Windows 8 Why so many task bars?
Zeeman28a
Windows 8, Build 8400
Is there a way to disable the taskbar from showing on all my extra monitors? I only need it on my main screen, I do not need/want it on my other 3 screens as it takes away from the total resolution of the screen.
Hiding the task bar is not an option.
Thanks.
Z.
Right click taskbar and choose properties.
Under the Taskbar Tab in the resultant dialog box, uncheck Show taskbar on all dispalys
