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0195f000 fffff880`01999000 fvevol fvevol.sys Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`0186c000 fffff880`018b6000 fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`02de6000 fffff880`02df3000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02e18000 fffff800`02e61000 hal hal.dll Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`02d8f000 fffff880`02db3000 HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`06afd000 fffff880`06b16000 HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`06b16000 fffff880`06b1e080 HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06aef000 fffff880`06afd000 hidusb hidusb.sys Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`06703000 fffff880`067cc000 HTTP HTTP.sys Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01956000 fffff880`0195f000 hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`02c1d000 fffff880`02c3b000 i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`02c3b000 fffff880`02c4a000 kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00b97000 fffff800`00ba1000 kdcom kdcom.dll Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04200000 fffff880`04243000 ks ks.sys Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`01200000 fffff880`0121b000 ksecdd ksecdd.sys Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`015b7000 fffff880`015e2000 ksecpkg ksecpkg.sys Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`06674000 fffff880`06679200 ksthunk ksthunk.sys Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06bdb000 fffff880`06bf0000 lltdio lltdio.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06b97000 fffff880`06bba000 luafv luafv.sys Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c80000 fffff880`00c8d000 mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`06b89000 fffff880`06b97000 monitor monitor.sys Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`043e1000 fffff880`043f0000 mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06b1f000 fffff880`06b2c000 mouhid mouhid.sys Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00dcf000 fffff880`00de9000 mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`01400000 fffff880`01431000 MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`0799d000 fffff880`079ad000 MpNWMon MpNWMon.sys Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`019df000 fffff880`019f7000 mpsdrv mpsdrv.sys Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06cb2000 fffff880`06cdf000 mrxsmb mrxsmb.sys Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`06cdf000 fffff880`06d2c000 mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`06d2c000 fffff880`06d50000 mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`013e6000 fffff880`013f1000 Msfs Msfs.SYS Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f1a000 fffff880`00f24000 msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010aa000 fffff880`01108000 msrpc msrpc.sys Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0408c000 fffff880`04097000 mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01944000 fffff880`01956000 mup mup.sys Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01464000 fffff880`01557000 ndis ndis.sys Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`051e6000 fffff880`051f2000 ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`06800000 fffff880`06813000 ndisuio ndisuio.sys Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`0435c000 fffff880`0438b000 ndiswan ndiswan.sys Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`01015000 fffff880`0102a000 NDProxy NDProxy.SYS Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`041d1000 fffff880`041e0000 netbios netbios.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04147000 fffff880`0418c000 netbt netbt.sys Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01557000 fffff880`015b7000 NETIO NETIO.SYS Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`079ad000 fffff880`079c2000 NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`0117a000 fffff880`0118b000 Npfs Npfs.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04080000 fffff880`0408c000 nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e61000 fffff800`0344b000 nt ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`01243000 fffff880`013e6000 Ntfs Ntfs.sys Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`01646000 fffff880`0164f000 Null Null.SYS Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`04269000 fffff880`04282000 nusb3hub nusb3hub.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`02db3000 fffff880`02de4000 nusb3xhc nusb3xhc.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`0667a000 fffff880`066cd000 nwifi nwifi.sys Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`04195000 fffff880`041bb000 pacer pacer.sys Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00f64000 fffff880`00f79000 partmgr partmgr.sys Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00f24000 fffff880`00f57000 pci pci.sys Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00fea000 fffff880`00ff1000 pciide pciide.sys Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00dbf000 fffff880`00dcf000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121b000 fffff880`0122c000 pcw pcw.sys Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06d59000 fffff880`06dff000 peauth peauth.sys Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06615000 fffff880`06652000 portcls portcls.sys Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c8d000 fffff880`00ca1000 PSHED PSHED.dll Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0109d000 fffff880`010a9040 PxHlpa64 PxHlpa64.sys Tue Oct 20 14:08:42 2009 (4ADDFCAA)
