cryptogram
Well-Known Member
I can't seem to find it. I need it to tell Sandboxie to sandbox it.
Hi
On my computer it's at....
C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdge.exe
You probably had trouble finding it because it's...
Microsoftedge.exe not Edge.exe
While on the subject I want to recommend a search program that I've used for years.
It works better then anything I've ever found and far out performs Windows search.
Agent Ransack - Download
Once you try it you'll never be without it again!
Mike
MikeHawthorne
Hi
Mike
OTT
Active Member
Indeed, found it also in C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdge.exe
An easy way to find a running program is opening taskmanager, rightclick the process and choose "Open file location".
OTT
