The tiny11builder project has received a significant refresh: the PowerShell-based builder now supports Windows 11 version 25H2 builds, adds explicit removal of Copilot and the new Outlook for Windows client, switches to more efficient recovery compression for smaller ISOs, and introduces additional safeguards to block unwanted apps from reinstalling — all while preserving its core approach of using only Microsoft tooling (DISM, the Windows ADK oscdimg, and an unattended answer file) to produce debloated Windows 11 images.
Windows 11 25H2 tiny11builder creates a customized ISO by removing Copilot and Outlook for privacy.Background​
tiny11 and tiny11builder grew from a simple, community-driven idea: give users a way to run a slimmer, faster Windows 11 by removing inbox apps, redundant services, and optional components many people never use. The project is maintained as an open-source PowerShell script that automates image servicing and rebuilds official Microsoft ISOs into lightweight installation media.
The builder is intended to be used with official Microsoft images. It leverages Microsoft utilities — primarily DISM for image manipulation and oscdimg.exe from the Windows ADK for creating bootable ISOs — and uses an autounattend file to allow setup-time customizations such as bypassing the Microsoft Account requirement in OOBE. The project's maintainers emphasize transparency: the scripts are readable, modifiable, and explicitly avoid including non-Microsoft binaries (beyond the ADK’s oscdimg when needed).
A second, more extreme variant — tiny11 Core — exists for users who want the barest bootable environment. Core sacrifices serviceability (WinSxS and many servicing paths are removed) to deliver minimal images suited for rapid testing and tightly constrained VMs, but it is not intended for daily, fully updated systems.
What’s new in the update​
This refresh to tiny11builder introduces several practical and structural changes that matter to anyone building or running custom Windows 11 ISOs.
25H2 compatibility and flexible image support​
  • The builder can now be used with Windows 11 25H2 images as well as other recent builds and editions.
  • The script’s PowerShell rewrite unlocks support for any Windows 11 release, any language, and both major architectures (x64/arm64) — a big step beyond earlier versions that were tied to specific builds or locales.
  • The builder accepts both WIM and ESD source images, giving users more options for input media.
This flexibility makes it practical to build a debloated 25H2 ISO that still benefits from the platform changes Microsoft rolled into 24H2/25H2 while keeping a smaller footprint.
Copilot and new Outlook removal​
  • The updated script includes explicit removal routines for Copilot and the new Outlook for Windows client.
  • These removals aim to keep the base image free of AI assistant and modern mail client components for users who don’t want those integrated features, or who prefer third-party alternatives.
While removing these components reduces on-disk size and attack surface for some users, it also alters the default user experience and could disable features that integrate with Copilot/Outlook.
Smaller ISOs via recovery compression​
  • The builder now uses DISM’s /Compress:recovery option (referred to as recovery compression) during image deployment, which yields significantly smaller final ISOs than previous compression strategies.
  • This change helps fit full installations into much smaller media footprints — the project has public examples showing tiny images that can fit on a single-layer 4.7 GB DVD under particular configurations.
The compression change trades a small amount of CPU time at imaging for meaningful savings in distribution size.
Proactive blocking of reinstallation and small QoL fixes​
  • The update adds more aggressive measures to prevent the reinstallation of certain inbox apps that Windows Update or the Microsoft Store may try to restore.
  • The script includes a handful of quality-of-life fixes and known-issue mitigations (for example, handling remnants in Settings when Edge is removed, and ARM-specific quirks around OneDriveSetup.exe).
  • The project also continues to offer tiny11 Core tooling for users who need an even lighter, non-serviceable image.
How tiny11builder works — technical overview​
The builder follows a consistent, scripted sequence using Microsoft-supported tools and standard image-servicing flows.
  • Prepare: Download an official Windows 11 ISO (or obtain a UUP/ESD image) from Microsoft. Ensure the Windows ADK is available for oscdimg.exe if you plan to make bootable ISOs.
  • Mount/Extract: The script mounts the source ISO and extracts the chosen image edition (WIM or ESD).
  • Service offline: Using DISM, the script applies package removal, optional component removal, feature toggles, language adjustments, and registry tweaks. Common targets include inbox apps (Clipchamp, News, Weather, Xbox components, OneDrive, Media Player, etc., language/voice packs, and telemetry services.
  • Unattend: An autounattend.xml is injected so OOBE can be customized — e.g., bypassing the Microsoft Account requirement and enabling the compact deployment flag.
  • Repack & compress: The image is rebuilt using DISM with /Compress:recovery to get a smaller payload.
  • ISO creation: oscdimg.exe (from the ADK) generates a bootable ISO that can be written to a USB stick or burned to media.
  • Optional Core path: If the tiny11 Core option is chosen, the script strips WinSxS and other servicing components to create the minimal, non-serviceable image.
Key operational notes:
  • The project runs as a PowerShell script and requires execution policy adjustments (Set-ExecutionPolicy Unrestricted) or running PowerShell elevated.
  • For reliability, the script should be executed from an elevated PowerShell session; running with specific invocation flags (e.g., powershell -f path\to\script.ps1) has proven necessary in some environments.
  • The approach intentionally avoids third-party executables for image servicing, favoring Microsoft-supplied tooling for transparency and stability.
Benefits — why enthusiasts and administrators care​
  • Reduced bloat: The primary benefit is a smaller, cleaner OS that lacks many inbox apps and services that many users never use.
  • Smaller install media: Recovery compression and component removal can cut the final ISO dramatically, which is handy for constrained environments or archival purposes.
  • Privacy and surface-area reduction: By removing telemetry-adjacent components and optional services, the image reduces potential telemetry vectors and attack surfaces.
