Windows 7 Using PSR to submit problems
olufs3n
Microsoft implemented a wonderful feature in this version of Windows name PSR. This is basically a recording tool which allows user to submit the kind of problem/issues they are running into (if they can replicate it). My question is how come Microsoft isn't using this wonderful feature to look at some of the problems other users are running into.
For Example, I am having problem changing the information on all of my MP3 files. I can clearly replicate it and produce screenshots but there isn't a place that would allow me to submit this.
PS: to start psr, simply start, run and type in psr
Microsoft's Problem Steps Recorder (PSR) is indeed a valuable tool for users to document and share the steps to replicate an issue they are facing on their Windows system. While this tool is primarily designed for users to create detailed descriptions of problems, steps to reproduce issues, and screenshots, its primary focus is on providing a quick and easy way for users to report problems to IT support or help desk personnel. Here are some insights into why Microsoft might not use PSR for extensive issue monitoring and resolution: 1. Scope and Purpose: - PSR is more geared towards capturing a specific issue experienced by an individual user, rather than monitoring and analyzing widespread issues across a large user base. 2...
Microsoft's Problem Steps Recorder (PSR) is indeed a valuable tool for users to document and share the steps to replicate an issue they are facing on their Windows system. While this tool is primarily designed for users to create detailed descriptions of problems, steps to reproduce issues, and screenshots, its primary focus is on providing a quick and easy way for users to report problems to IT support or help desk personnel. Here are some insights into why Microsoft might not use PSR for extensive issue monitoring and resolution: 1. Scope and Purpose: - PSR is more geared towards capturing a specific issue experienced by an individual user, rather than monitoring and analyzing widespread issues across a large user base. 2. Volume of Data: - Microsoft has various other tools and processes in place for gathering and analyzing large-scale issue reports from users, such as Windows Error Reporting (WER) and user feedback programs. PSR captures detailed steps which may not be as scalable or standardized for automated analysis. 3. Privacy and Security: - PSR captures detailed user interactions on the system, including keystrokes and screen content. Using this data on a large scale for issue resolution might raise privacy concerns. Microsoft needs to ensure data protection and user privacy. 4. Resource Allocation: - Handling and processing the vast amount of data generated by PSR recordings from a large user base can be resource-intensive. Microsoft likely has dedicated teams, processes, and tools for aggregating, analyzing, and prioritizing reported issues. While PSR is an excellent tool for individual users to document and communicate problems more effectively, Microsoft's approach to monitoring and addressing system-wide issues involves more specialized tools and processes tailored to handle the volume and complexity of reported problems. If you are experiencing a specific issue with changing MP3 file information, you can explore Microsoft's official support channels, community forums, or feedback mechanisms to report and seek assistance for the problem you are encountering.
