nyjfootball
Active Member
I recently purchased a Razer Edge Pro. I constantly receive the error message irql_not_less_or_equal after a crash. I also receive error xodeaddead (or is it x0deaddead ?). Immediately preceding the crash, Bluetooth stops working and Wi-Fi terminates. I have upgraded the RAM and Wi-Fi card. Not sure if this factors into the crashes. I know very little despite upgrading the computer, so please bare with my limited knowledge. I have included the minidump below. Thanks for taking the time to read this.
https://skydrive.live.com/redir?resid=B1887EE1F90D4B2A!129&authkey=!ACI085IHdgjUAwk
On a side note, I have to reset the network adapter 5 times a day. Every time, the error is "default gateway not available".
Hi -
KIS is listed as the probable cause in one BSOD -
klim6.sys         Mon Jun 10 04:27:38 2013 (51B58DFA)
http://www.sysnative.com/drivers/driver.php?id=klim6.sys
Intel wifi driver is listed in the other 2 dumps -
NETwNe64.sys      Tue Dec 06 12:48:39 2011 (4EDE5577)
Intel needs to be updated. Check manufacturer's support site or go to Intel directly -
Update Intel wifi first. If BSODs continue, remove KIS with removal tool - http://kb.eset.com/esetkb/index?page=content&id=SOLN146&locale=en_US
Reboot upon completion. Re-activate Windows Defender -...
Saltgrass
It seems that error code might be caused by something you are doing. You may not know about, but I know some system utilities from SysInternals will cause a BSOD intentionally for you to see how it works. I do not remember if it uses that error code. If you have not done something like this you might check the link to see if it helps.
http://answers.microsoft.com/en-us/...deaddead/8818800c-1da0-48c6-a135-2647005c41aa
jcgriff2
Microsoft MVP
Hi -
Reboot upon completion. Re-activate Windows Defender - http://www.sysnative.com/forums/win...urity-essentials-windows-7-windows-vista.html
Lastly, are you overclocked?
MaxSpeed:     1900
CurrentSpeed: 2395
If so, return to default settings.
Regards. . .
jcgriff2
Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\091413-5843-01.dmp]
Built by: 9200.16628.amd64fre.win8_gdr.130531-1504
Debug session time: Sat Sep 14 19:12:11.981 2013 (UTC - 4:00)
System Uptime: 0 days 21:41:06.749
BugCheck D1, {600000028, 2, 0, fffff88003b7ce91}
*** WARNING: Unable to verify timestamp for klim6.sys
*** ERROR: Module load completed but symbols could not be loaded for klim6.sys
Probably caused by : klim6.sys ( klim6+2e91 )
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  AV
PROCESS_NAME:  System
FAILURE_BUCKET_ID:  AV_klim6+2e91
Bugcheck code 000000D1
Arguments 00000006`00000028 00000000`00000002 00000000`00000000 fffff880`03b7ce91
BiosVersion = Razer.EDGE.03
BiosReleaseDate = 02/01/2013
SystemManufacturer = Razer
SystemProductName = Razer Edge
MaxSpeed:     1900
CurrentSpeed: 2395
Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\091313-5828-01.dmp]
Debug session time: Fri Sep 13 21:30:25.807 2013 (UTC - 4:00)
System Uptime: 0 days 12:04:57.553
*** WARNING: Unable to verify timestamp for NETwNe64.sys
*** ERROR: Module load completed but symbols could not be loaded for NETwNe64.sys
BugCheck DEADDEAD, {e08084b, 125025b, 120122ce, 6250005e}
Probably caused by : NETwNe64.sys ( NETwNe64+3c0d2 )
BUGCHECK_STR:  0xDEADDEAD
FAILURE_BUCKET_ID:  0xDEADDEAD_NETwNe64+3c0d2
Bugcheck code DEADDEAD
Arguments 00000000`0e08084b 00000000`0125025b 00000000`120122ce 00000000`6250005e
MaxSpeed:     1900
CurrentSpeed: 2395
Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\091213-5937-01.dmp]
Debug session time: Thu Sep 12 14:05:54.942 2013 (UTC - 4:00)
System Uptime: 0 days 3:36:39.141
BugCheck D1, {97, 2, 0, fffff880061664ea}
Probably caused by : NETwNe64.sys ( NETwNe64+9c4ea )
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID:  AV_NETwNe64+9c4ea
Arguments 00000000`00000097 00000000`00000002 00000000`00000000 fffff880`061664ea
MaxSpeed:     1900
CurrentSpeed: 2395
Saltgrass
I also see something that mentions klim6.sys, which I think is related to Kaspersky anti-virus. It says it is the faulting application, but that doesn't always mean something else did not cause the problem and this one got caught in the aftermath.
nyjfootball
Active Member
Hi -
Reboot upon completion. Re-activate Windows Defender - http://www.sysnative.com/forums/windows-8-|-windows-rt-tutorials/4976-re-enable-windows-defender-windows-8-aka-microsoft-security-essentials-windows-7-windows-vista.html
MaxSpeed:     1900
CurrentSpeed: 2395
Regards. . .
jcgriff2
BUGCHECK_STR:  AV
MaxSpeed:     1900
CurrentSpeed: 2395
MaxSpeed:     1900
CurrentSpeed: 2395
BUGCHECK_STR:  AV
MaxSpeed:     1900
CurrentSpeed: 2395
Thank you for the sweet, complete breakdown!! I have updated the Wi-Fi and so far everything's running smooth. If issues continue I'll uninstall Kaspersky and go with Defender. As for being overclocked, I didn't change anything but how can I fix that issue and get things back to normal? It's been running hot but not overusing system resources.
nyjfootball
Active Member
Thanks Saltgrass! If the problem isn't the Wi-Fi, I'll uninstall Kaspersky. I really appreciate your help!
nyjfootball
Active Member
No BSOD now and no crashes or unexpected restarts. But the problem isn't solved unfortunately. I have to restart the computer every time the network disappears and drops out. I usually get a connection for 5 minutes at a time until a restart is necessary. I'm attaching 3 network logs in hopes you'll know what the issue is. Thanks again for all your help! I have not uninstalled Kaspersky. If you think I should, then I will.
https://skydrive.live.com/redir?resid=B1887EE1F90D4B2A!132&authkey=!AMl8nAUZ9Vi5l88
https://skydrive.live.com/redir?resid=B1887EE1F90D4B2A!131&authkey=!AOy1nB-2rUXQN5k
https://skydrive.live.com/redir?resid=B1887EE1F90D4B2A!135&authkey=!AIgWEyr2_LtzIio