  • Customizable OOBE: The included autounattend allows local-account first-boot setups and other customizations that enterprises or privacy-focused users often want.
  • Open and auditable: The script-based, open-source approach lets users inspect every change before running it — a critical trust advantage over pre-built, third-party ISOs.
  • Flexible image support: Support for ESD and any Windows 11 release makes the tool practical for building images for the latest 25H2 Insider/preview or retail releases.
Risks, limitations, and real-world caveats​
Using a debloater and custom image builder like tiny11builder delivers power — but it also carries tangible risks. These are the major concerns users and admins must weigh.
Serviceability and updates​
  • The tiny11 Core image is explicitly non-serviceable: removing WinSxS and other servicing components breaks the normal patching and feature-installation pathways. That means you cannot easily add languages, features, or cumulative updates after install.
  • Even the regular tiny11 variant can see reinstallation of some apps after major Windows updates or Store repairs. The project adds mitigations, but Windows Update behavior can change and may restore components.
  • Removing key components can complicate future upgrades. Major Windows feature updates and servicing stacks expect certain components to exist; heavy customization increases the chance of upgrade failures or odd compatibility problems.
Security and stability​
  • Stripping components and services can inadvertently remove capabilities relied upon by security features or applications. For example, removing certain platform features could impact anti-malware tooling or Windows Update behavior.
  • Users have reported a range of issues when experimenting with preview releases of Windows on heavily customized images — including boot loops on specific hardware in some cases. Those reports suggest an increased chance of hardware-specific regressions after mixing preview builds with aggressive removal scripts.
  • The more extreme the removal (Core mode), the higher the likelihood of breakage.
Compatibility and functionality loss​
  • Removing Copilot and Outlook eliminates functionality integrated into the OS experience and may break workflows dependent on those integrations.
  • Some inbox features (e.g., Web Search integration, certain UWP app contracts) assume the presence of specific components. Removing them could cause errors in Settings, search, or other system areas.
  • ARM-specific quirks (missing OneDriveSetup.exe in certain images) still surface for arm64 users and may require manual handling.
Legal and support implications​
  • The builder modifies official Microsoft images. While rebuilding an image for personal use is common practice among enthusiasts and admins, these modified images are not supported by Microsoft. If you rely on commercial support or strict vendor-approved configurations, using a custom image could invalidate support contracts or complicate enterprise management.
  • Users should exercise caution when deploying modified images in production environments.
Unverified or anecdotal claims​
  • Community anecdotes (for instance, extreme claims about running Windows on tiny RAM footprints or long-term stability of certain pre-built tiny11 ISOs) should be treated as unverified. Test results vary by hardware, build, and the specific set of components removed. These claims are useful as pointers for experimentation but are not universal guarantees.
Best practices and recommended workflow​
If you plan to experiment with tiny11builder or adopt it for a niche deployment, follow a cautious, methodical approach.
  • Always start in a virtual machine. Validate the target image and configuration in a VM before moving to physical hardware.
  • Use an official Microsoft ISO as the source. Avoid downloading prebuilt third-party tiny11 ISOs unless you trust the builder and the publisher.
  • Keep backups. Create full disk images of any system before deploying a custom build.
  • Test updates. Before handing a custom image to end users, install the latest cumulative updates and, if possible, simulate future feature updates in a test environment.
  • Retain a support path. For production machines, maintain a recovery image and clear documentation of what was removed so you can restore functionality if needed.
  • Run the script elevated and with the recommended PowerShell invocation. Set ExecutionPolicy to Unrestricted (or sign scripts appropriately) and run from an administrative PowerShell session.
  • Keep the ADK up to date if you rely on oscdimg.exe for ISO creation.
  • Expect reinstallation attempts. After major updates, validate that removed apps have not reappeared, and keep the script or its blocking mechanisms handy to reapply fixes.
  • Favor selective removal. If uncertain, opt to remove only the apps you know you won’t use — incremental changes reduce the blast radius.
Practical step-by-step (concise)​
  • Download the official Windows 11 ISO for the desired edition and build.
  • Install or ensure access to the Windows ADK if you need oscdimg.exe.
  • Open PowerShell as Administrator and run: Set-ExecutionPolicy Unrestricted.
  • Execute tiny11builder with the recommended invocation (powerShell -f path\to\tiny11maker.ps1) and follow prompts to pick drive letter and SKU.
  • Choose whether to build “tiny11” or the more extreme “tiny11 Core”.
  • After the script finishes, test the resulting ISO in a VM.
  • If acceptable, proceed to write the ISO to media and perform a physical install — keeping a recovery option available.
Community, transparency, and future outlook​
tiny11builder’s continued development highlights an active, open, and transparent approach to Windows customization. The project maintainers are responsive to user reports and have iterated on compatibility (ESD/WIM support, 24H2/25H2 flexibility), compression techniques, and safeguards to reduce the annoyance of reinstalled apps.
That said, the ecosystem around Windows is always evolving: Microsoft’s servicing model, Store mechanics, and platform changes can introduce new behaviors that defeat current removal techniques. Users should expect an ongoing cat-and-mouse dynamic: maintainers will push fixes, and platform updates will sometimes require adaptations.
For those who value a clean, efficient Windows 11 with minimal inbox clutter, tiny11builder is now more capable and versatile than it was a year ago. For environments where official supportability, seamless updating, or out-of-the-box feature parity is essential, the trade-offs of a debloated image may outweigh the benefits.
