Hi stevesalsa and Welcome to The Forum.
Both dumps show:
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes: Device driver
The older dump file lists
usbaapl64.sys as the probable cause.
This is an Apple Mobile USB Driver.
Your latest dump file lists
pci.sys as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
As a Priority:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct
Link Removed for your system
(32 or 64 bit).
If you have AVG ID protection installed, download the
AVGID Protection Remover from the above link as well
(it wouldn't hurt to download and run it anyway). Download BSOD friendly
Link Removed due to 404 Error as AVG's replacement.
Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the
AVG Removal tool
(s). Re-boot to normal mode and
install MSE. Make sure your Windows firewall is enabled! After your blue screens have been resolved, feel free to re-try AVG.
Make sure your system is fully updated including SP1.
Download and install the correct system readiness tool
prior to installing SP1.
Drivers that pre-date Windows 7. Update:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with
iTunes
Drivers with Updates:
atikmdag.sys Mon Jun 27 20:38:05 2011 Link Removed
- Download and install DriverSweeper.
- Uninstall your current Graphics setup through Programs and Features
- Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
- Reboot to Normal Mode.
- Install your new Graphics set up.
Rt64win7.sys Tue Sep 27 15:50:33 2011 Link Removed If you're unsure about manually installing drivers then choose the
Win7 and WinServer 2008 R2 Auto Installation Program (SID:1483XXX) option to download.
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck 9F, {3, fffffa800724aa20, fffff80000b9c518, fffffa8007b81830}
Probably caused by : pci.sys
Followup: MachineOwner
Drivers:
fffff880`00f7d000 fffff880`00fd4000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`056f1000 fffff880`0577a000 afd afd.sys Wed Dec 28 03:59:08 2011 (4EFA940C)
fffff880`05cf4000 fffff880`05d0a000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01a9e000 fffff880`01aec000 ahcix64s ahcix64s.sys Mon Sep 22 12:24:17 2008 (48D78061)
fffff880`01165000 fffff880`0117d000 amd_sata amd_sata.sys Sat Oct 29 00:40:46 2011 (4EAB3D7E)
fffff880`011df000 fffff880`011ed000 amd_xata amd_xata.sys Sat Oct 29 00:40:48 2011 (4EAB3D80)
fffff880`05ddf000 fffff880`05df3000 amdiox64 amdiox64.sys Thu Feb 18 15:17:53 2010 (4B7D5A21)
fffff880`059af000 fffff880`059c4000 amdppm amdppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`011ed000 fffff880`011f8000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`09570000 fffff880`0957b000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`01127000 fffff880`01130000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01130000 fffff880`0115a000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`06e00000 fffff880`070a9000 athrx athrx.sys Thu Aug 04 04:57:02 2011 (4E3A188E)
fffff880`07f37000 fffff880`07f58000 AtihdW76 AtihdW76.sys Thu Mar 31 08:15:43 2011 (4D942A1F)
fffff880`0603a000 fffff880`069fa000 atikmdag atikmdag.sys Mon Jun 27 20:38:05 2011 (4E08DC1D)
fffff880`05800000 fffff880`05850000 atikmpag atikmpag.sys Mon Jun 27 20:02:33 2011 (4E08D3C9)
fffff880`017ef000 fffff880`017f7000 AtiPcie AtiPcie.sys Tue May 05 16:00:22 2009 (4A005486)
fffff880`05317000 fffff880`05342000 AVGIDSDriver AVGIDSDriver.Sys Sun Jul 10 23:36:37 2011 (4E1A2975)
fffff880`017e5000 fffff880`017ef000 AVGIDSEH AVGIDSEH.Sys Sun Jul 10 23:36:50 2011 (4E1A2982)
fffff880`0329e000 fffff880`032a9000 AVGIDSFilter AVGIDSFilter.Sys Sun Jul 10 23:37:05 2011 (4E1A2991)
fffff880`05940000 fffff880`05989000 avgldx64 avgldx64.sys Fri Oct 07 04:55:41 2011 (4E8E783D)
fffff880`01b8f000 fffff880`01b9f000 avgmfx64 avgmfx64.sys Mon Aug 08 04:41:46 2011 (4E3F5AFA)
fffff880`017d9000 fffff880`017e5000 avgrkx64 avgrkx64.sys Tue Sep 13 05:02:34 2011 (4E6ED5DA)
fffff880`0564c000 fffff880`056ac000 avgtdia avgtdia.sys Sun Jul 10 23:46:53 2011 (4E1A2BDD)
fffff880`01ba8000 fffff880`01baf000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0592f000 fffff880`05940000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`033c7000 fffff880`033e5000 bowser bowser.sys Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff960`00710000 fffff960`00737000 cdd cdd.dll unavailable (00000000)
fffff880`01b65000 fffff880`01b8f000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`013a9000 fffff880`013d9000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00d0f000 fffff880`00d6d000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0147e000 fffff880`014f1000 cng cng.sys Thu Nov 17 04:26:35 2011 (4EC48CFB)
fffff880`05ce4000 fffff880`05cf4000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`08600000 fffff880`0860e000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`05911000 fffff880`0592f000 dfsc dfsc.sys Wed Apr 27 03:57:39 2011 (4DB78623)
