Start iTunes with computer, but show GUI
mknabster
Hello all! I have a Windows Server 2016 box where i would like iTunes to start automatically when the computer boots up. I was able to successfully set the task up in task scheduler, but it started hidden, despite the hidden check box not being checked. I do occasionally use this computer to play music locally, so i would like to be able to see the GUI. Is there an argument i should be using for this task? Thanks!
Use a logon script or just put a shortcut in the start up folder. There's no reason to start it on the system start up since it's a interactive application.
Neemobeer
Windows Forum Team