The latest tiny11builder update is a meaningful upgrade for power users and administrators who want to build custom Windows 11 25H2 images without relying on opaque prebuilt ISOs. With Copilot and the new Outlook client explicitly removable, recovery compression for smaller ISOs, and enhanced protections against app reinstallation, the project continues to refine the balance between a minimal footprint and practical usability.
However, the convenience of a cleaner system comes with real trade-offs: reduced serviceability for core images, potential update and compatibility headaches, and the need for vigilant testing and backup strategies. The smart approach is to treat tiny11builder as a powerful tool for controlled scenarios — test thoroughly in VMs, prefer building your own images from official ISOs, and accept that maintaining a customized Windows installation requires attention over time.
For enthusiasts who enjoy tailoring their environment and administrators who need compact, privacy-minded images for constrained devices, tiny11builder’s new capabilities make it a compelling option. For larger or mission-critical deployments, weigh the benefits against the ongoing maintenance burden and lack of vendor support before converting a fleet to custom-built images.
Source: Neowin Windows 11 debloater tiny11builder updated with 25H2 support, Copilot removal, and more
Windows 11’s “inbox app” problem just got a new, pragmatic weapon: NTDEV’s updated Tiny11 Builder — a PowerShell-driven ISO rebuilder that now explicitly strips Copilot, the new Outlook client, and Teams from fresh Windows 11 installs while adding image-size and anti‑reinstall improvements aimed at the forthcoming 25H2 era. The release shifts the project from ad‑hoc hacks toward a more flexible, scriptable toolchain that works across languages and architectures, but it also renews long‑standing trade‑offs between minimal footprint and long‑term serviceability.
A monitor shows Windows 11 with a glowing Tiny11 recovery ring and code on a tilted screen.Background​
Windows 11 ships with dozens of built‑in apps, always‑on integration points, and an increasing push toward AI‑enabled features. For many power users and admins these inbox components are unnecessary, consume disk space, run background services, and — in some cases — form part of Microsoft’s telemetry and cloud‑centric UI flows. The community response over the last few years has been varied: post‑install debloat scripts, image customizers, and complete rebuilds of the ISO. Tiny11 sits squarely in that tradition: an open‑source, scriptable approach that accepts an official Microsoft ISO and outputs a trimmed, administrator‑controlled installer. (makeuseof.com)
NTDEV, the project maintainer, recently overhauled the builder into a single PowerShell script (tiny11maker.ps1), introduced an experimental tiny11 Core variant, and made explicit, automated removals for modern inbox components such as Copilot, the new Outlook client, and Teams. The change is positioned as 25H2‑ready and includes compression and reinstall‑blocking tweaks intended to make the final image smaller and more persistent across updates.
What’s new in this release​
This update is both pragmatic and pointed: it removes, compresses, hardens, and (where possible) prevents re‑appearance.
  • Explicit removal routines for Copilot, the new Outlook for Windows client, and Microsoft Teams. This is the headline: AI‑heavy components and Microsoft’s modern mail app are treated as optional by the builder rather than mandatory in the default image.
  • Single PowerShell pipeline: tiny11maker.ps1 replaces earlier batch-based flows, making the builder more portable across Windows releases, languages, and CPU architectures.
  • Recovery compression via DISM (the /Compress:recovery flag) to shrink final ISOs significantly. NTDEV reports that the new pipeline produces much smaller images, trading a bit of CPU time during creation for greatly reduced distribution size. (techspot.com)
  • Proactive blocking of reinstallation attempts for specific inbox apps — an ongoing “whack‑a‑mole” problem as Microsoft updates Store and servicing behaviours. The script attempts multiple mitigations to keep removed apps from reappearing after updates.
  • Unattended answer file included to bypass Microsoft Account enforcement during OOBE (the out‑of‑box experience), plus standard Microsoft tooling (DISM, and oscdimg.exe from the Windows ADK) used for image servicing and ISO creation. (pureinfotech.com)
  • tiny11 Core: a more extreme variant that removes the Windows Component Store (WinSxS) and numerous servicing paths to create ultra‑small, non‑serviceable images intended for testing, VMs, or constrained offline devices. The maintainer flags this as a development testbed, not a daily‑driver option.
These changes are documented in the project’s README and on community writeups and coverage. They are deliberate: the maintainer aims to use only Microsoft tools (no third‑party image manipulators), keep the pipeline transparent, and make the rebuildable ISO approach repeatable. (github.com, github.com, github.com, github.com, pureinfotech.com, blogs.windows.com, techspot.com, pureinfotech.com, pureinfotech.com, github.com)
Legal, operational, and enterprise considerations​
  • Licensing: rebuilding an image does not obviate licensing obligations — activation and valid licensing remain required. Microsoft’s support channels and community guidance caution against treating custom builds as license workarounds.
  • Supportability: enterprises bound by vendor SLAs or centralized management with Microsoft or OEMs should treat custom images as custom — support contracts may be impacted. Use custom images for test fleets, kiosks, or lab environments where vendor support is not mission critical.
  • Security: while Tiny11 uses Microsoft tooling and official ISOs, distribution of modified images increases operational risk. Build internally, sign and audit scripts, and avoid deploying unknown prebuilt images from untrusted sources.
When a department wants a curated Windows baseline, the recommended enterprise approach remains building a controlled image in the corporate image pipeline (SCCM/MDT/Intune workflows) with approved components and patching mechanics in place — Tiny11 is useful, but it must be integrated into a compliant lifecycle plan for enterprise use.
How this fits into the larger Windows ecosystem​
Tiny11’s update is another example of how community tooling responds to platform direction. As Microsoft tightens integration with AI assistants, modern mail clients, and in‑box services, community projects reassert local control. That tug‑of‑war is visible across several fronts: OOBE tweaks, ad suppression, telemetry toggles, and app removal tools.