fffff880`05902000 fffff880`05911000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0163a000 fffff880`01650000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07f95000 fffff880`07fb7000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`07e00000 fffff880`07e4e000 dump_ahcix64s dump_ahcix64s.sys Mon Sep 22 12:24:17 2008 (48D78061)
fffff880`0860e000 fffff880`08618000 dump_diskdump dump_diskdump.sys Fri Apr 22 19:11:55 2011 (4DB1C4EB)
fffff880`08618000 fffff880`0862b000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`087f0000 fffff880`087fc000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`05a53000 fffff880`05b47000 dxgkrnl dxgkrnl.sys Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`05b47000 fffff880`05b8d000 dxgmms1 dxgmms1.sys Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`00db9000 fffff880`00dcd000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00d6d000 fffff880`00db9000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`07157000 fffff880`07190000 FLxHCIc FLxHCIc.sys Sat Oct 23 10:18:40 2010 (4CC2A870)
fffff880`071ca000 fffff880`071e2000 FLxHCIh FLxHCIh.sys Sat Oct 23 10:18:49 2010 (4CC2A879)
fffff880`01502000 fffff880`0150c000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01600000 fffff880`0163a000 fvevol fvevol.sys Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`016df000 fffff880`01729000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`071a0000 fffff880`071ad000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`045ef000 fffff800`04638000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`05b8d000 fffff880`05bb1000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`07e6b000 fffff880`07e84000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`0863b000 fffff880`08643080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0862d000 fffff880`0863b000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`032ff000 fffff880`033c7000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`017d0000 fffff880`017d9000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`01009000 fffff880`01127000 iaStorV iaStorV.sys Fri Mar 05 21:27:48 2010 (4B917754)
fffff880`05dbf000 fffff880`05dce000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`07e84000 fffff880`07e92000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00baf000 fffff800`00bb9000 kdcom kdcom.dll Sat Feb 05 12:21:45 2011 (4D4D40D9)
fffff880`09502000 fffff880`09509000 KernExplorer64 KernExplorer64.sys Thu Feb 03 14:28:26 2011 (4D4ABB8A)
fffff880`05c00000 fffff880`05c43000 ks ks.sys Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`01464000 fffff880`0147e000 ksecdd ksecdd.sys Thu Nov 17 03:54:33 2011 (4EC48579)
fffff880`016b4000 fffff880`016df000 ksecpkg ksecpkg.sys Thu Nov 17 04:27:30 2011 (4EC48D32)
fffff880`07fb7000 fffff880`07fbc200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`00dcd000 fffff880`00de2000 Lbd Lbd.sys Thu Feb 03 14:23:53 2011 (4D4ABA79)
fffff880`07fe0000 fffff880`07ff5000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07fbd000 fffff880`07fe0000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cee000 fffff880`00cfb000 mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`07e9f000 fffff880`07ead000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`05dce000 fffff880`05ddd000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`07e92000 fffff880`07e9f000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`033e5000 fffff880`033fd000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`03200000 fffff880`0322d000 mrxsmb mrxsmb.sys Wed May 04 03:51:06 2011 (4DC0BF1A)
fffff880`0322d000 fffff880`0327b000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:44:55 2011 (4E17C0A7)
fffff880`0327b000 fffff880`0329e000 mrxsmb20 mrxsmb20.sys Wed May 04 03:51:05 2011 (4DC0BF19)
fffff880`0115a000 fffff880`01165000 msahci msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01a12000 fffff880`01a1d000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fdd000 fffff880`00fe7000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01406000 fffff880`01464000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`058f7000 fffff880`05902000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`017be000 fffff880`017d0000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0150c000 fffff880`015fe000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`05d2e000 fffff880`05d3a000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`07ead000 fffff880`07ec0000 ndisuio ndisuio.sys Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`05d3a000 fffff880`05d69000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`07f22000 fffff880`07f37000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`057bf000 fffff880`057ce000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`056ac000 fffff880`056f1000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01654000 fffff880`016b4000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01a1d000 fffff880`01a2e000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`058eb000 fffff880`058f7000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`04013000 fffff800`045ef000 nt ntkrnlmp.exe Thu Jun 23 03:51:48 2011 (4E02AA44)
