Windows 7 Wifi Connection Works, But Doesn't
cspperson
Hi I've had this problem that never seems to ever be solved. My wifi button says that I'm not connected and there are no connections available, and the wifi list works with wifis listed. When I connect to a network the icon doesn't change to connected. I'm not sure if this is just a glitch or not but I would like it to be solved.
It looks like your computer is a laptop and your only network connection is wifi, is that right? Is there a built-in wifi adapter? Are you using a wifi dongle (adapter that plugs into a USB port)?
On your screen shot, the window shows you connected but the tray icon says no. You could just hide the useless tray icon, but the issue is that you want a tray icon that correctly shows the connection status?
When you are actually connected, hover over the tray icon; does it display any information (you would normally see the name of the network if that icon is for the connection)? If you see the network name but the icon shows the symbol for no connection, the problem is some form of corruption (or pranking), where the wrong icon has...
Fixer1234
Any chance you have more than one wifi utility active (e.g., a generic windows one plus one that came bundled with the wifi hardware)? Could be that the one you are looking at is not the one that is managing your actual connection.
cspperson
No, I don't have any other wifi utility that is connected to this computer
Fixer1234
You would typically have two icons associated with the wifi connection. One is a windows icon that reports on the network connection. The other is for a wireless utility associated with your wifi card or dongle. If you have other potential network connections (like an Ethernet jack), there will be additional icons for them, even if you do not have a network connection through them. You could be seeing an icon for an unused network connection correctly informing you that there is no connection there.
Right click on a blank area of the system tray and select properties. Select Customize for the notification area. See if there are entries currently hidden for another network connection and the wifi utility. You can hide the network connection that is not giving you useful information and show what is relevant.
cspperson
Sorry I haven't been responding, school.
I went to the customize window and there is only one wifi icon/notification available
Fixer1234
When you are actually connected, hover over the tray icon; does it display any information (you would normally see the name of the network if that icon is for the connection)? If you see the network name but the icon shows the symbol for no connection, the problem is some form of corruption (or pranking), where the wrong icon has been associated with connected status. You might be able to fix that by running SFC /SCANNOW from the start menu Run window (it repairs corrupted system files). Actually, it wouldn't hurt to do that anyway because it may clean up other types of corruption that could underlie the problem.
If you don't see any information when you hover over the icon, right click on the tray icon and select the Network and Sharing Center. The middle of that window should show your current connections. Does your network connection appear there? It should if you are connected and that will confirm that the issue is limited to the tray icon. Click on the listed wireless connection, and then Properties. You will see a box titled "Connect Using". What does it show in that box?
Open the Device Manager (many ways to get there, such as the System window from the Control Panel). In the Device Manager, you will see a list of device categories. Expand the Network Adapters category by clicking on the arrowhead in front of it. How many adapters are listed? What are their names? Do any of them have a little yellow fault flag? (If you are able to connect, I wouldn't expect it, but it is possible to be corrupted in a way where the issue is limited to non-critical internal handshaking.)
Let me know the answers to these questions to figure out the next step.