Expect an ongoing cycle:
  • Microsoft modifies Store and servicing behaviours to streamline app provisioning and AI integration.
  • Community builders adapt their scripts to block or remove those components from images.
  • Microsoft adjusts, and the cycle continues.
Practically, that means Tiny11’s maintainers must keep iterating to prevent re‑installation and to account for store/servicing shifts. The project is explicit about that dynamic and the need for users to reapply or update their builds over time.
Bottom line​
NTDEV’s Tiny11 Builder update is a notable, well‑scoped evolution for users who want a lean, deterministic Windows 11 install. By adding removal routines for Copilot, the new Outlook client, and Teams, switching to PowerShell, and using DISM’s recovery compression for smaller ISOs, the project improves both flexibility and usability for hobbyists, lab admins, and embedded/low‑capacity device scenarios. Independent coverage and the repository README corroborate the headline claims and technical choices. (github.com, pureinfotech.com)
At the same time, the update reminds us of enduring trade‑offs: serviceability vs footprint, support vs control, and convenience vs long‑term maintenance. For production machines that must receive routine updates and vendor support, the standard Tiny11 (serviceable) profile — and rigorous testing — is the conservative path. For testing, VMs, or single‑purpose devices where a tiny footprint is essential, the Core option delivers exceptional reductions — but it does so by design at the cost of future updateability. Finally, the rebuild‑from‑official‑ISO model is the safest way to work with Tiny11: download official media, run the script locally, inspect changes, and validate on representative hardware. That keeps the power in administrators’ hands while minimizing the legal, support, and supply‑chain hazards that come with third‑party prebuilt images. (learn.microsoft.com)
This is a practical, evolving tool — excellent for users who value control and are comfortable managing Windows images — but it’s not a one‑click cure for every environment. The right choice depends on how much you value a tiny footprint versus the guarantees of standard Windows servicing and vendor support.
Source: Tom's Hardware Custom Windows 11 builder axes Microsoft's AI features, whack-a-moling Copilot, Outlook, and Teams — new Tiny11 Builder release should be Windows 11 25H2 ready
Tiny11’s latest builder refresh is a decisive step for power users who want Windows 11 without the inbox app clutter or the newest AI‑first integrations: NTDev’s rewritten PowerShell pipeline can now remove Copilot, the revamped Outlook client, and Microsoft Teams from a rebuilt Windows 11 installer, produce substantially smaller ISOs using DISM’s recovery (LZMS/LZX) compression, and include proactive measures to reduce the chance of removed apps being silently reinstalled.
Monitor shows a code editor with two red X marks and ISO compression promo beside Tiny11 branding.Background / Overview​
Windows 11 has steadily shifted from a minimal OS surface to a curated, service‑centric user experience that ships with many inbox apps, cloud integrations, and now first‑class AI features such as Copilot and a web‑backed “new Outlook.” For administrators, testers, and enthusiasts who want deterministic, compact images, community projects that rebuild official ISOs and remove unwanted packages have long been an answer — and Tiny11 is one of the most prominent such efforts.
NTDev’s September 2025 refresh converts the builder into a single PowerShell script (tiny11maker.ps1 / tiny11Coremaker.ps1), expands compatibility across Windows 11 SKUs, languages and CPU architectures, and introduces specific removal routines for Microsoft’s latest inbox items. The update is positioned as 25H2‑ready and ships with tooling and workflow changes intended to make the rebuild process both simpler and more resilient.
What changed in this Tiny11 Builder release​
PowerShell-first pipeline and broader compatibility​
The project has moved from older Batch-based flows to a robust PowerShell pipeline. That rewrite matters: PowerShell makes cross‑locale and cross‑architecture scripting more reliable, reduces brittle string-handling, and allows the script to target any Windows 11 release (WIM or ESD), x64 and arm64, and multiple languages without per‑build hacks. The repo and release notes explicitly call this out as a core improvement. Key practical effects:
  • One‑script workflow (tiny11maker.ps1) that prompts for image SKU and handles mount/servicing tasks.
  • Support for both WIM and ESD inputs and for different architectures.
  • No third‑party image tools required beyond Microsoft’s oscdimg.exe (Windows ADK) for ISO creation.
New removal targets: Copilot, new Outlook, Teams (and the usual suspects)​
The headline addition is explicit removal routines for Copilot, the “new Outlook” client, and Microsoft Teams. These components are now enumerated in the builder’s removal list alongside the long roster of UWP inbox apps Tiny11 has historically targeted: Clipchamp, OneDrive, Edge remnants handling, Xbox apps (with Xbox Identity Provider left in place to allow reinstallation), Mail & Calendar, Media Player, GetHelp, Feedback Hub and many more. The script also includes registry tweaks intended to proactively disable Copilot and to prevent some reinstallation paths. (tomshardware.com)
Why this matters: Copilot and the new Outlook are tightly integrated with cloud services and background update mechanisms; removing them reduces disk footprint, background services, and the in‑box prompts that drive users toward Microsoft’s cloud experiences. Teams and Outlook also create friction on low‑spec devices; making them optional at build time gives admins control over base images.