fffff880`04338000 fffff880`0435c000 rasl2tp rasl2tp.sys Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`0438b000 fffff880`043a6000 raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`043a6000 fffff880`043c7000 raspptp raspptp.sys Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`043c7000 fffff880`043e1000 rassstp rassstp.sys Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0402f000 fffff880`04080000 rdbss rdbss.sys Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`015f2000 fffff880`015fb000 RDPCDD RDPCDD.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01456000 fffff880`0145f000 rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01236000 fffff880`0123f000 rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0190a000 fffff880`01944000 rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`06813000 fffff880`0682b000 rspndr rspndr.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04800000 fffff880`0486a000 Rt64win7 Rt64win7.sys Wed Feb 16 04:03:57 2011 (4D5B92FD)
fffff880`00c35000 fffff880`00c7cc00 RtHDMIVX RtHDMIVX.sys Tue Nov 23 05:27:12 2010 (4CEB9700)
fffff880`06842000 fffff880`06ad1280 RTKVHD64 RTKVHD64.sys Wed Dec 29 22:52:42 2010 (4D1C020A)
fffff880`06c00000 fffff880`06c0b000 secdrv secdrv.SYS Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`02c11000 fffff880`02c1d000 serenum serenum.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`041e0000 fffff880`041fd000 serial serial.sys Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01902000 fffff880`0190a000 spldr spldr.sys Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0751d000 fffff880`075b6000 srv srv.sys Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`074b2000 fffff880`0751d000 srv2 srv2.sys Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`06c0b000 fffff880`06c3c000 srvnet srvnet.sys Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`02c4a000 fffff880`02c4b480 swenum swenum.sys Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01668000 fffff880`0186c000 tcpip tcpip.sys Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`06c3c000 fffff880`06c4e000 tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`013f1000 fffff880`013fe000 TDI TDI.SYS Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`0118b000 fffff880`011ad000 tdx tdx.sys Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`0401b000 fffff880`0402f000 termdd termdd.sys Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`005d0000 fffff960`005da000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`011cb000 fffff880`011f1000 tunnel tunnel.sys Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`04257000 fffff880`04269000 umbus umbus.sys Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`06ad2000 fffff880`06aef000 usbccgp usbccgp.sys Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`02de4000 fffff880`02de5f00 USBD USBD.SYS Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`02c00000 fffff880`02c11000 usbehci usbehci.sys Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04282000 fffff880`042dc000 usbhub usbhub.sys Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`02df3000 fffff880`02dfe000 usbohci usbohci.sys Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0516a000 fffff880`051c0000 USBPORT USBPORT.SYS Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06b2c000 fffff880`06b47000 USBSTOR USBSTOR.SYS Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`00f57000 fffff880`00f64000 vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01656000 fffff880`01664000 vga vga.sys Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01431000 fffff880`01456000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00f79000 fffff880`00f8e000 volmgr volmgr.sys Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00f8e000 fffff880`00fea000 volmgrx volmgrx.sys Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`018b6000 fffff880`01902000 volsnap volsnap.sys Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`07990000 fffff880`0799d000 vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`041bb000 fffff880`041d1000 vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`04000000 fffff880`0401b000 wanarp wanarp.sys Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`015e2000 fffff880`015f2000 watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e07000 fffff880`00eab000 Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00eab000 fffff880`00eba000 WDFLDR WDFLDR.SYS Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0418c000 fffff880`04195000 wfplwf wfplwf.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00030000 fffff960`00341000 win32k win32k.sys Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`00f11000 fffff880`00f1a000 WMILIB WMILIB.SYS Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06bba000 fffff880`06bdb000 WudfPf WudfPf.sys Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`079cd000 fffff880`079fe000 WUDFRd WUDFRd.sys Sat Nov 20 05:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`07800000 fffff880`0780a000 umpass.sys
Checksum: 00000000
ImageSize: 0000A000
fffff880`07871000 fffff880`0787b000 umpass.sys
Checksum: 00000000
ImageSize: 0000A000
fffff880`075b6000 fffff880`075e7000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
fffff880`07800000 fffff880`07871000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`019df000 fffff880`019ed000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`019ed000 fffff880`019f9000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`01600000 fffff880`01609000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`01609000 fffff880`0161c000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