fffff880`01207000 fffff880`013a9000 Ntfs Ntfs.sys Fri Mar 11 03:39:25 2011 (4D79996D)
fffff880`01b9f000 fffff880`01ba8000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`05a00000 fffff880`05a53000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`05783000 fffff880`057a9000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`05cb2000 fffff880`05ccf000 parport parport.sys Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`00e40000 fffff880`00e55000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fe7000 fffff880`00fee000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fee000 fffff880`00ffe000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`014f1000 fffff880`01502000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`05227000 fffff880`052cd000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07f58000 fffff880`07f95000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cfb000 fffff880`00d0f000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`05d0a000 fffff880`05d2e000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`05d69000 fffff880`05d84000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`05d84000 fffff880`05da5000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`05da5000 fffff880`05dbf000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0589a000 fffff880`058eb000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`01bf2000 fffff880`01bfb000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01a00000 fffff880`01a09000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01a09000 fffff880`01a12000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01784000 fffff880`017be000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`071e2000 fffff880`071fa000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`070b7000 fffff880`07157000 Rt64win7 Rt64win7.sys Tue Sep 27 15:50:33 2011 (4E81E2B9)
fffff880`052cd000 fffff880`052d8000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`05ccf000 fffff880`05cdb000 serenum serenum.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`057ce000 fffff880`057eb000 serial serial.sys Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`0177d000 fffff880`01784000 SmartDefragDriver SmartDefragDriver.sys Fri Nov 26 09:29:40 2010 (4CEF7E04)
fffff880`01775000 fffff880`0177d000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`09465000 fffff880`094fa000 srv srv.sys Fri Apr 29 04:13:05 2011 (4DBA2CC1)
fffff880`05342000 fffff880`053a9000 srv2 srv2.sys Fri Apr 29 04:12:51 2011 (4DBA2CB3)
fffff880`052d8000 fffff880`05305000 srvnet srvnet.sys Fri Apr 29 04:12:35 2011 (4DBA2CA3)
fffff880`0117d000 fffff880`011df000 storport storport.sys Fri Mar 11 04:24:35 2011 (4D79A403)
fffff880`05ddd000 fffff880`05dde480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01802000 fffff880`01a00000 tcpip tcpip.sys Thu Sep 29 04:52:31 2011 (4E83EB7F)
fffff880`05305000 fffff880`05317000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`01a4c000 fffff880`01a59000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01a2e000 fffff880`01a4c000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`0561b000 fffff880`0562f000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00510000 fffff960`0051a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`05989000 fffff880`059af000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`071b8000 fffff880`071ca000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`07e4e000 fffff880`07e6b000 usbccgp usbccgp.sys Fri Mar 25 03:23:03 2011 (4D8C0A97)
fffff880`0862b000 fffff880`0862cf00 USBD USBD.SYS Fri Mar 25 03:22:51 2011 (4D8C0A8B)
fffff880`05ca1000 fffff880`05cb2000 usbehci usbehci.sys Fri Mar 25 03:22:57 2011 (4D8C0A91)
fffff880`07190000 fffff880`071a0000 usbfilter usbfilter.sys Thu Nov 17 03:35:45 2011 (4EC48111)
fffff880`07ec8000 fffff880`07f22000 usbhub usbhub.sys Fri Mar 25 03:23:22 2011 (4D8C0AAA)
fffff880`071ad000 fffff880`071b8000 usbohci usbohci.sys Fri Mar 25 03:22:56 2011 (4D8C0A90)
fffff880`05c4b000 fffff880`05ca1000 USBPORT USBPORT.SYS Fri Mar 25 03:23:03 2011 (4D8C0A97)
fffff880`00e33000 fffff880`00e40000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01baf000 fffff880`01bbd000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`08646000 fffff880`087f0000 viahduaa viahduaa.sys Wed Nov 25 13:06:00 2009 (4B0D2BB8)