Compression overhaul: DISM /Compress:recovery (LZMS/LZX / “recovery”)​
To reduce final ISO and install sizes the new builder switches DISM’s export/compress mode to /Compress:recovery — the “recovery” compression mode that produces solid (ESD‑style) images using LZMS/LZX algorithms. That compression can substantially reduce image sizes compared with XPRESS/Fast compression, but the trade‑offs are notable: it takes longer and needs much more RAM while exporting. NTDev and the release notes make this explicit. (ntdotdev.wordpress.com)
Independent tools and imaging guides confirm the technical reality: recovery/solid compression yields markedly smaller files by using a heavier, solid compression method (LZMS/LZX), at the cost of increased memory consumption and slower export times. That makes the tiny11 builder’s output more distributable (smaller ISOs) while increasing the hardware requirements of the build step. (oofhours.com)
Tiny11 Core: an “experimental” ultra‑compact build​
The release also formally ships a Tiny11 Core builder: a variant intended for testing and constrained VMs that removes the Windows Component Store (WinSxS), disables or removes Windows Update and certain defensive components, and produces extremely compact, non‑serviceable images. The maintainer warns that Core is not suitable for production machines because serviceability and updates are intentionally sacrificed.
How the builder works — technical overview​
The Tiny11 builder is designed as an offline image servicing and repack pipeline that leverages Microsoft tooling wherever possible. The high‑level steps are:
  • Acquire an official Windows 11 ISO (WIM/ESD) from Microsoft.
  • Mount or extract the chosen image index.
  • Use DISM to mount the image and remove packages, optional components, scheduled tasks, language packs and registry entries corresponding to the selected removal profile.
  • Export/repack the modified image using DISM with /Compress:recovery for a smaller final footprint.
  • Use oscdimg.exe (from the Windows ADK) to recreate a bootable ISO and optionally inject an autounattend.xml to customize OOBE (for example, bypass Microsoft Account enforcement). (dwamconsult.co.uk)
The script includes logic to remove UWP packages, delete files, alter scheduled tasks, and apply registry changes to block common reinstall paths. It aims to rely on Microsoft’s own tooling (DISM, oscdimg) rather than third‑party image processors.
Strengths — why this release matters​
  • Explicit AI and mail client removal: For users who consider Copilot, the new Outlook, or the consumer Teams client to be unwanted bloat or privacy surface area, having precise removal routines reduces manual post‑install cleanup and the risk those components show up in fresh installs.
  • Cleaner base images for constrained devices: Smaller ISOs and smaller in‑place footprints make Windows 11 viable on storage‑constrained systems and VMs where every GB counts. Using recovery compression produces tangible distribution size wins. (github.com)
  • Powerful, transparent, Microsoft‑tooling workflow: The PowerShell script is open, modifiable, and intentionally depends on DISM and the ADK rather than opaque binary packers. This transparency helps administrators audit and tweak the process for their environments.
  • Reduced background churn: By removing auto‑updating inbox apps and background components, administrators gain more predictable update and resource behavior — important for kiosks, labs, test rigs and ephemeral VMs.
  • Repeatability and multi‑SKU support: The rewrite makes Tiny11 usable across Windows 11 releases and locales without the brittle per‑build hacks of older approaches. That’s a practical win for image builders in heterogeneous environments.
Risks, caveats, and what to watch out for​
1) Serviceability and update fragility​
Even the standard Tiny11 profile (non‑Core) removes many inbox packages. Microsoft’s servicing pipeline and future feature updates can assume the presence of certain components; heavy customization increases the risk of update failures, reboots during servicing, or the reappearance of removed packages after a major update or Store repair. Tiny11’s script adds mitigations, but it is not a guaranteed permanent block against reinstallation. The Core variant intentionally breaks serviceability and should not be used on machines that require ongoing security updates.
2) Security exposure (Core builds especially)​
Tiny11 Core may disable or remove Windows Update, Defender components and WinSxS, or otherwise hobble built‑in update and remediation paths to achieve minimal size. Running such an image as a daily‑connected workstation can leave systems exposed to unpatched vulnerabilities. Community coverage and the project itself warn strongly that Core is for testbeds only.
3) Compatibility, driver and feature breakage​
Removing certain platform pieces can cause surprising regressions: hardware vendors’ drivers may rely on components that were removed, Settings pages can show remnants or errors, and some apps may fail without expected runtime services. Reports from testers emphasize hardware‑specific quirks and that aggressive removals can lead to boot loops or device‑specific failures when combined with preview builds. These are empirical, environment‑dependent risks.
4) Build resource requirements​
The change to DISM’s recovery compression reduces ISO sizes but raises build‑time demands. Expect significantly longer exports and high memory use during the /Export‑Image or /Apply‑Image steps. Users building on low‑RAM machines may see DISM fail with out‑of‑memory errors during recovery compression; the community and documentation note this is a real limitation. Plan builds on machines with ample RAM and disk I/O headroom. (answers.microsoft.com)
5) Official support and licensing questions​
Modified images are not supported by Microsoft. Enterprises or users under support agreements should treat custom Tiny11 images as unsanctioned configurations that could complicate vendor troubleshooting or breach support terms. For home users the legal/licensing picture is typically workable (activation with valid keys is possible), but organizations must evaluate policy and compliance risk.
Practical guidance: when and how to use Tiny11 Builder safely​
Good use cases​
  • Test VMs and ephemeral lab images where quick boot and low disk footprint are priorities.
  • Kiosk systems, single‑purpose appliances, or locked VMs where updates and app diversity are intentionally constrained.
  • Hobbyist exploration on spare hardware where the owner accepts the risks and possible need to rebuild for future updates.
  • Rescue environments or offline systems with strict storage constraints.
Cases to avoid​
  • Production endpoints that must remain supported and up‑to‑date via Windows Update.
  • Internet‑facing machines that rely on built‑in security features removed by the Core profile.
  • Environments with strict vendor support contracts that prohibit modified OS images.
Recommended workflow (step‑by‑step)​
  • Always back up data and create a recovery plan before deploying a custom image.
