StefaNafetS
Bad sound quality( after installing Realtek latest driver?)
I just installed the latest driver and now the sound qulity is notso good as before even i ddint change anything in my realteck manger. I dont know if it counts but I my windows is installing automatically another driver HD audio device but I dont think that matter since I have that disabled and even uninstalled once just to see if affects the quality but nothing. About the sound quality I will try to make a descriprton even my english is not 100%:
its like my system is trying to reproduce an rough coarsed acousting sound and my sub sounds are distorted with a tremble. plus anoying scarts and squeakies, screechings when u play for ex a instrumental track
Here some captureLink Removed due to 404 ErrorLink Removed due to 404 Error
These are my motherboard specs http://www.asus.com/Motherboards/Intel_Socket_775/P5GCMX1333/#overview
I have attached what I show in my Device Manager for Sound devices. The driver from the Asus website should be good, but you never know. Showing an HD device is fairly normal as far as I know.
But I did have something happen yesterday that was a little strange. My sound was being distorted like I was going through a reverb. I noticed in my mixer settings there was a listing for HD audio volume level. I turned it down and the distortion stopped. The attachment does not show it today, but it was listed like the others.
If not that, check the Realtek settings to see if you have any special effects settings turned up. Also you might adjust which volume source is highest. A good mix between the speaker output on the speaker and the...
If I understand, on your attachment, the HD Audio Device is not there currently, but the HD device with the Yellow exclamation mark is?
It seems you have had problems about a sound device not installing correctly, as per your comments about Windows attempting to add a driver. If you right click the yellow mark and select update drivers, does anything happen? It might be good to get the basic driver straightened out prior to reinstalling the Realtek drivers.
As you can see from Trouble's attachment, a video card can cause some sound devices to be installed. Nvidia will install HD sound drivers if you have a video card that uses them.
On one of my systems with onboard Intel Video and Audio, I have an Intel Display audio device in the Sound section which you saw in an earlier attachment. But the Graphics driver and audio driver are on the referenced site. If you have both versions loaded on your system, it should have all the audio drivers it needs.
When I install a new system, I will always load the chipset drivers first.....you probably already have those.
Hmmmm....lets discuss about the current situation..its too much hassle if talking about previous facts.So yesterday Ive unistalled and install my realtek driver..again.At the time prior to uninstalling I had besides realtek the HD audio device and most recently a driver from my webcam( I bought these days a web cam).When I uninstalled Realtek from control panel I remained with no audio playback device so I guess I dint had any driver left too.This is weird cause I should remined with that HD audio device at least and still be able to play audio.And how I ve reported winows tried to instlla this but Ive got that warming about unsuccessfull installation.So I guess this HD is an issue. After installing realtek again however the hd appeared in my sound devices but I doubt its working properly even doesnt have the warning sign .
And how I've reported Windows tried to install this but I've got that warming about unsuccessful installation. So I guess this HD is an issue.
You have mentioned Windows is failing to install some device, but I don't see you trying to find out why.
Trouble showed you how to get the information about a device that we could use to make sure exactly what device it is. For instance, my Intel(R) Display Audio device is showing the following for Hardware IDs:
HDAUDIO\FUNC_01&VEN_8086&DEV_2805&SUBSYS_80862805&REV_1000
From such information, we might be able to track down what your device is. We seem to have the same sound and video devices on our Motherboards. So yours should look like mine. The Intel Display Audio and the Realtek High Definition Audio should show in Device Manager. I am not sure what the Intel Display Audio does, but it might be for the HDMI output. I did have this system connected to a TV with an HDMI input. If you show an unknown device, we can still use the info, so go to the properties of any yellow marked device listing and under the Details Tab, select Hardware IDs and it will give you a listing as in the attachment.