fffff880`01bbd000 fffff880`01be2000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e55000 fffff880`00e6a000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00ec6000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01729000 fffff880`01775000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`09400000 fffff880`0940d000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`057a9000 fffff880`057bf000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`05600000 fffff880`0561b000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`01be2000 fffff880`01bf2000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00eca000 fffff880`00f6e000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f6e000 fffff880`00f7d000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0577a000 fffff880`05783000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f4000 win32k win32k.sys unavailable (00000000)
fffff880`05cdb000 fffff880`05ce4000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fd4000 fffff880`00fdd000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05bb1000 fffff880`05bd2000 WudfPf WudfPf.sys Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`070aa000 fffff880`070b7000 vwifibus.sys
Checksum: 00000000
ImageSize: 0000D000
fffff880`06e01000 fffff880`070aa000 athrx.sys
Checksum: 00000000
ImageSize: 002A9000
fffff880`0958e000 fffff880`09598000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`09598000 fffff880`095e6000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`095e6000 fffff880`095f9000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`09509000 fffff880`09513000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`09513000 fffff880`09561000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`0957b000 fffff880`0958e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`095e6000 fffff880`095f0000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`09400000 fffff880`0944e000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`0944e000 fffff880`09461000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`0957b000 fffff880`09585000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`09585000 fffff880`095d3000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`095d3000 fffff880`095e6000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`095e6000 fffff880`095f8000 usbaapl64.sy
Checksum: 00000000
ImageSize: 00012000
fffff880`09411000 fffff880`09442000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
fffff880`09400000 fffff880`09411000 WinUsb.sys
Checksum: 00000000
ImageSize: 00011000
fffff880`09442000 fffff880`0944c000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`09509000 fffff880`09557000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`09557000 fffff880`0956a000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`094fa000 fffff880`09502000 AsrOcDrv.sys
Checksum: 00000000
ImageSize: 00008000
Checksum: 00000000
ImageSize: 0000A000
Checksum: 00000000
ImageSize: 0004E000
Checksum: 00000000
ImageSize: 00013000
Checksum: 00000000
ImageSize: 0000A000
Checksum: 00000000
ImageSize: 0004E000
Checksum: 00000000
ImageSize: 00013000
Checksum: 00000000
ImageSize: 00012000
Checksum: 00000000
ImageSize: 00031000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 0000A000
Checksum: 00000000
ImageSize: 0004E000
Checksum: 00000000
ImageSize: 00013000
fffff880`0951c000 fffff880`0952e000 usbaapl64.sy
Checksum: 00000000
ImageSize: 00012000
fffff880`0953f000 fffff880`09570000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
fffff880`0952e000 fffff880`0953f000 WinUsb.sys
Checksum: 00000000
ImageSize: 00011000
fffff880`09400000 fffff880`0940a000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`0940a000 fffff880`09458000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`09509000 fffff880`0951c000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`0958c000 fffff880`09596000 hiber_storpo
Checksum: 00000000
ImageSize: 0000A000
fffff880`09596000 fffff880`095e4000 hiber_ahcix6
Checksum: 00000000
ImageSize: 0004E000
fffff880`095e4000 fffff880`095f7000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`0c294000 fffff880`0c320000 bthport.sys
Checksum: 00000000
ImageSize: 0008C000
fffff880`09574000 fffff880`0958c000 BTHUSB.sys
Checksum: 00000000
ImageSize: 00018000
fffff880`0c35c000 fffff880`0c36c000 BthEnum.sys
Checksum: 00000000
ImageSize: 00010000
fffff880`0c330000 fffff880`0c35c000 rfcomm.sys
Checksum: 00000000
ImageSize: 0002C000
fffff880`0c36c000 fffff880`0c38c000 bthpan.sys
Checksum: 00000000
ImageSize: 00020000
fffff880`0c320000 fffff880`0c330000 BthEnum.sys
Checksum: 00000000
ImageSize: 00010000
Checksum: 00000000
ImageSize: 0000A000
Checksum: 00000000
ImageSize: 0004E000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
When attaching dmp files, PLEASE put them in a single zipped folder