  • Build on a powerful workstation or VM with abundant RAM (16–64+ GB recommended depending on compression chunk size and threads).
  • Start with the standard tiny11 profile (not Core) for production‑adjacent test images.
  • Test the image extensively in representative hardware and update scenarios (monthly rollups, feature updates).
  • If you must use Core for constrained VMs, keep them offline or closely network‑segmented and schedule periodic rebuilds rather than in‑place patching.
  • Keep the builder scripts under version control; audit registry and scheduled task modifications before mass deployment.
Verification of key technical claims​
  • The builder’s published release notes and NTDev’s blog post confirm removal of Copilot, the new Outlook, and Teams in the September 2025 update. These are explicit entries in the GitHub releases and NTDev’s announcement. (ntdotdev.wordpress.com)
  • The claim that the script switched to DISM’s /Compress:recovery mode is recorded in the repository’s README and release notes; separate documentation of DISM’s recovery/solid compression confirms that it uses LZMS/LZX solid compression with better ratios at higher memory cost. This behaves as NTDev describes: smaller images at the cost of time and RAM. (wimlib.net)
  • The statement that the Tiny11 Core image is non‑serviceable and removes WinSxS and update hooks appears in the repo and in release commentary; multiple outlets and the project README warn Core images cannot reliably receive conventional updates. That limitation is explicit and repeatable.
If any of these points are critical for deployment planning — for example, serviceability, updateability, or compliance — they should be validated against the exact Tiny11 builder version and local test runs, because the builder’s behavior depends on input images, build options, and the precise selection of removal flags.
Critical analysis — balancing practicality and risk​
Tiny11’s updated builder is an elegant, pragmatic tool for a defined audience: experimenters, lab admins, and niche deployments that prioritize minimal footprint and control over a full, Microsoft‑curated experience. The project’s strengths are obvious and repeatable: improved script architecture, Microsoft toolchain usage, and better compression all add real value for those who need small, deterministic install media. At the same time, the update crystallizes a longstanding tension in modern OS management: the trade between a clean base image and the serviceability guaranteed by a full install. Removing inbox components and update plumbing reduces attack surface and background churn, but it also removes repair and update pathways. Tiny11 Core intentionally formalizes that trade‑off and warns users — which is responsible — but the presence of a non‑serviceable option increases the chance that ill‑prepared users will deploy images inappropriately.
A second, more insidious operational challenge is long‑term maintenance: Microsoft changes servicing behavior, Store republish flows, and package names — a “whack‑a‑mole” problem NTDev acknowledges. Any builder that relies on precise package names and registry blockers must be actively maintained to keep pace with Microsoft’s evolution. The PowerShell rewrite reduces maintenance friction, but it doesn’t eliminate the need for ongoing vigilance. Finally, the recovery compression move is a clear win for distribution — smaller ISOs are easier to host and ship — yet it pushes imaging beyond the capabilities of light builders. Organizations that want repeatable builds should standardize on build hardware (sufficient RAM / SSD storage) and bake that into their image pipeline. The energy, time and resource cost of recovery compression must be weighed against storage and bandwidth savings. (github.com)
Bottom line​
NTDev’s Tiny11 builder update is a meaningful release for anyone who wants a stripped, serviceable Windows 11 image or an experimental, ultra‑lean test image. It combines a modern PowerShell pipeline with explicit removals for Copilot, the new Outlook, and Teams, and it adopts stronger compression to deliver smaller ISOs — but those benefits come with clear trade‑offs: more demanding build hardware, potential update and compatibility fragility, and real security considerations for Core images. The project is well‑documented, intentionally transparent, and useful in the right scenarios — but it is not a one‑size‑fits‑all replacement for standard, supported Windows 11 installations.
Quick reference: Where the facts line up (short checklist)​
  • New PowerShell builder (tiny11maker.ps1) and Tiny11 Core variant: confirmed.
  • Explicit removal of Copilot, new Outlook client, and Teams: confirmed in release notes and NTDev blog. (ntdotdev.wordpress.com)
  • Switch to DISM /Compress:recovery for smaller ISOs — true, but requires more RAM and time. (oofhours.com)
  • Tiny11 Core intentionally non‑serviceable: documented and warned against for production use.
  • Builder relies on Microsoft tooling (DISM, oscdimg.exe) and includes an autounattend.xml for OOBE customizations. (dwamconsult.co.uk)
The Tiny11 project continues to be one of the clearest expressions of the power‑user community’s desire for lean, controllable Windows images — and this update sharpens the toolset while honestly laying out the costs. For lab and niche deployments it’s an excellent, repeatable approach; for production endpoints and general‑purpose desktops, weigh the benefits against the increased maintenance and security responsibilities before deploying.
Source: TechSpot Tiny11 Builder update lets users strip Copilot and other bloat from Windows 11
Tiny11’s refreshed Builder recasts Windows 11 as a lean, privacy-minded alternative for users who don’t want Microsoft’s inbox apps, Copilot, or forced Microsoft Account flows—and it does so at a critical moment, as Windows 10 support winds down and millions of PCs face an awkward upgrade choice.
Diagram of Tiny11: a slim Windows 11 build with offline servicing and privacy, trimmed of Copilot, Outlook, and Teams.Overview​
Tiny11 Builder is an open-source PowerShell tool that rebuilds an official Windows 11 ISO, removing a long list of inbox apps, telemetry hooks, and cloud-first components, then repacks the image using more aggressive compression to produce a much smaller installer. The project’s maintainer, NTDEV (ntdevlabs), published a major refresh in September 2025 that moves the tool to a single PowerShell pipeline, adds explicit removal routines for Microsoft’s recent AI and mail integrations (Copilot and the “new Outlook”), and switches to DISM’s recovery/LZX compression to dramatically reduce final ISO size. This update arrives with timing that matters: Microsoft ends mainstream support for Windows 10 on October 14, 2025, leaving users three basic choices—upgrade to Windows 11, enroll in Extended Security Updates (ESU), or accept an unsupported OS. Tiny11 positions itself as a pragmatic middle ground for users who must move to Windows 11 but want to keep control over what ships on their PCs.
Background: why Tiny11 matters now​
Windows 11 has steadily become more than a minimalist OS shell: inbox apps, integrated cloud clients, and AI-first features now ship by default. For users on older hardware, privacy-minded enthusiasts, and administrators building deterministic images, that trend is a headache—disk space, background processes, telemetry, and persistent reinstall behavior all add friction. Community tools that modify the installer (rather than post-install scripts) have been the most reliable way to enforce a minimal base image, and Tiny11 is one of the most prominent of those projects.
At a systems level, Tiny11’s approach is simple and deliberate:
  • Start with an official Microsoft Windows 11 ISO (WIM or ESD).
  • Use Microsoft tooling (DISM, and optionally oscdimg from the Windows ADK) to service the image offline.
  • Remove selected packages, set registry and policy tweaks, and inject an unattend file to avoid Microsoft Account enforcement during OOBE.
  • Recompress and rebuild a bootable ISO that omits the targeted inbox components.
That flow preserves important advantages: the image is still built from official media (reducing supply-chain risks compared with unknown prebuilt ISOs), and the tooling relies on Microsoft’s own utilities where possible. But because Tiny11 removes components at image level, the installed system starts clean—no post-install debloat needed.
What changed in the September 2025 refresh​
PowerShell-first single pipeline​
The builder was rewritten into a single PowerShell pipeline (tiny11maker.ps1 and an experimental tiny11Coremaker.ps1) to improve cross-language and cross-architecture reliability, simplify maintenance, and support x64 and arm64 images from the same script. This helps avoid brittle batch-file hacks and makes the rebuild process more predictable across locales.
Explicit removal of Copilot, new Outlook, and Teams​
The new release explicitly targets Microsoft’s recent inbox components—Copilot, the new Outlook client, and Teams—which are tightly integrated with cloud services and have proven difficult to remove in some environments. Removing these reduces surface area for background updates and telemetry for users who don’t want them. The maintainer documents these removals in the repo’s release notes and README.
Recovery/LZX compression for smaller ISOs​
Tiny11 now uses DISM’s /Compress:recovery (LZX/LZMS) option when rebuilding the image. That change trades more CPU and memory during image creation for meaningful reductions in ISO size—useful for constrained media and for keeping the on-disk footprint lower on low-capacity drives.
Proactive blocking of reinstall attempts​
The update includes registry tweaks and blocking measures designed to reduce the chance that Windows Update or Microsoft Store will silently reinstall removed inbox apps. The maintainers describe this as an ongoing cat‑and‑mouse process—Microsoft’s servicing and store mechanics can and do change, so removals sometimes require follow-up patches.
Tiny11 Core: extreme, non‑serviceable option​
For testbeds and ultra‑compact systems, tiny11Coremaker creates a non‑serviceable image that strips WinSxS and many servicing hooks. That yields the smallest on-disk footprint but intentionally sacrifices Windows Update and future servicing; it’s explicitly not recommended for production laptops or internet-facing systems.
What Tiny11 removes (the practical list)​
The exact removal roster can vary between builder versions and forks, but the September refresh (and forks that followed) target a comprehensive set of inbox apps and components commonly identified as bloat:
  • Clipchamp, News, Weather, Xbox family apps, Get Help, Get Started
  • Office Hub, Solitaire, People, Power Automate, To Do, Alarms
  • Mail and Calendar (classic), Feedback Hub, Maps, Sound Recorder, Your Phone / Phone Link
  • Media Player, Quick Assist, Internet Explorer remnants, Tablet PC Math, OneDrive, Microsoft Edge (in many configurations)
  • Copilot, the new Outlook client, and Microsoft Teams (removal routines added in the recent update)
Note: lists differ by repository fork and configuration flags. Tiny11maker (standard mode) aims to leave the image serviceable; tiny11Core is far more aggressive and can break compatibility with some apps or drivers.
How Tiny11 is used (practical steps)​
For readers who want the high-level workflow without every friction detail, here’s the typical sequence used by builders like Tiny11:
  • Download an official Windows 11 ISO from Microsoft and place it on your build machine.
  • Download the Tiny11 Builder repository (tiny11maker.ps1) from the project GitHub and extract locally.
  • On the build machine, install or have access to the Windows ADK if you need oscdimg.exe for ISO creation.
  • Open PowerShell as Administrator and run Set-ExecutionPolicy Unrestricted (or run the script with the appropriate execution flags).
  • Mount the source ISO, run tiny11maker.ps1 and follow prompts to select edition, language, and whether to build standard or Core images. The script services the offline image via DISM and rebuilds it with recovery compression.
  • Create bootable media from the output ISO (Rufus or Microsoft's media tools), then install to target PC—disconnect from the network during OOBE to avoid online-first prompts if desired.
This is intentionally a somewhat technical process; it’s not a one‑click installer and assumes a measure of comfort with PowerShell, DISM, and Windows imaging.
Benefits: why users are adopting Tiny11​
  • Smaller ISO and on-disk footprint. The use of recovery/LZX compression plus omission of dozens of inbox components yields substantially smaller installers and installs that consume fewer gigabytes.
  • Reduced background churn. Fewer inbox apps and services mean fewer automatic updaters and background processes on low‑spec machines.
  • Privacy and control. Users who object to Copilot, cloud‑first mail clients, or Microsoft nudges can remove those components at build time instead of wrestling with post-install workarounds.
  • No forced Microsoft Account required. The builder can inject an autounattend to bypass Microsoft Account enforcement during OOBE, which appeals to users who want a local account setup.
  • Flexibility for specialized deployments. Kiosks, VMs, test rigs, and constrained devices benefit from a deterministic base image with minimal attack surface.
For many enthusiasts and small‑scale admins, these gains outweigh the extra work to build a custom ISO.
Real risks and trade-offs — what Tiny11 doesn’t solve​
Tiny11’s appeal is strong, but the tool also introduces real trade-offs that every reader must weigh carefully.
1) Updateability and security posture​
  • The standard tiny11maker is designed to remain serviceable, but the Core variant deliberately disables many servicing hooks and Windows Update channels. Systems built from Core images may not receive crucial security patches and could be unsafe on untrusted networks. That makes Core suitable only for isolated test VMs or single-purpose appliances.
  • Even a serviceable Tiny11 image may behave differently with Microsoft’s ongoing servicing pipeline; future platform updates can reintroduce removed components or break compatibility. The maintainer and community describe an ongoing “cat‑and‑mouse” dynamic.
2) Compatibility and reliability problems​
  • Aggressive removals can surface unexpected breakage in drivers, multimedia stacks, game compatibility, or enterprise software that expects certain inbox components to be present. Community reports show both success stories and cases where reinstalling vanilla Windows resolved problems that cropped up under Tiny11 Core. (reddit.com)
3) Legal and support implications​
  • Building and installing Windows from modified official ISOs is feasible for personal use, but distributing modified Windows images or redistributing Microsoft components can trigger license issues. Organizations should treat Tiny11 as a community tool rather than an official supported path; vendor support from Microsoft is not available for modified images.
4) Supply-chain and trust concerns​
  • The Tiny11 code is open source on GitHub, but forks, archived ISOs, and third‑party builds have historically led to controversy. Users should always use the official repository (or inspect code) and build locally from Microsoft-supplied ISOs to minimize risk. Community threads document past incidents where unofficial ISOs or altered binaries raised alarm—transparency matters. (reddit.com)
5) The Microsoft countermeasures problem​
  • Microsoft’s servicing model (Windows Update, Store, component re-provisioning) can and does attempt to reinstall some removed components. Tiny11’s recent release includes mitigations against reinstallation, but this remains a moving target; administrators should expect to update custom build scripts after major servicing changes.
Practical recommendations​
If you’re considering Tiny11 to bridge the Windows 10 end-of-support transition, follow a conservative, test-driven path:
  • Prefer tiny11maker (serviceable) over tiny11Core for daily drivers and internet-facing machines. The Core option is for VMs and controlled test hardware only.
  • Build locally from an official Microsoft ISO—do not download pre-built Tiny11 ISOs from untrusted sources. This minimizes tampering risk.
  • Test in VMs first. Validate driver compatibility, Windows Update behavior, and the functionality of your critical applications before upgrading physical machines.
  • Keep a recovery plan. Have vanilla Windows 11 install media and full backups ready—if an update or app requires a removed component, you’ll need an escape hatch.
  • Monitor upstream changes. Follow the NTDEV repo and community forks for updates that patch reinstallation behaviors or compatibility issues. The project’s README and release notes document noteworthy changes.
  • Consider ESU or a hardware refresh if you need guaranteed vendor support and minimal operational risk; Tiny11 is excellent for control and footprint reduction, but it is not an official servicing path.
A closer look at specific concerns​
Will Microsoft force Edge or Copilot back onto Tiny11 images?​
Historically, Microsoft’s servicing pipeline can re-provision certain inbox packages in response to updates. Tiny11’s maintainers added registry and policy tweaks to proactively block many of those re-provisioning flows, and the recent update explicitly targets Copilot and the new Outlook. That said, the project itself calls this an ongoing battle—expect to revisit builds after big Windows updates. Users should treat claims of permanent removal with caution and maintain a test cycle.
Are Tiny11 images secure?​
A serviceable Tiny11 image that preserves Windows Update and Defender and that’s kept up to date can be reasonably secure for everyday tasks. A Core image that disables update hooks or reduces Defender functionality is not secure for general-purpose or internet-connected use. The security posture depends on the mode chosen and the maintainers’ specific removal choices. This is a design trade-off, not a bug.
Is Tiny11 legal for businesses?​
Using Tiny11 to customize an installation for internal use is a legal gray area best handled by your legal and procurement teams. Redistribution of modified ISOs, or offering modified Windows as a service to customers, is riskier and can violate Microsoft licensing terms. For fleets that require vendor support and predictable servicing, Microsoft’s supported upgrade paths and ESU are the safer choice.
The ecosystem: forks, community and coverage​
Tiny11 is not a monolith. Numerous forks and community builds exist, each adapting the core scripts for newer Windows builds, local languages, or edge cases (24H2, 25H2, arm64). Independent outlets—from Tom’s Hardware to Windows Central and TechRadar—have covered the September 2025 refresh and the broader Windows 10 EOL context, highlighting both the utility and the caveats of rebuilding Windows ISOs. The NTDEV GitHub repo and community forks remain the authoritative places to track code changes, release notes, and remediation steps. (windowscentral.com, github.com, microsoft.com)
Source: PCWorld Tiny11's free update strips down Windows 11 for Windows 10 fans
